Author Topic: first start  (Read 352 times)
Offline mikecb550
first start
« on: June 11, 2014, 04:22:59 PM »
Hello. I have recently purchases a cb550k 1977. I haven't heard it run but have been assured it does.I was told the starter motor doesn't work. The engine oil looks clean?
I was wondering if there was a rundown somewhere on the forum of what to check before attempting to start the bike. I was going to put a fuel filter  between tank and carb. also new fuel line as it's old.
Any thoughts appreciated. Mike.
Re: first start
« Reply #1 on: June 11, 2014, 04:48:21 PM »
clean fuel, good battery
check blockages(critters) in exhaust and in airbox/filter.
might want to pour a little oil up top(valves) to protect them until oil pressure builds.
....fire in the hole!
Offline greenjeans
  • 1972 CB750K2
Re: first start
« Reply #2 on: June 11, 2014, 04:52:07 PM »
Here's what I do everytime:
Take the carbs off and clean them. Thoroughly.  That will eliminate fuel issues.
Clean the points and set the timing.  New plugs.   Squirt a little marvel mystery oil or your favorite snake oil in the plug holes.  Trim 1/4" off the spark plug wires.
Set the valve tappets and the cam chain tension.  Squirt a little oil in the valves while you have the caps off.
Basically, you're doing the 3000 mile tune-up.
The starters are pretty overbuilt.  I'd check the solenoid first - You can put a big screw driver across it and see if the starter spins.
Offline Thamuz
Re: first start
« Reply #3 on: June 11, 2014, 05:32:50 PM »
+1 on Greens answer.  Be sure to use a guitar string on the jets in the card.  Pilot jet and slow idle.  Get the junk out.
Also, if you have the airbox, use it.  Pods are a pain, coming from experience on my current bike.
1979 Yami Chopper XS1100s
1978 CB750k
1977 CB550F
1974 CB550k
Parts bike for the 550's
