Author Topic: BRAKE PAD ADVICE  (Read 723 times)
Offline GEARBOX
    • THE LOLA REGISTRY
BRAKE PAD ADVICE
« on: June 25, 2014, 04:50:21 PM »
Hi All,
           Looking for some advice on brake pads.  I'm rebuilding my 1978 CB750F from a 30 year hibernation and going through everything.  But I lost track on the newest developments in braking technology.  Is the a better brake pad out there that I should use?  Thanks Allan
Re: BRAKE PAD ADVICE
« Reply #1 on: June 25, 2014, 04:59:55 PM »
If you are still using the stock rotor, then the stock pads work fine.
AJK
« Reply #2 on: June 25, 2014, 05:10:36 PM »
I rebuilt my front brake caliper the other day and never quite liked the feel of it with the newer style pads (I beleive they were kevlar based).
 http://forums.sohc4.net/index.php?topic=61168.msg1567555#msg1567555
 While i had everything apart, i went through my old stash and found an original asbestos pad that had little wear (the lighter colour one on the left hand side of the picture), so i decided to clean it up with hot soapy water and fit it. I'd have to say that i like the feel of it a lot better. It seems more firmer and reassuring than the other ones i had in there. So i used the asbestos pad on the piston side and an original kevlar based one on the idle side simply because they both had the most meat on them.
 Not sure what other opinions of material type vs feel is on the forum.
Nic
« Reply #3 on: June 25, 2014, 05:20:09 PM »
I'm using DSS aftermarket ones on twin discs, they work well, leave black #$%* all over the discs and don't look like the ones you see on the site, no bevel unlike the pictures which look like old stock ones but they work.
http://www.davidsilverspares.co.uk/CB750K2-FOUR-1972/part_104849/
Offline RJ CB450
« Reply #4 on: June 26, 2014, 09:31:13 AM »
On my 82 I have EBS performance rotors with copper semi-sintered pads.  Combined with stainless lines, braking is powerful but very firm.  So lots of feedback through handle and tough to accidentally over grab.
74 CB450 K7 Supersport, 82 CB650sc Nighthawk, 1982 CBX 1000, 2015 Tiger XCx.... And some ol minibike with a 5hp Briggs.
« Reply #5 on: June 26, 2014, 10:01:59 AM »
The EBC FA12, or FA13 (kevlar) pads have always worked well for me.
Offline bjbuchanan
« Reply #6 on: June 26, 2014, 10:45:49 AM »
I use the FA12V, semi sintered version of the FA12. Can usually be had for a steal on amazon too
