First thanks for all the help so far from everyone As the title says my bike is a 78 750K the carbs are 42b with 35 slow & 110 mains the bike runs great has stock intake paper filter from Honda plus I have a spare K&N that I may or may not use depending on what the most and smartest say. The exhaust is a 4 into 2 unknown brand so one on each side they have baffles and sound good a little deeper throatier than stock.
I bought a complete rack for $50 that are very clean on the outside and the bowl area. I am still going to break them down to make sure they are good to go on the inside. Now the questions The new set are 42a. I have read the bodies are the same. Is this true? If so can I just change the high & low jets? I think the lows are the same #35 but not 100% sure. Also is the float height (12.5 +/-.5) or (14.5 +/- .5) I cleaned the set on the bike (PD42b) a few months ago and got them right on the third try
Like I said it runs great all clean. Choke and fast idle cam set float height but I not sure if I set them to 12.5 or 14.5 but at the time I use the clear tube and they were all about 2 to 3 mm below the bowl gasket.
Just to recap what is the correct carbs on a 78 750K? What slow and high jets are correct? What is the correct float height? Should I start with the pilot screw 1-1.5 out from a gentle seat? If I have forgotten any thing please let me know. I take corrective criticism very well. Any little tips are welcomed.
