Author Topic: Old Wiseco's  (Read 2821 times)
Offline jweeks
Old Wiseco's
« on: June 14, 2014, 10:27:01 AM »
I've got a set of NOS (1978?) 836 Wiseco's. There's no arrow on the dome for orientation. The dome isn't fully machined, just a 5/8" circle in the center (used for turning?). Two slightly different width valve pockets and the number 1.00 stamped into the dome. Anyone know which way I put them on? I'll be calling Wiseco Monday otherwise. This is supposed to be running for next Friday. Just call me last minute Jon. ::)
  • Moderator
Re: Old Wiseco's
« Reply #1 on: June 14, 2014, 10:40:40 AM »
Jon, the off set of the piston pin is to the rear. I was puzzled by it the first time I saw a set of Wiseco pistons.
Sam. ;)
  • Moderator
Re: Old Wiseco's
« Reply #2 on: June 14, 2014, 10:45:37 AM »
Although you would expect the slightly larger valve recess to be for the bigger inlet valve, it's bigger for the off set of the exhaust valves being away from the center. It saves making two handed pistons, these can be fitted anywhere you care to put them.  ;D ;D ;D ;D ;D
Sam. ;)
Offline Bill/BentON Racing
    • BentON Racing
Re: Old Wiseco's
« Reply #3 on: June 14, 2014, 10:55:42 AM »
No mo 1&3 and 2&4 sets. The newer Wiseco's have an arrow now.Go Jon go, you got your answer, Sam to rescue!  ;D K. Bill
BentON Racing Website
BentON Racing Facebook
  • Moderator
Re: Old Wiseco's
« Reply #4 on: June 14, 2014, 11:29:02 AM »
 ;)   ;D ;D ;D ;D ;D ;D ;D
Offline jweeks
Re: Old Wiseco's
« Reply #5 on: June 14, 2014, 11:52:48 AM »
Thanks Sam. I'm working on it. ::)
    • BentON Racing
Re: Old Wiseco's
« Reply #6 on: June 14, 2014, 12:23:35 PM »
The newer Wiseco the smaller cut is on exhaust side. IC soon! ;D Bill
Offline jweeks
Re: Old Wiseco's
« Reply #7 on: June 14, 2014, 01:22:04 PM »
The stamped 1.00 is on the intake side with the wider valve recess toward the exhaust side of the motor. Pistons mounted, circlip wires in, wood cut, waiting for my help who is away for the weekend. Monday the block goes on. It won't have any passes on it when I get there Friday. (And I took Frank's bet??? ::)) It will take a miracle....
    • BentON Racing
Re: Old Wiseco's
« Reply #8 on: June 14, 2014, 03:24:18 PM »
Do 2&3 first, use hose clamps....done it many a time without ring compressors, rather use clamps and 10 fingers, well sorta, rather than 20! Haha.You can be riding tomorrow or at least have engine finished! C'mon man, you can do it!  ;D Bill
Online MRieck
Re: Old Wiseco's
« Reply #9 on: June 14, 2014, 05:33:16 PM »
Yes...that is the gospel.
Online MRieck
Re: Old Wiseco's
« Reply #10 on: June 14, 2014, 05:34:47 PM »
No. Consider the valve size vs angle Jon.
Offline jweeks
Re: Old Wiseco's
« Reply #11 on: June 14, 2014, 06:25:44 PM »
Mike you and Sam seem to disagree. I'm just trying to put this thing together right. These are very old Wiseco's.
Offline BPellerine
Re: Old Wiseco's
« Reply #12 on: June 14, 2014, 06:30:27 PM »
do they look like these?
1978 CB 750K ard and webers
another anfob
Offline jweeks
Re: Old Wiseco's
« Reply #13 on: June 14, 2014, 06:43:48 PM »
No, as stated when I started this posting, the dome isn't machined nor is there an arrow. There is a machined circle at the top of the dome along with a stamped 1.00. The dome is actually a little grainy.
Offline jweeks
Re: Old Wiseco's
« Reply #14 on: June 14, 2014, 06:53:47 PM »
Bill,
     I'm building this in a trailer. After dark, you run for your life as the mosquito's will eat you alive. I'm racing tomorrow, so we'll see what can get done after the event. Finding the right size hose clamps late on a Sunday will also be a challenge. Not much open for auto parts stores then. Maybe Walmart... :o
Offline Big Jay
    • CBRzone
Re: Old Wiseco's
« Reply #15 on: June 14, 2014, 11:11:39 PM »
Sounds more like a Forgedture. Does it say Wiseco or have a W in an oval underneath?
Re: Old Wiseco's
« Reply #16 on: June 14, 2014, 11:22:21 PM »
Jon, if you could post a picture of your pistons it may help getting things figured out?
Online MRieck
Re: Old Wiseco's
« Reply #17 on: June 14, 2014, 11:26:02 PM »
Yeah...something is odd.
    • BentON Racing
Re: Old Wiseco's
« Reply #18 on: June 15, 2014, 04:49:44 AM »
I've posted a pic before. One was in the line of pistons I posted a couple times. I'll look for a pic. I want Jon there and on an Automatic!  ;D It was an old NOS kit purchased from Star Cycle. Remember talking with Jackie, I found a date of 1987 on some paper on pistons! Remembered it weighed 177.xx grams. Just a little roadblock Jon, you'll get it done!  8) Bill
    • BentON Racing
Re: Old Wiseco's
« Reply #19 on: June 15, 2014, 02:15:19 PM »
Well we got something to cool 'em with! Haha. Jon, what's a qt in Maine?
Offline jweeks
Re: Old Wiseco's
« Reply #20 on: June 15, 2014, 05:21:05 PM »
$4.25
Pistons are mostly in the block. A couple of oil rings will join them tomorrow. Camera had a dead battery that's now charging. Hopefully pictures tomorrow evening. By then, I'm committed.
    • BentON Racing
Re: Old Wiseco's
« Reply #21 on: June 15, 2014, 07:51:57 PM »
Buy your oil in Maine, was $4.80 with discount! I'll just hang on to it if you want, Bill ;D
Offline jweeks
Re: Old Wiseco's
« Reply #22 on: June 16, 2014, 02:56:13 AM »
Plus state sales tax. I'll take a case; you went to the effort. I've got half a case left from 3? years ago at $3.60/qt. A barrel of oil hasn't gone up much in the last few years, but the price of oil per quart for our bikes sure has.
Offline jweeks
Re: Old Wiseco's
« Reply #23 on: June 16, 2014, 06:56:15 PM »
Camera battery recharged, but the head is already on the motor. I'm lashing the cam tomorrow night; if everything spins the right way, I'm racing it Saturday. If it clunks or binds, it's coming apart (again) and I'll shoot the piston shots that others want. Too tight a schedule for resolving this topic. I went with the wider valve pocket for the exhaust valves on this motor. I'll let everyone know how it goes. Thanks for the responses.
    • BentON Racing
Re: Old Wiseco's
« Reply #24 on: June 16, 2014, 07:08:34 PM »
We can do that trackside, it's an automatic ! Haha!  8)
