Author Topic: That pesky/elusive 550 petcock  (Read 10992 times)
Offline Jimray23
    • none
Re: That pesky/elusive 550 petcock
« Reply #50 on: April 04, 2017, 09:59:31 AM »
If urs broke easy, tjeres a good chancebit is junk. U might find a petcock with a bigger single outlet and put a reducing y on it, so u can still run 1/4" fuel line and not have to worry about supply.
Jimmy
1979 kz1000 ltd
« Reply #51 on: April 04, 2017, 02:16:18 PM »
1/4" is not the correct size fuel line...no offence intended but I question the advice you are giving on this thread.
« Reply #52 on: April 04, 2017, 04:00:34 PM »
Dont be a cheap ass, buy the correct part!  Available now...
http://www.ebay.com/itm/Honda-CB-550K-550F-550-F-K-CB550-NOS-petcock-1975-76-/232286277430?vxp=mtr
Yeah, this is getting silly.
I purchased the NOS one from this guy and have had ZERO issues with it since.
Offline Jimray23
    • none
« Reply #53 on: April 04, 2017, 04:48:03 PM »
What r u saying is the correct size fuel line
Jimmy
1979 kz1000 ltd
Offline Jimray23
    • none
« Reply #54 on: April 04, 2017, 06:25:18 PM »
Some of us would rather ride our bike than set around for months working on them. I have had my bike for about 5 years and all i have had to do to it is change tire, change oil and clean carbs. Although i got some bad fuel here lately and now have to clean the carbs again.
Jimmy
1979 kz1000 ltd
Offline wowbagger
  • Not much of an
« Reply #55 on: April 04, 2017, 06:44:04 PM »
OEM fuel line size is 5.5mm or 0.217 inches. 1/4 (0.25) inch hose is just large enough that leaks can occur. If you can't find 5.5mm hose, you can go with 3/16 but you'll need to heat the end up to soften it enough to get over the barb.
Offline Scott S
« Reply #56 on: April 05, 2017, 06:16:13 AM »
 Ditto. I've "lucked out" and had three tanks that needed this petcock. Just spend the $100 and be done with it.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Gene
  • Chat enuf you too can be a
« Reply #57 on: April 05, 2017, 11:07:58 AM »
Buy the good one or find used. I was lucky enough to find one that somebody had for $55.00 - that was a few years ago now.
Mine was leaky cuz the plastic "cone" had been roughed up. The sock filter and washers can be had from DSS.
*1973 CB750K3 (Bow)
Offline Scott S
'71 CB500 K0
'81 Yamaha XS650
