Author Topic: Draining Gas Tank Question - Need Help!  (Read 1714 times)
Offline ironandtime
    • Iron & Time
« on: May 24, 2014, 10:29:33 AM »
Hey Gang,
I have my gas tank off of my '78 CB550, and I am trying to get all the gas out of it since I am about to strip all the paint off. Most of the gas drained fine out of the petcock, but there seems to still be a small amount sloshing around somewhere in the tank. I even tried removing the petcock completely, and tipping the tank upside down with the cap off, but that last little bit will not drain out at all. It also sounds like that last little bit might have some debris in it as well. How do do I get every drop out of the tank? Thanks!!
1978 Honda CB550
Offline Koonendez
Re: Draining Gas Tank Question - Need Help!
« Reply #1 on: May 24, 2014, 11:35:13 AM »
My guess is that you're dealing with the in tank fuel filter in there blocking the rest of the gas if you're trying to pour it out of the petcock bung hole. I used a small siphon (really cheap at autozone) and pretty much removed 99% out with the siphon.
'78 Honda CB550K
« Reply #2 on: May 24, 2014, 01:45:30 PM »
Might be the fuel filter itself banging around in there. Did your petcock have one attached when you removed it. Not an expert on that model though to know if it has the 'sock'.
Offline 2wheels
« Reply #3 on: May 25, 2014, 05:47:06 AM »
When I want the tank completely empty I do what you have done.
Then as a last step I take a cloth rag (long and thin) and put it into the tank.  Leaving some hanging out the top so I don't loose it in there.
Then, shake the tank around.
1970 CB750 K0 (I can't believe I tossed my duck tail seat in the trash 30 years ago)
Offline billingstitan
« Reply #4 on: May 26, 2014, 08:59:25 PM »
+1 on the acetone - although you might want to have some two-stroke oil or wd40 to give a quick coat to the interior to prevent flash rust.
Calling upon my years of experience, I froze at the controls.  ~Stirling Moss
2014 Ducati Monster 796
1977 CB550K http://forums.sohc4.net/index.php?topic=138289.0
1977 CB550K
1972 CL175
2000 Kaw Nomad 1500
1992 KDX 200
2001 Honda 80R
Past Bikes:
1973 Kaw 900Z1
1970 Yamaha 350RD
2003 Yamaha VStar 1100
2001 Suzuki GS850
Offline Airborne 82nd
« Reply #5 on: May 27, 2014, 05:55:15 AM »
After it is clean and if it is going to sit for awhile I use a can of fogging oil that stuff gets into every little nook & cranny ( what is a cranny) ??? it is at the pressure washing parts area at Lowe's or Home Depot. I use it every winter.
Offline ironandtime
    • Iron & Time
« Reply #6 on: May 27, 2014, 07:49:16 AM »
Thanks ya'll! Lots of good ideas here - I appreciate the help. Cheers, Matt
1978 Honda CB550
