Author Topic: At least Valvoline is trying to help!  (Read 20971 times)
Offline grcamna2
Re: At least Valvoline is trying to help!
« Reply #25 on: June 20, 2014, 05:03:45 AM »
How do you know what has zinc and what doesn't? Also ive noticed no foaming in my oil tank with valve line 10-30w. Though she does run a bit warm but I don't have anything to compare it to.
Have you found that 10-30 is too light for your application? especially in NC.
75' CB400F/'bunch o' parts'
Offline Oldtech
  • Motorcycle tech: old, cranky and retired
« Reply #26 on: June 20, 2014, 06:16:44 AM »
I use Honda GN4 in all my bikes. No complaints. Costs me about $6.50 a quart.
Offline grcamna2
« Reply #27 on: June 20, 2014, 06:49:34 AM »
That's a decent price for GN4
« Reply #28 on: June 20, 2014, 07:10:01 AM »
The nearest Walmart actually carries this Valvoline 20W-50 oil.  I may give it a try next time.
Offline KC_Northstar
« Reply #29 on: June 20, 2014, 07:17:07 AM »
This isn't an 'oil thread', but a singular on-line product evaluation attempt, by me.  :D
If you have used this oil, maybe make a comment about it? If not, don't bring up another oil topic, please.
http://www.valvoline.com/products/consumer-products/motor-oil/motorcycle-atv-oil/13
"Normal" Valvoline oils (good for car engines) have long been my personal choice, and I typically get upwards of 300k miles from my engines with it. But, it has always had too much detergent for bikes, making it foam in our SOHC4 engines. Since the EPA started edicting in 2002 that oil makers follow THEIR rules and not [needed] ones, most oils have fallen well short of what we need. Here is the first version I have seen in a long time that is trying to meet the needs: good for wet clutches, has more-than-others zinc, and has anti-foaming agents included. I'll try some out at my 100 mile oil change and report back (if I can find some around here).
...and you can be sure that Valvoline is taking some serious flak from the EPA for selling it...
I am 'shopping' for a new bike oil because the Castrol 4T falls well short of my expectations since they, too, removed the zinc, starting in 2008. It makes the 1-2-3 gearshifting sticky, and the clutch 'grabby', compared to, say, Bel-Ray mineral oils. Problems is: Bel-Ray is hard to find outside of the 9 AM -to-6 PM bike shops, and locally they are gouging over $7 per quart for it. I work 9 AM to 8 PM most days, can't ever GET to a bike shop...and shipping heavy oil makes it closer to $10 per quart.  >:(
This is turning into an 'oil thread'    You might want to read Marks's original posting again.  Especially the first 2 sentences.
KC
1971 CB750-K1
1972 CB750-K2
1971 SL350-K1
1971 SL125-K0
1979 CM400A
Offline grcamna2
« Reply #30 on: June 20, 2014, 07:56:22 AM »
So far I don't see it getting too technical...  ???
Offline jamesbekman
« Reply #31 on: June 20, 2014, 09:56:18 AM »
Yea Valvoline VR1 racing oil is where its at.  I use it in my MGB.  http://www.valvoline.com/products/consumer-products/motor-oil/racing-motor-oil/6/
Offline Kevin D
  • SE Michigan
« Reply #32 on: June 20, 2014, 10:10:52 AM »
I've been using Valvoline MC oil since 2004, about 20000 miles. I'm a bargain shopper and finding JASO oil at the bigbox store on sale is fine by me. I've seen it at AutoZone and Advance Auto as well.
My experience:
My clutch is not in the best shape, good for normal riding, but just gives up when thrashed. It was much better for quite a while after I deglazed the plates, added Barnett springs, drilled the extra basket holes. I have new friction plates on hand, but I'd rather ride the bike than work on it.
Finding neutral when stopped can be a chore, but this K1 has never been a slick shifter like my K0 was.
Leaks: top end is pretty dry since 2008 rebuild, bottom end maybe a small seep here or there.
I haven't tried a bunch of other stuff to compare.
I've seen Terry's condemnation of Valvoline oil, I'm not doubting him one little bitty bit, but its not my experience.
I saw bwaller's Blackstone labs thread recently. It'd be nice to have a library full of used oil test results, a running history on my bike, and the smarts to understand it all. I might do an end-of-season sample and post  results.
From the Valvoline PDF's: 0.112% zinc for MC oil, 0.083% zinc for conventional automotive oil. Thats more zinc, but not a whole lot more.
VR1 racing (non-JASO) 0.14% zinc
« Last Edit: June 20, 2014, 11:05:46 AM by Kevin D »
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline jamesbekman
« Reply #33 on: June 20, 2014, 10:12:29 AM »
There is conventional and synthetic, obviously conventional for our bikes...
http://www.valvoline.com/pdf/vr1_racing.pdf
-James
Offline jamesbekman
« Reply #34 on: June 20, 2014, 10:14:04 AM »
Kevin we are talking about Conventional RACING oil not their standard conventional oil.  I think a few other posters are commenting without knowing that as well.  I just want to make it clear for everyone.
« Reply #35 on: June 20, 2014, 10:24:49 AM »
So if I read the spec sheet correctly the VR1 racing oil should not be used in our bikes as it specifies not to use with a wet clutch application.
« Reply #36 on: June 20, 2014, 10:48:42 AM »
....exactly why I'm interested in the results of HM's test  :)
Offline grcamna2
« Reply #37 on: June 20, 2014, 10:49:35 AM »
I think they have a '4 stroke synthetic' M/C specific oil
Offline jamesbekman
« Reply #38 on: June 20, 2014, 01:02:24 PM »
Ahhhh got ya.  Yup I was wrong.  Didnt see that part.
« Reply #39 on: June 20, 2014, 03:08:29 PM »
Yep Hondaman is testing the 4 stroke specific motorcycle oil not the VR1 racing oil. Hopefully he will pile some miles on for everybody.
Offline CoachDoc
  • 1974 CB550, 2005 GL1800, 1997 Valkyrie Standard
« Reply #40 on: June 20, 2014, 03:36:05 PM »
I've been using Valvoline  manufactured synthetic 15W-50 oil from NAPA for the last few years and I love it. Priced below most other synthetics ...........worth a look for sure.
Are you running that with a cb750k? How often do you change your oil being its synthetic?
I'm running that Valvoline/NAPA oil in my '74 550, changing it every 2000 miles whereas I used to change Dino oil every 1K. I also started using it in my Valkyrie and Goldwing. Excellent clutch action with no slippage on all 3 bikes. I bought a bunch of it last year when it was on sale for 4 bucks a quart. Regular price is around $5.50. Not bad price/performance for a full synthetic.
Offline grcamna2
« Reply #41 on: June 20, 2014, 03:52:52 PM »
CoachDoc,
Can you post a pic of the qt. bottles you're running in your bikes so when I go to Napa I make sure to see it ?  Thanks  :)
« Reply #42 on: June 20, 2014, 09:42:20 PM »
Been using that since my engine rebuild.   Good clutch and shifting performance.
KC
I'm thinking that's what this might be about?
Boy, do I miss Castrol XLR... that stuff was the wine that goes with the bread!
Offline ncstatecamp
« Reply #43 on: June 20, 2014, 10:19:01 PM »
Theres also castrol 4 motorcycle oil that I used, seemed pretty comparable to the Valvoline in price and usage, the only reason I switched was my local place switched...
http://static.pepboys.com/images/productImages/1461100/Castrol-4T-motorcycle-oil-1-liter-20W50.jpg
Offline CoachDoc
« Reply #44 on: June 22, 2014, 12:43:23 AM »
CoachDoc,
Here ya go!
Offline grcamna2
« Reply #45 on: June 22, 2014, 04:44:50 AM »
CoachD,
You're saying that Napa brand oil is Valvoline ?  8)
Offline CoachDoc
« Reply #46 on: June 22, 2014, 12:03:07 PM »
CoachD,
Not sure if all their oils are Valvoline, but yes this full synthetic 15W-50 definitely is. Ashland is I believe the company name.
Offline grcamna2
« Reply #47 on: June 22, 2014, 12:11:52 PM »
it says 'Ashland' (co. name) on the back label..,that's a key.
Offline dhall57
« Reply #48 on: June 22, 2014, 12:29:52 PM »
We deal with NAPA a lot at my work and yes all the NAPA brand oil is Valvoline.
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline ncstatecamp
« Reply #49 on: June 22, 2014, 08:52:26 PM »
And they have no friction modifiers or slick agents or any of that jazz?
