Author Topic: 6'6" and I bought a 1978 CB750...  (Read 37183 times)
Offline Davez134
Re: 6'6" and I bought a 1978 CB750...
« Reply #50 on: July 15, 2014, 01:25:36 PM »
If you tape the line where you are going to cut with good painter's tape, the finish should be ok. (Mine didn't chip at least) I ended up doing it black anyways though.
[IMG]http://img.tapatalk.com/d/14/07/16/5u8y2
Sent from my iPad using Tapatalk
Offline Prez1967
  • Adding lightness...
« Reply #51 on: July 15, 2014, 01:33:30 PM »
I was debating cutting it at the part closest to the bike to retain the rolled edges but it looks like cutting from the rearward edge would be the best option for mounting properly.
Offline Davez134
« Reply #52 on: July 15, 2014, 08:24:18 PM »
I too was wondering how it would look with the rolled edges up the sides and then stopping at the rear. Actually looks great if you take your time cutting it.  I would not mess with cutting rear edge if you are worried about proper mounting. I wish I would have thought of that though, as my rear mounts had been cut off by the P.O. And I had to make new anyways.  Good luck, and of course, post pics!
Offline Prez1967
« Reply #53 on: July 16, 2014, 01:56:30 AM »
Thanks Davez! Could you measure the overall length of that just to give me an idea?
Offline AintNoEasyWay
« Reply #54 on: July 16, 2014, 06:18:24 AM »
That does look nice, Davez. Any photos to share of it on the bike? Like Prez asks, some measurements would be great.
« Reply #55 on: July 16, 2014, 07:40:46 AM »
I would definitely agree that if is easiest to retain the stock mounts and bob the fender from the trailing end with a steady hand and a cutting wheel.  If you are going to paint it, then you will have even more forgiveness with the cutting wheel.
Offline Davez134
« Reply #56 on: July 16, 2014, 07:41:44 AM »
Just went to measure. Overall length is 12.5 inches. Pics are of brackets I made and fender on bike...
Offline Prez1967
« Reply #57 on: July 17, 2014, 09:32:04 AM »
Great pictures!!! Thanks for the info also.
I tried taking my bike by the local shop yesterday only to find that they were closed for the day.  Sucks because I had a friend drive his monster F250 with a utility trailer about 45 min to get to me and another 20 min to the shop only to find that the doors were closed.  Thats alot of diesel fuel wasted haha... I'll probably rent a U-haul trailer for $25 tomorrow and swing it back up that way.
On a positive note, my seat came from Motorcycleseatsdirect.com today!!! Alot earlier than expected.  It looks damn good and I look forward to swapping the hardware on to the base from my spare OEM seat when I get home.  I'll report back on fitment.
I'm also going to have my hand at re-installing the exhaust tonight to see if I can get the #2 flange to fit before I take it to the shop.  Still very curious as to why the bike wont start with the new exhaust/filter setup.
Heres a quick picture of the new seat:
Offline Davez134
« Reply #58 on: July 17, 2014, 01:03:37 PM »
Did you try to start without exhaust on ( or without being fit properly?) I wasn't clear on that by reading your posts. That could cause it not to start. Also you may have to mess with idle mixture ( though I'm not really familiar with PD carbs)
Offline Prez1967
« Reply #59 on: July 17, 2014, 01:13:09 PM »
Didnt try starting it with exhaust off... Tried starting it after installing exhaust and pods (#2 flange isnt secured but pipe is in there). Im gonna let the pros mess with it for now.
Offline Prez1967
« Reply #60 on: July 17, 2014, 04:13:12 PM »
Still needs a bit of an adjustment at the hinge but this will certainly do just fine :-)
« Reply #61 on: July 18, 2014, 05:43:58 AM »
That seat looks sweet, Prez. If I didn't have my original seat redone, I would definitely go for a similar shape. Fits very nicely with the 77/78 tank (which is the coolest tank shape of the CBs, in my opinion), & will look even better once you get the chrome trim lined up.
As you're probably aware, switching to pods & changing exhaust may increase the complexity of the system too quickly. Better to give Davez's advice a shot first; take one thing at a time.
Looks like you're getting closer & closer to the goal of streamlining this thing though. I think it'll be a cleaner, modernized version of the original, which I love.
« Last Edit: July 18, 2014, 05:46:30 AM by AintNoEasyWay »
« Reply #62 on: July 18, 2014, 02:39:50 PM »
"Fits very nicely with the 77/78 tank (which is the coolest tank shape of the CBs, in my opinion)"
Damn.  Being the proud owner of a 77 CB750K7, I would have to disagree, but beauty is in the eye of the beholder!  Such is the reason I swapped to an F-style tank.
That said, this combo looks good!
Offline Davidov
  • 1978 CB750 F3
    • My CB750F project log
« Reply #63 on: July 18, 2014, 02:47:53 PM »
Looking nice so far  :D
-David
« Reply #64 on: July 18, 2014, 05:17:52 PM »
Haha. The F still gets 2nd best in my book!
Offline Prez1967
« Reply #65 on: July 20, 2014, 01:03:48 PM »
Bike was dropped off at my local shop Friday to get some odds and ends buttoned up and have the carbs tuned for the new exhaust/intake.  I told them I need it back in two weeks.
« Reply #66 on: October 23, 2014, 11:03:12 AM »
Hey Prez, any news on the bike brother?
Offline Prez1967
« Reply #67 on: October 24, 2014, 06:35:52 AM »
After i got the bike home from the shop, i just parked it.!
Carbs have been cleaned and rebuilt but one is leaking. A bracket was made for the Carpy 4-1 and the front caliper was rebuilt.
I need to order a new brake line, tune carbs for new exhaust setup and a couple other small items and that'll be it for this winter (unless I get frisky). I'd like to ride it springtime as-is to get a feel for it.
I can tell that the new seat will be too low for my height. I may go back to the stock seat and look into having a custom seat made into the style of the Vietnamese seat but higher.
« Reply #68 on: October 25, 2014, 05:11:26 AM »
Nice. I assume the leak on the single carb is just from float height being off. Still really like Carpy's turn signals that you got. Saving a pic of your bike with the new signals so I can install some on mine this winter.
Offline Prez1967
« Reply #69 on: December 07, 2014, 07:02:12 AM »
No progress yet as I'm having too much fun playing with my 8 month old son  :D
Managed to buy a new tank on Ebay as I've found myself drooling over some of your builds on this site and figured I "needed" it.
Since I already have aftermarket rear blinkers and brake light/tag holder on the bike, I'm not sure what seat setup i'm going to go after should I choose to run with this tank but we'll see.  Is it safe to assume that if I wanted to run the tank, simply swapping on a F seat/base setup would work? My wife really wants me to keep the rear seat for the time being until we get another bike so I can take her for a ride from time to time. Maybe if I found a F seat setup and fit it to the bike I'd get a better idea if I like it or not.  The aftermarket seat that I got from Vietnam is too low for my 6'6" body to sit on it comfortably... It'll be for sale soon.
« Reply #70 on: December 07, 2014, 09:57:02 PM »
I have a 77 CB750K bike with a F tank.  Mine, however, uses a custom seat.  The F tank WILL fit right into the mounts but I'm not sure if the K seat will need some adjustment.
Offline Prez1967
« Reply #71 on: August 04, 2015, 11:25:19 AM »
I've gotten the itch to start fiddling with this thing again.  Having kids really takes time away from garage play time but I'm at it again.
Carbs need to be looked over and jetted/tuned
Front master cylinder and brake line needs to be assembled/bled and hooked up to tail light
Steering stop needs to be adjusted so that I dont mash up my hands on steering lock
And I'm sure a bunch of other stuff
Called two shops today about working on carb tuning.  Both claim they can get the pods and exhaust to work just fine without having to resort back to factory air box... we'll see. Both shops prefer to retain the points ignition because they find it more reliable than electric (I was shocked).
With the rough quotes i'm getting for tuning the carbs (from $400 and up depending on issues they run into when they dig in) I may have them install more of the parts I have laying around.  Unless they can return the bike to me within three weeks, I may have them hang onto it over the winter and bang out some of the larger jobs including bearings install, brake upgrade, wheel/tire install/upgrade etc.
Wish me luck, I'm really hoping to get some riding in this year before the fall.
« Reply #72 on: August 04, 2015, 11:27:44 AM »
Great to see you back, prez. Good luck!
Offline TomsK8resto
« Reply #73 on: August 04, 2015, 12:59:17 PM »
Prez, good to see you posting again. I came across your build and like many of your mods.  On the seat that you ordered and received from Motorcycleseatdirect, did you buy the seat where they supplied the seat pan or did you get the cover and foam and put it on your own pan?
Tom
'69 CB750 long gone
'76 CB750F gone
'78 CB750K in progress.....
'09 H-D Roadglide
Offline Prez1967
« Reply #74 on: August 04, 2015, 03:41:45 PM »
Good to be back gentlemen! Glad to see everyone is doing well from todays browsing :)
The seat I bought from Motorcycleseatdirect was the model that they supplied the seat pan for.  I will say that the seat pan is no where near OEM quality but it seems to do the job.  Still uncertain if I'll be sticking with this seat or going the custom route.
I'm hoping the shop I end up with has the capability to dyno the bike.  Some of these guys are old school (and old) and they may have it down to an art so I'm not disregarding them just yet if they dont have a dyno at their shop.
