Author Topic: Pickled Carbs  (Read 707 times)
Offline jamesbekman
Pickled Carbs
« on: June 24, 2014, 08:30:28 AM »
I have a cb500 parts bike and just got to the carbs...  The outside carb bodies themselves are purty gunky and I wasnt sure if the internals would be junk or not...  I saw some hope when I pulled the carbs and saw a clean needle and piston.
I pulled the bowls and it was a beautiful sight.  These bowls and jets and emulsion tubes were fantastic.  I couldnt believe how the emulsion tubes looked, they were perfect, original jets etc too....  Im trying to figure out what they were all coated with, It smelled a little sweet, and had a tannish tarnish to the fuel bowls that went away with a little squirt of carb cleaner.  In one bowl at the bottom it was more of a blackish tan...  Ive never had the pleasure of cracking open an old carb that was so well preserved.  By any chance does anyone know off the top of their head what they could have been preserved with?
Im also going to switch to non-ethanaol gas as I had just cleaned up another rebuilt pair of cb500 carbs that were gunked up from the ethanaol and the bike not being run dry...  Although I heard the marine grade stabil fuel treatment works good.
Offline harisuluv
Re: Pickled Carbs
« Reply #1 on: June 24, 2014, 08:52:53 AM »
Not necessarily preserved with anything, just not abused for long periods of time.  Gas and water in the carbs ruins them over time.  Sounds like you had some gas in there but not long enough to do damage.
Offline jamesbekman
Re: Pickled Carbs
« Reply #2 on: June 24, 2014, 09:37:12 AM »
Well that would be gas without any ethanol in it...  Im just very surprised everything was perfect...  and I do mean perfect...
Offline fmctm1sw
Re: Pickled Carbs
« Reply #3 on: June 24, 2014, 11:24:07 AM »
Don't get used to it....   ;D
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
