Author Topic: needle valves  (Read 1212 times)
Offline tramp
needle valves
« on: September 20, 2006, 09:05:59 AM »
leaking gas out the overflows
when i tap the carb the gas stops
figure a needle valve is sticking
can i repair the sruck needle valve without removing the carbs and do i need to get the carbs syncro'ed again
1974 750k
Offline dusterdude
Re: needle valves
« Reply #1 on: September 20, 2006, 09:08:20 AM »
drop the offending float bowl and remove the float,the needle will fall out at that point,be carefull dont lose it.clean the tip real well and make sure its not cracked and then blow carb cleaner into the seat and take a soft rag or something of that nature and clean the seat with that,that should take care of any debris that may be in there.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Re: needle valves
« Reply #2 on: September 20, 2006, 10:00:18 AM »
 If it's a metal tip float needle you'll have to replace it and the seat.
