I see that the manual advises installing crankshaft and internals into upper crank case.
I can see that it would make it easier to feed con rods through, but doesnt it make it more difficult to locate the gear selector fork?
I took apart by lifting upper cases from lower, as its easier to rest on bench and less risk of damaging cylinder studs
Any advice appreciated before I start reassembling. Thanks
