Author Topic: Why would someone NOT do this?  (Read 5548 times)
Offline BeSeeingYou
Re: Why would someone NOT do this?
« Reply #25 on: May 26, 2014, 08:08:47 PM »
On Yamaha XS650's the two crankcase drain plugs have a magnet built into them.
« Reply #26 on: May 26, 2014, 10:21:13 PM »
because the xs650 has such a crappy filter set up!
Offline cakey
  • 5% recipe and 95% process
« Reply #27 on: May 27, 2014, 03:28:46 AM »
Real novice comment hear, but just asking the question.
When doing up my CX500 there was lots of talk on the forum of motors that had blown because the oil bolt washer was missing and the holes in the bolt would get restricted of oil and starve the engine.
Could there be a risk of this happening using different size magnets and the holes being restricted?
1971 CB750 K1 (restored)
1975 GL1000 Goldwing (restored)
« Reply #28 on: May 27, 2014, 12:58:32 PM »
with magnets used on the tin filter end no holes are restricted at all.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #29 on: May 27, 2014, 01:01:20 PM »
What if the shavings are aluminum?
« Reply #30 on: May 27, 2014, 01:07:07 PM »
they make pretty sparkles in the oil!
Offline Whaleman
« Reply #31 on: May 27, 2014, 01:07:22 PM »
The magnet will not attract aluminum. On the other hand aluminum is softer and will cause less wear than steel. Dan
AJK
« Reply #32 on: May 27, 2014, 04:22:34 PM »
Makes a nice polishing compound  :D
« Reply #33 on: May 27, 2014, 04:28:55 PM »
If you use bamboo magnets it will atract all the wooden splinters floating in the system.
« Reply #34 on: May 27, 2014, 04:32:41 PM »
Well i'm going to use chick magnets, I need all the help i can get.... 8) :P
Offline Whaleman
« Reply #35 on: May 27, 2014, 04:38:54 PM »
We thought you were THE, "chick magnet".
« Reply #36 on: May 27, 2014, 04:57:42 PM »
Really.? I could only wish for such a status... 8)
AJK
« Reply #37 on: May 27, 2014, 05:06:23 PM »
Retro, you really should get together with Dave. He is the man.
Offline Grnrngr
« Reply #38 on: May 27, 2014, 05:08:56 PM »
Totally different thread than I was expecting, great info and I'll be doing it soon, but since I didn't see anyone mention it, the first article I read about using HDD magnets on a bike, was to attach a few to the bottom of the bike at a low spot as an aid to tripping the sensors at stoplights. Supposedly it's very effective. Think I'll be taking a few old drives to the rifle range, total destruction is the only true security.
'72 CB750-K2 "PopCycle"
'73 CB750-K2 "Barney"
'77 CB750A
'83 Virago 500 (red)
'83 Virago 500 (black)
« Reply #39 on: May 27, 2014, 06:35:00 PM »
I've seen Dave enough times to call him a friend mate... ;) His wife said he can be the man as long as he likes, as long as she wears the pants.... ;D ;D :o ;)
