Author Topic: 78 cb750 wiring help on NH seacoast  (Read 8123 times)
Offline sethmcalister
Re: 78 cb750 wiring help on NH seacoast
« Reply #50 on: July 19, 2014, 06:27:06 PM »
Yes the switch assembly has been attached but I think I just had an epiphany. So if the handlebar is the ground, the fact that the handlebars are painted are probably the problem right?
Sent from my Nexus 5 using Tapatalk
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #51 on: July 19, 2014, 06:35:09 PM »
It very well could be. You can test continuity through the switch by connecting one lead to the light green, the other to the lower half of the switch housing. Push the button and check for continuity.
If the switch tests okay (I suspect it will, the switch is a pretty simple momentary contact switch) you will then either:
>Have to grind paint off the handlebars under the switch housing and under the handlebar clamp. Or....
>Run another ground wire from the switch housing to the frame or to a green/ground lead in the harness.
« Last Edit: July 19, 2014, 06:47:12 PM by madmtnmotors »
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #52 on: July 19, 2014, 11:08:17 PM »
Haha, sorry! I didn't know that the handlebars were the ground. And....so I didn't think that they were relevant. My sincerest apologies haha! If you stop by I'll be sure to buy you a beer or two.
« Reply #53 on: July 20, 2014, 03:44:29 PM »
If this turns out to be the issue, please do expect me to stop by Monday and smack you one  >:(
And once for me!  ;)
And one for me!  ;)
The start button is also grounded to the bars as well. If the start button works you must have gotten lucky and scraped enough paint on assembly to ground the right side controls.
TAMTF...
Wilbur
Projects:
« Reply #54 on: July 20, 2014, 04:40:32 PM »
Or he paints like he wires  ;)
Ouch!  :o
That almost counts as a smack!  ;D ;D ;D
TAMTF...
Wilbur
Projects:
« Reply #55 on: July 20, 2014, 05:57:41 PM »
Well I guess I deserve some smacks and owe some beers. Ground the paint off and horn works. The starter worked because the throttle didnt work so I had to sand that down for the throttle. I had no idea that the handlebar was the ground.
I'm really sorry for dragging you guys through my incompetence haha.
« Reply #56 on: July 20, 2014, 07:11:16 PM »
All part of the learning process. You know more now than you did before!  8)
TAMTF...
Wilbur
Projects:
« Reply #57 on: July 20, 2014, 07:15:24 PM »
That's a fact!
« Reply #58 on: July 20, 2014, 07:34:52 PM »
And we can all learn from the experience of others:
http://forums.sohc4.net/index.php?topic=139544.msg1579352#msg1579352
TAMTF...
Wilbur
Projects:
