Author Topic: CB360 Rolls in Gear  (Read 963 times)
Offline Dake
  • Not James May.
  • Wine tastes on a college budget.
CB360 Rolls in Gear
« on: June 13, 2014, 06:19:09 PM »
Hello. I know this isn't the exact place to post this, but given how similar the 350 and 360 are and the generic nature of the question I figured I'd ask.
I have a CB360 that will not kick start. There is little to no resistance when I move the lever, and I can do it by hand. It has kicked freely in the past, though it did not start then for electrical reasons. I had no idea what changed, and then I noticed it rolls while in gear. There is resistance when doing so, but not a lot. I can't get this to change no matter what I do with any or all of the clutch adjustments. I was just in the clutch basket area with the right side case open, so I know the clutch isn't rusted together.
I feel like the clutch issue might be leading to the kicking issue. I searched, but as can sometimes be the case I found a lot of dead-end topics and no answers. Any insight is appreciated.
x 1982 XJ750
x 2006 FZ6
x 1976 CB750K
x 1974 CB750K
x 2002 F4i
x 2007 600RR
1975 CB360T
2005 600RR
Re: CB360 Rolls in Gear
« Reply #1 on: June 13, 2014, 07:35:26 PM »
The clutch is slipping, most likely something you miss-assembled when you were messing with the basket?
Offline grcamna2
« Reply #2 on: June 13, 2014, 08:46:28 PM »
How's the clutch actuator mech. on the left drive cover,did you adj. the clutch ?
Offline trueblue
« Reply #3 on: June 14, 2014, 03:25:57 AM »
+1 on the clutch adjustment, I don't know if it is possible on the 360 but on some bikes it is possible to have the clutch that far out of adjustment, the mechanism can overcentre and lock the clutch in the disengaged position. ;D
1979 CB650Z
Offline Franky
« Reply #4 on: June 14, 2014, 03:40:41 AM »
Otherwise try the good http://www.hondatwins.net/ - I also have a CB360T, and have found much great info there.
1974 Honda CB360T Stock
1974 Honda CB550 K0 Stock
1977 Honda CB550 K3 Cafe - never ending build :)
1988 Honda Dax ST50 Cafe
1997 Honda Benly 50S Stock
Check out my "Yamaha R6 fork on a CB550 made easy" thread:
http://forums.sohc4.net/index.php?topic=118983.0;all
Offline RJ CB450
« Reply #5 on: June 14, 2014, 07:04:53 AM »
Will be clutch for sure to start.  I remember learning the kickstart and being a derp and holding the clutch first time I tried XD
74 CB450 K7 Supersport, 82 CB650sc Nighthawk, 1982 CBX 1000, 2015 Tiger XCx.... And some ol minibike with a 5hp Briggs.
Offline enwri
  • So that noise is normal?
« Reply #6 on: June 14, 2014, 07:33:24 AM »
Have you had the springs and the pressure plate off? the pressure plate will fit over the spring posts in any of four ways, but will only fit onto the internal splines in one position, I thought there was some sort of mark on the pressure plate, and the centre hub. if it's not on properly the clutch cannot squeeze the clutch plates together, so clutch appears at the lever to be already pulled in and slipping.
77 CB 750 k.. 29 years and counting.
91 TDM 850 (No.34) so comfy and soft
8? XJ 550 meh...
76 XL 350 Super Sport stump puller..
80 XR 200 idiot proof
75 MX 250 b dangerous
