Author Topic: What type grease can I use?  (Read 1512 times)
Offline Moosey
« on: November 24, 2014, 03:01:43 PM »
I am in the process of building a 71 cb500 and am cleaning up the wheels. Got the brakes, sprocket, speedometer pickup, and axles off. Gonna cleanup the axle areas and would like to regrease everything prior to reinstall. I have some general use grease that states its "moly fortified ford lincoln mercury gen purpose grease" and i also have "green grease". Is it ok to use any one of these or should i get something else? Also can I use any of those for the rear swingarm bolt?
Thanks
Offline [Blank]
Re: What type grease can I use?
« Reply #1 on: November 24, 2014, 04:42:50 PM »
You might get other opinions but this is My favorite.
Offline Whaleman
« Reply #2 on: November 24, 2014, 06:14:20 PM »
I use waterproof wheel bearing grease. Dan
Offline MoMo
  • Ride like you're invisible
« Reply #3 on: November 24, 2014, 06:21:22 PM »
good choice,  Belray waterproof grease may be a little bit better though...Larry
Offline MiGhost
  • What was that about being an
« Reply #4 on: November 25, 2014, 11:52:38 AM »
Waterproof grease!! What a concept!! ;D ;D ;D
Gotta love those sales marketing schemes. ;D ;D ;D
~ Ghost
Grey Ghost '80 CB650C: Updated Stock Restomod. Period Custom Cruiser (OEM harbags & trunk, Wixom Ranger fairing, Jardine turnouts)
Bad Moon '83 XJ750MK Midnight Maxim: Full Dress Tour Deluxe w/ X-1 Fairing
Offline Moosey
« Reply #5 on: November 25, 2014, 04:23:59 PM »
Thanks for replys! Anyone know if I can use the grease(s) I listed?
« Reply #6 on: November 25, 2014, 04:28:31 PM »
Waterproof grease is different to normal grease, its usually called "marine grease" here in Aus, I use it on my boat trailer bearings {amongst other things} and it lasts longer with exposure to water than normal grease.... ;)
Offline bjbuchanan
« Reply #7 on: November 25, 2014, 04:57:55 PM »
Yes you can use them, go for it. You have dust shields on critical areas anyway, regular grease is enough. Use the higher temp of the two. I usually just use wheel bearing grease for everything ;D
