Author Topic: Replacing nuts on front rotor  (Read 781 times)
Offline jamesv220820
« on: June 30, 2014, 10:34:38 PM »
1973 CB350f -
The manual and service bulletin says not to reuse the tongue washers when working on the rotor.
I can't find new tongue washers anywhere on the net.  So should I go against the bold text and just reuse my tongue washers?  Or should I switch to these so called UBS nuts?  If you guys think I should switch to the UBS nuts is that something I can find at a typical hardware store or is that something i'll have to get from the stealership?
cheers
-James
« Last Edit: July 01, 2014, 07:21:27 AM by jamesv220820 »
There is nothing to fear but fear itself . . . and trying to restore a cb350f
Offline Trad
Re: Replacing nuts on front rotor
« Reply #1 on: June 30, 2014, 10:55:36 PM »
I bought new ones at the dealer. They should be available. It's not like your rotor is going to fall out without them though.
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
Offline Muckinfuss
  • "I plan to live forever.....or die trying."
« Reply #2 on: July 01, 2014, 06:51:56 AM »
Drill and wire if you're really concerned.
1984 Sportster 1000cc XL
1988 Heritage Softail
1974 CB550
1989 Corvette
« Reply #3 on: July 01, 2014, 06:56:20 AM »
nylock nuts will work too.
« Reply #4 on: July 01, 2014, 07:23:15 AM »
So Steve-O if I go with the nylock nuts which torque setting should I follow?
-james
Offline Muckinfuss
« Reply #5 on: July 01, 2014, 07:27:27 AM »
Why not save yourself a headache and buy the UBS nuts that were used on the later serial number bikes?  The torque spec is right there on your bulletin.
1974 CB550
1989 Corvette
« Reply #6 on: July 01, 2014, 07:51:53 AM »
-james
Did nylocks the german way, gutntight :) and they hold find.  I would think the nylocks have the same or close the same torgue as normal nuts.
Offline wowbagger
  • Not much of an
« Reply #7 on: July 01, 2014, 07:57:59 AM »
I replaced one of my rotor nuts that was lost with a nylock....and promptly stripped it when trying to torque it. After cutting it off I replaced all of the nuts with tension lock nuts. They are one time only use but are pretty easy to come by and don't require the tongue washers.
Offline bjbuchanan
« Reply #8 on: July 01, 2014, 09:46:41 AM »
Just reuse the tongued washer. It only says that because eventually they will work harden and snap from removal. I bet it will still take more times than you will need to remove that rotor
« Reply #9 on: July 01, 2014, 06:45:44 PM »
-james
+1.
Online Don R
« Reply #10 on: July 01, 2014, 11:42:00 PM »
All the above.
