Author Topic: Scare tactics//Statistics//New Rider//  (Read 12730 times)
Offline trueblue
Re: Scare tactics//Statistics//New Rider//
« Reply #100 on: July 07, 2014, 05:27:34 AM »
Here is one of my OC issues:
I never fill up motorcycle at a pump stand where there is diesel fuel next to gas fuel hose.  The logic is I don't want to roll through the spill diesel even in slow speed.
A mate of mine dropped his bike in that sort of circumstance. He spotted someone he knew at a servo, he then pulled in to say g'day. There was diesel on the ground, when he put his foot down the bike went one way, his foot the other. He ended up laying on his bike, upside down, in a heap on the ground.
1979 CB650Z
Online grcamna2
« Reply #101 on: July 07, 2014, 05:31:41 AM »
That diesel sounds slipperier than a banana peel;so far I've never met up w/ any of it under my shoe.
Online grcamna2
« Reply #102 on: July 07, 2014, 05:36:49 AM »
How does diesel work for a holeshot,better than bleach ?   :D
Offline trueblue
« Reply #103 on: July 07, 2014, 05:44:33 AM »
To my mind, I wouldn't use it. May not get it all off as the tire compounds tend to absorb it as it's petroleum based, unlike bleach. Don't know for a fact, but since I have a diesel truck, I never park or service it near where my bikes are stored. It's pretty dang slippy stuff. And once on you, it permeates everything for a good, long while.
Tell me about it. I work on the stinking rotten smoking puss buckets for a living. All my work clothes stink of the #$%*. It takes a week away from work before my hands could be considered clean. For the most part it is a #$%* fuel but it serves a purpose.
1979 CB650Z
Online grcamna2
« Reply #104 on: July 07, 2014, 05:45:11 AM »
Gotcha
Offline Kevin D
  • SE Michigan
« Reply #105 on: July 07, 2014, 02:30:54 PM »
There is no such thing as a "fender bender" when riding a MC.
My coworker lost his life when he had a blowout at speed.
Another walks with a limp, his girl lost her left leg to a car that crossed the centerline.
Another limped in to retirement when he put his Beemer into a steel guard rail, riding aggressively.
Is it always the left leg?
I witnessed a remarkable near miss recently. I'm Following a couple of ladies yakking in the car in front of me, the driver turns her face to the right, distracted by the animated conversation, and starts drifting into the left turn lane. A sport biker, approaching from the opposite direction, turns his face to the right and also starts to drift into the left turn lane. They passed each other about a foot apart without ever seeing each other, probably heard each other, and then recovered their positions.
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
« Reply #106 on: July 07, 2014, 03:15:50 PM »
I wouldn't call that OC mate, very sensible, diesel is like riding on marbles, its without doubt the slipperiest substance i've ever ridden on, I'm just thankful it was at low speed.  :o
Offline trueblue
« Reply #107 on: July 08, 2014, 03:39:23 AM »
I've only found 4 great uses for it:
1 as a fuel source as intended,
2 cleans the carbon fouling out of shotguns and semi- actions like the bees knees,
3 use it to flush and rinse motor parts after sand blasting to remove media and grease,
4 keeps a burn pile going until the Fire Dept says "enough"  :)
I've thought about another but never tried it: spray some on an adulterous wife or young daughter. Nobody would come near her!
It is also useful for freeing rusted parts.  My father found an old hydraulic pump buried in the dirt under where a shed burnt down on his property nearly 30 years ago.  It was missing in the cleanup from the shed.  He soaked it in diesel for about 6 months.  When he pulled it out it was still stiff but no longer siezed, moved it to and fro a couple of times and it was free.  We then pulled it apart, cleaned it out and it was like new inside and even pumps oil ;D.
1979 CB650Z
« Reply #108 on: July 08, 2014, 03:51:04 AM »
And of course, the nut between handlebars and the seat makes for some trouble too.
This morning I took left turn I should not have with a pickup coming at me, all is well but it was a close one.
Online grcamna2
« Reply #109 on: July 08, 2014, 05:36:07 AM »
'Close calls' are no fun !
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #110 on: July 08, 2014, 06:15:37 AM »
I always have a problem with that one working loose!  ;D ;D ;D
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline greenjeans
  • 1972 CB750K2
« Reply #111 on: July 08, 2014, 03:00:21 PM »
Been riding some sort of cycle for almost 40 years now.   Somehow I've never heard or even thought about the don't fill up at the diesel pump.  When reading that statement, I initially thought it would end with:  those big 'ol diesel trucks won't see you and run you over at the pump...
You can learn things everyday.  Never took a safety course until I was 43 - had some fun and picked up a few new things and reinforced things I inately always did.
The advice I always give:  Ride as if you are invisible.
Offline trueblue
« Reply #112 on: July 09, 2014, 02:30:52 AM »
The one habit that has saved my arse more than anything else is to keep your head moving, if you start day dreaming and only focus on a spot 50' in front of the bike you won't see  that car up ahead turning across in front of you, or that car running the stop sign on your right, or a multitude of other different scenarios.  ;D
1979 CB650Z
Online grcamna2
« Reply #113 on: July 09, 2014, 07:36:25 AM »
I hear you,that gives me more of an 'I am in command of this' type of feeling.
Offline krusty
« Reply #114 on: July 09, 2014, 04:37:23 PM »
That's called scanning and planning.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Online grcamna2
« Reply #115 on: July 09, 2014, 04:45:35 PM »
it's necessary for survival out here.
« Reply #116 on: July 09, 2014, 04:49:15 PM »
I do that on auto pilot, just like putting on a seatbelt when driving the car, don't even think about it, it just happens... 8)
« Reply #117 on: July 09, 2014, 04:51:12 PM »
So to sum up and get back on point. After reading all of these, as a Newbie.........would you begin riding? ;D
« Reply #118 on: July 09, 2014, 04:53:54 PM »
Oh hell yeah.... ;D 8) ;)  {its easier than being married, and safer most of the time}   ;D
« Reply #119 on: July 09, 2014, 05:31:30 PM »
I would (cause I thought I was bulletproof) but I bet this thread would make a lot of newbies think twice...
Online grcamna2
« Reply #120 on: July 09, 2014, 05:45:32 PM »
Especially we need to 'count the cost' of inattention; cagers are doing it almost as an occupation,looking at a screen WHILE driving... THAT"S scary to me.
We as cyclists have the maneuverability to avoid them when they go astray,we can run rings around them if we need to.Develop some 'Street Smarts' and practice 'Escape Routes' continually !; be Vigilant and you Will stay on course for the duration  ;)  :)
« Last Edit: July 09, 2014, 05:47:16 PM by grcamna2 »
Offline billingstitan
« Reply #121 on: July 09, 2014, 09:19:08 PM »
"The reason I do it is because if you get it wrong, it’ll kill you.
If you think it’s too dangerous go home and cut your grass and leave us to it."
-Guy Martin, Isle of Man Champion
Calling upon my years of experience, I froze at the controls.  ~Stirling Moss
2014 Ducati Monster 796
1977 CB550K http://forums.sohc4.net/index.php?topic=138289.0
1977 CB550K
1972 CL175
2000 Kaw Nomad 1500
1992 KDX 200
2001 Honda 80R
Past Bikes:
1973 Kaw 900Z1
1970 Yamaha 350RD
2003 Yamaha VStar 1100
2001 Suzuki GS850
Online grcamna2
« Reply #122 on: July 09, 2014, 10:15:48 PM »
Yeah  ;D !
Offline trueblue
« Reply #123 on: July 10, 2014, 03:28:11 AM »
A cousin of a mate of mine was on a ride  this weekend gone, he was preparing to overtake a car so he was sitting slightly higher than normal but still well in his lane.  A car coming the other way (department of fisheries), towing a boat drifted over the centreline and cleaned him up with the guard of the trailer.  He is currently in hospital with a broken left leg, dislocated left knee, broken right foot and two broken toes. He is bloody lucky to be alive as they were both traveling at 100kph when they hit.
1979 CB650Z
Offline trueblue
« Reply #124 on: July 10, 2014, 03:29:15 AM »
#$%*ing oath mate, life's too short to not ;D
1979 CB650Z
