Author Topic: RPM limits  (Read 8735 times)
Offline afkrejci90
RPM limits
« on: July 06, 2014, 12:46:49 PM »
I've been thinking about this for a while now.  The 78K has a redline of 9,500 or 10,000 rpm I believe.  Having a lightened and balanced crank to 14,000 rpm along with lighter valves, is the engine able to rev higher when all assembled?  Is there anything that would limit rpm's in the top end such as the rockers?
'78 CB750K http://forums.sohc4.net/index.php?topic=105327.0
'80 CB750C - Sold
'06 CBR600RR
Offline Old Scrambler
Re: RPM limits
« Reply #1 on: July 06, 2014, 05:22:37 PM »
YES..............the ROCKERS..............along with a few other things with long skirts (pistons), curls (springs), and odd-shaped weights (crank) that cause flex and stress the bearings. The cam-tower fasteners and bearing-caps need re-enforcement to hold lumpy cams...............and any amount of valve-float with a Hi-Po motor will usually grenade it.  That said, a lot of builders have gotten a lot of power and performance from these motors when ridden or driven to their limits ;D.......and not beyond :(   Quite a few riders have learned that the way to go faster is to up-shift ;D ;D ;D ;D ;D ;D
Run-ups to 12,000 rpms in lower gears are common..............but falling back to 10,000 -11,000 or so is typical in top gear.  I personally have hit those numbers and have never blown a motor in close to stock condition.   I see the carnage in the race-track pits...........and I'm about to find out for myself with a somewhat out-of-the ordinary build.  Let's see now................14,000 rpm in 5th-gear with an 18 x 38 sprocket combo will go HOW FAST???
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Bill/BentON Racing
    • BentON Racing
Re: RPM limits
« Reply #2 on: July 06, 2014, 05:30:42 PM »
Midget motors with no trans(cut off/plate added) would wind up to 14-16,000 rpms! K.  ;D Bill
BentON Racing Website
BentON Racing Facebook
Offline bear
  • Leeton in Australia
Re: RPM limits
« Reply #3 on: July 06, 2014, 05:51:48 PM »
I have learnt the hard way, that these motors do not like to have the crap reved out of them.
Their just not built for that.
In my opinion, there's more to be gained working with their strengths.
For their age, these motors can handle very high loads.
We chase hp through high cylinder pressure, cylinder volume, combined with coaxing as much flow as possible through the heads limited capability.
Brian
Re: RPM limits
« Reply #4 on: July 06, 2014, 06:07:47 PM »
Ok then, who's going to put their hand up and make us some roller rockers... ;D 8)
Re: RPM limits
« Reply #5 on: July 06, 2014, 06:59:33 PM »
The stock 78K redlines at 9K. I have reached that on mine a very few times and so far so good. I do not race so I don;t need to rev that high.   As Bear said, there is no advantage to overdoing it.
Offline Jim F
  • go baby go
Re: RPM limits
« Reply #6 on: July 07, 2014, 10:57:59 AM »
Brian
Hey Brian
what kind of CFM have you achieved with the heads?
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline bear
Re: RPM limits
« Reply #7 on: July 07, 2014, 06:03:57 PM »
G'day Jim,
Our heads usually test in the high 70's, not all of them have been flowed though.
Could never break through the 80cfm mark. >:(
Hopfully Uncle Johno may be able to help us with that later in the year with a bit of luck.
I think we probably need around 90cfm for these motors to reach their potential.
Their a little asthmatic at the moment.
Possibly one of your hair dryers could solve our problems.
But the powers to be won't let us run them.
Brian
« Last Edit: July 07, 2014, 06:32:45 PM by bear »
    • BentON Racing
Re: RPM limits
« Reply #8 on: July 07, 2014, 08:51:31 PM »
Very fortunate to have a friend like Mike Rieck, my (his) K head flows 79 @.400 lift, 82 @ .500....I know ,no .500 cams! Can't wait to install it! K.  ;D Soon!  8) Bill
Offline Doctor_D
Re: RPM limits
« Reply #9 on: July 09, 2014, 05:07:47 PM »
Even with a well prepped, hot-street motor, power starts to fall off pretty quickly after 9k.  Balanced, lightened, shot-peened, cryo-treated, etc., and etc. internals, and I've still set my limiter to 10.5k, and I could probably drop that to 10k and never know the difference.
Like Bear said, these motors don't need to scream to make power (paraphrasing).  Square bore to stroke on 836's means they make great torque over a broad and very usable rpm range.  And, really, when I did ping it off the limiter in 3rd (and promptly rolled off the throttle and trail-braked out of "lose your license" territory) - I hit 108mph.  Shoot, I hit 81mph  in 2nd - and didn't feel the limiter.  More than fast enough to merge with traffic on the highway.  What's 11k in 3rd, 112mph versus 108 at 10.5k?  My opinion is that when compared to up-shifting and getting back into the meat of the torque curve - the extra rmp's aren't the answer on these bikes.
Take care,
David
1978 CX500
1971 Norton Commando
Offline johno
Re: RPM limits
« Reply #10 on: July 12, 2014, 01:17:54 AM »
Hi D.
I use your bike as the benchmark in judging old honda's, its pure class mate.
I am curious though,  Have you ever given it a decent squirt in top gear ?
cheers johno
Offline Doctor_D
Re: RPM limits
« Reply #11 on: July 12, 2014, 03:42:57 PM »
Hi D.
cheers johno
Top gear?  No. I live in an urban area where there's little room for that sort of stuff.  Thought about bringing it out for track-days, but I'd cry if I laid her down.  Actually, crying's probably the least of it.
My top-speed recall has ticked 112 mph after a few seconds of drop-the-elbow, chin-on-the-tank foolishness.  But, the wind noise and the feeling that I'm going to blown off of the bike starts to get to me around triple-digit speeds - so I back down pretty quickly once I'm there.
Take care,
David
1978 CX500
Re: RPM limits
« Reply #12 on: July 12, 2014, 06:46:07 PM »
I think it depends gearing..,( with my old 836) I often run17/54 gearing..And shift without tach at 10,5 to 11 Ish.. Run a tach occasionally to see where I am at rpm wise.
.just another tool to enable lower gearing, with relatively. Same top speed..
 RC 315 Cam..  Stock head,  triple cut stock valves, 30 mm Webers..
Offline Greg H
  • When two cams is one too many .
  • Still crazy after all these years .
Re: RPM limits
« Reply #13 on: July 13, 2014, 01:08:06 AM »
When I used to race a 970 in the street class I used to change gear when it seemed like the right thing to do  ::). The regulations stated that a working speedo must be fitted so I fitted one off a moped  and dispensed with a tacho to save weight ::). Air shifters weren't allowed so we just power shifted , which wasn't good for the "box" but was good for the times . I remember one instance where I'd rigged up a tacho and then proceeded to miss a gear , when I looked down at the tacho the needle was coming down at 12 k  :o :o. Result ,one bent valve  :( We live and learn ::) .
Re: RPM limits
« Reply #14 on: July 13, 2014, 10:13:53 AM »
Dr. D.................I know a place where the rules encourage you to ride your bike as fast as it will possibly go ;D ;D ;D ;D ;D ;D ;D
YOUR INVITED ;)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
Offline Doctor_D
Re: RPM limits
« Reply #15 on: July 15, 2014, 09:13:19 PM »
YOUR INVITED ;)
You think I'm putting this bike on the salt?  :o Ummm... no.  :P
Take care,
David
1978 CX500
Offline johno
Re: RPM limits
« Reply #16 on: July 16, 2014, 03:41:37 AM »
+1  ;D    you look after our forum child D  ;) ;D
    • BentON Racing
Re: RPM limits
« Reply #17 on: July 16, 2014, 04:41:15 AM »
Haha, very smart D!  ;D Bill
Offline Doctor_D
Re: RPM limits
« Reply #18 on: July 17, 2014, 02:03:35 PM »
John, I love getting up to speed ludicrously quickly, and generally do.  However, restraint is generally the better part of maintaining one's health (not to mention driving privileges).  I've had a shoulder reconstructed as the result of a lay-down avoiding an apparently-sightless cager in 1991.  Did everything right.  Low-sided, got away from the bike, then I hit the curb... and, bam.  Shattered my collar-bone, and tore everything else to hell.  Getting back to the rugby pitch took two surgeries, six-months of fully dedicated rehab, and healing the way only young men can.  Continuing the full-on thread-jack/side-note; Though my Doc said contact sports were over for me, about nine-months later I hooked in the Div 3 national collegiate tourney.  And my knees... that could be a thread unto itself.
Tough as I am - I have, however, gotten a bit older in the interim.  Likewise, a bit more cautious and restrained.  Which is not to say that I'm not a fan of speed.  While never eyeing my CX500 for the 500cc pushrod twin LSR, I do believe the current SCTA Speed Week MPS PG 500cc record is just shy of 127mph. Not that I've given it any thought, but I figure I'd need to get that 48hp slug up to about 81hp at sea level to hit 130mph with a partially streamlined CX.  Again, not that I've given it a moments consideration, but the ratio of the ring and pinion on the shaft drive seems to be the most complicated bit of engineering involved.  ;D
« Last Edit: July 17, 2014, 02:11:10 PM by Doctor_D »
Take care,
David
1978 CX500
Offline johno
Re: RPM limits
« Reply #19 on: July 18, 2014, 03:39:29 AM »
Speaking vaguely of max RPM  ;) ;D
D the ol CX 500 seems to have a cult following in the US salt scene and also here in OZ.
Thos bloke was at the salt this year, I'll show you how he solved the gear ratio problem. ;)
Offline johno
Re: RPM limits
« Reply #20 on: July 18, 2014, 03:44:09 AM »
Hacksawed the back part of the frame off, cut the frame off an old 500 jawa track bike ( speedway) which is rigid and put a chain drive on so he could swap sprockets easily.
 nothing a 5 inch grinder and welder couldnt fix .
johno
Offline dusterdude
Re: RPM limits
« Reply #21 on: July 18, 2014, 04:12:01 AM »
Johno,wasnt that bike shaft drive?
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline johno
Re: RPM limits
« Reply #22 on: July 18, 2014, 04:28:31 AM »
Yeh , Was,   he converted it to chain drive,  8)  cheaper to swap sprockets than ring gears.
Re: RPM limits
« Reply #23 on: July 18, 2014, 07:04:23 AM »
 Crazy Australians. ;) ;) ;) ;D
Re: RPM limits
« Reply #24 on: July 18, 2014, 10:48:42 AM »
I've seen a couple of those bikes with high mileage. They seem to be a tough engine. I always thought they'd make a good endurance racer.
