Author Topic: Optical ignition system from Cycle Exchange  (Read 8926 times)
Offline arncruz
  • 1977 cb550
« on: July 17, 2014, 02:14:51 PM »
Has anyone used the optical ignition system for  a CB550F from Cycle Exchange?  I'm contemplating this system over the stock system.  It's expensive though $350 so I wanted to get some opinions.
Thanks
My Stable
1969 CB750 #6xx
1969 CB750 #20xx
1969 CB750 #27xx
1969 CB750 #43xx survivor
1969 CB750 #12xxx
1970 CB750 K0 survivor
2014 MVP Agusta 675 F3
Offline goldarrow
  • one day, i'll be an
Re: Optical ignition system from Cycle Exchange
« Reply #1 on: July 17, 2014, 06:05:18 PM »
I only know that a member here ran CycleX power arc and it failed during GZ ride back in April, I read that customer service was great.   Don't know if it was free replacement though.
CB550 K0
Offline gto_ron
« Reply #2 on: July 17, 2014, 06:57:59 PM »
I have it on my 750K6 and can recommend the system as a good investment and worth every penny.
best regards
76 CB750K
72 CB350F
64 GTO
why yes, I am old-school, so what?
These are the good old days.
Offline arncruz
  • 1977 cb550
« Reply #3 on: July 17, 2014, 09:54:18 PM »
Thanks guys.  I compared the optical ignition system and the dyna 2000.  I'm not so good with anything electric so I don't know if the two systems are equal replacements for the original system.  I included the pictures of the two systems.  If the systems are equal replacements for the original one, the optical one appears to be the cheaper route.  But it seems like the dyna 2000 system is more popular. Any thoughts on this.
My Stable
1969 CB750 #6xx
1969 CB750 #20xx
1969 CB750 #27xx
1969 CB750 #12xxx
« Reply #4 on: July 17, 2014, 10:12:26 PM »
What other mods are you planning? The ignition systems you are looking at are expensive, and may not give any greater performance than cheaper electronic ignitions.
Offline arncruz
  • 1977 cb550
« Reply #5 on: July 18, 2014, 06:33:19 AM »
Scottly,
I'm a noob at best and just want to make a reliable weekend rider.  The engine when I bought the bike was in bad shape.  Oil leaking after each ride.  Clattering coming from the engine.  Stalling when I stopped.  I have a sport bike that I just got a year ago but I love these older hondas and wanted a project bike I could make my own.  In addition to the ignition system, I plan on upgrading the carbs, wheels, and tires.  I'm keeping the same brakes with new pads, headers, .  Keeping the bike basically as is but a little lighter and make it more reliable.  I don't plan to take it to the track.  My budget is limited and I'm spending the biggest amount of it on the engine.
My Stable
1969 CB750 #6xx
1969 CB750 #20xx
1969 CB750 #27xx
1969 CB750 #12xxx
Offline bjbuchanan
« Reply #6 on: July 18, 2014, 08:20:46 AM »
Get yourself a Hondaman ignition box. This will reduce point wear to zero and never need readjusting because they basically become switches now. Only like 85$, great investment. I have one, as well as many other people and they are awesome.
Save your cash for other stuff. Most of the Electronic ignition is crap and the ones that aren't are very expensive for the minimal gain (I don't count modified engines, they are a whole diff animal). The advantage most people are paying for is not having to set their points after a couple thousand miles, not much work at all to begin with. Most of the 'improvements' people see from EI setups can usually be obtained from getting a quality set of points and gapping them properly.
You want a low buck hop up? Get the hondaman box, go on ebay and get a set of Andrews Coils, the orangey red ones that are 5 0hm and made for our hondas. They go used all day long for like 60-80$ and go fantastic, they are quality coils and come with replaceable wires.
http://forums.sohc4.net/index.php?topic=67543.0;nowap
http://www.sohc4shop.com/catalog/index.php
http://www.ebay.com/sch/i.html?_trksid=p2050601.m570.l1313.TR0.TRC0.H0.Xandrews+coils&_nkw=andrews+coils&_sacat=0&_from=R40
While you are ordering your hondaman box pick up the plug and play blade style fusebox too
« Reply #7 on: July 18, 2014, 08:39:28 AM »
I returned to points (TEC complete plate). Dyna S consumed too much power despite 5 ohms coils. Headlight on daytime. I use the Dyna coils with the points that made the bike to run much better since I got ign spot on, on all cylinders.
During my igntion session I fried a Pamco due to crappy Ultimate coils that broke direct. Very fragile ign wire post.
My experience and conclusion:
No reason for electronic unless you have a race bike and need different advance curves like Dyna 2000 offer. Black Dyna coils, TEC points is OK.
Hondaman module is hopefully waiting in my postbox when I arrive home after a holiday with my family.
My engine is midified with 836, ported head, Smoothbore carbs
« Last Edit: July 18, 2014, 01:17:45 PM by PeWe »
Offline arncruz
  • 1977 cb550
« Reply #8 on: July 18, 2014, 10:35:11 AM »
bjbuchanan and PeWe, Thanks so much for the comments.  I will probably go this route that you guys are recommending since it is cheaper and I'm not really going to take this bike racing any time soon.
My Stable
1969 CB750 #6xx
1969 CB750 #20xx
1969 CB750 #27xx
1969 CB750 #12xxx
Offline bjbuchanan
« Reply #9 on: July 18, 2014, 02:09:06 PM »
It's a solid proven setup you can use on almost all builds, you will be pleased
Offline arncruz
  • 1977 cb550
« Reply #10 on: July 18, 2014, 05:23:47 PM »
bjbuchanan,
Thanks for the advice!  You saved me probably a good $200. That money will go to cut-offs and tires.  Do you have any advice about carbs?  The ones that came with the bike are done and I don't think a rebuild kit would fix them either.  I want to get ones that are plug-and-play type of carbs.
My Stable
1969 CB750 #6xx
1969 CB750 #20xx
1969 CB750 #27xx
1969 CB750 #12xxx
AJK
« Reply #11 on: July 18, 2014, 05:25:01 PM »
I agree with BJ. If you are staying with a stock motor, just grab yourself a hondaman box or a pamco unit. The hondaman box will draw milli-amps through the points instead of amps, so your points will probably never wear out or pit. But yet at the same time, your spark will be beefed up due to the transistorised electronics in the box, with no adverse affects on your electrical system. Easier starting and improved economy.
Offline arncruz
  • 1977 cb550
« Reply #12 on: July 18, 2014, 05:43:20 PM »
Before I get the hondaman box do u guys recommend replacing the old points and condensers?
My Stable
1969 CB750 #6xx
1969 CB750 #20xx
1969 CB750 #27xx
1969 CB750 #12xxx
Offline Tews19
  • I am no
« Reply #13 on: July 18, 2014, 06:54:01 PM »
Snap a pic of your carbs. Carbs hardly ever become " to gone" to fix/repair/ clean. The rubbers will go but everything else should be salvageable.
1970 Honda CB750 survivor.
« Reply #14 on: July 18, 2014, 09:17:15 PM »
ive never liked optical triggers,they never have been commonly used from car manufacturers,the lucas "opus"system comes to mind though which quickly got nicknamed "hope less".
Offline arncruz
  • 1977 cb550
« Reply #15 on: July 18, 2014, 09:36:48 PM »
calj737,
What does he charge for this service - rebuild and set up carbs?
My Stable
1969 CB750 #6xx
1969 CB750 #20xx
1969 CB750 #27xx
1969 CB750 #12xxx
Offline flatlander
« Reply #16 on: July 19, 2014, 01:46:01 AM »
calj737 and dave500:
do you know what advance curve(s) the boyer has, when the rev limiter kicks in and  how much current it uses?
compared to dyna2000 and powerarc i seem to have a hard time finding technical info for the boyer (apart from marketing blurb) but might be looking in the wrong places...
  • I'm back
« Reply #17 on: July 19, 2014, 01:54:25 AM »
Fresh points and condensers whether buying HM ignition or not.
For a transistor ignition module like Hondamans you don't need fresh points as long as they are mechanically sound. Condensors you don't need at all if you go transistorized ignition, but you can keep them there (dis)connected in the event you would have to switch back to conventional Ketter.
« Reply #18 on: July 19, 2014, 02:42:53 AM »
forget about a tailored curve,or what curve it has,people read too much into that and it doesn't really apply to our old Hondas, it mostly applies to a slower revving longer stroke old school street driven V8 automobile engine which will benefit from such finesse,the boyer units have no rev limiter?i think the boyers are one of the lesser current hungry units?,im surprised their not used as much as the common failing dynas?i guess being English they get associated with lucas rubbish?
Offline flatlander
« Reply #19 on: July 19, 2014, 04:46:46 AM »
well i like low tech if it works. no rev limiter is better than one that's set somewhere where you don't want it. and as to the advance curve you're right, but would still be nice to know from when on it's on full advance as that's pretty much the only thing that matters for these hondas.
whatever it does: i gather your happy with yours, dave? hardly anyone here seems to be using them which is enough to make me curious ;)
« Reply #20 on: July 19, 2014, 05:06:05 AM »
we don't use the word "curious"here much,for reasons I don't have time to explain,i don't know why not many more use boyer ignitions and I care less for the answer,if the ignition advance system of any engine was more considered an ignition retard system used for starting the engine and less thought was given to trying to be precise with the first few thousand rpm range of its use in advancing the ignition timing there might be a lot less #$%*ing about with #$%* that doesent really matter?you dig?= do you understand?
« Last Edit: July 19, 2014, 05:07:38 AM by dave500 »
Offline Bailgang
  • Scott
  • Indiana
« Reply #21 on: July 19, 2014, 05:47:37 AM »
My guess is price is the reason you don't see too many using them because the Boyers are a bit more expensive than say a basic dyna, pamco or accent system. I haven't heard anyone say anything bad about the Boyers system though at least not yet.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline KayOne
« Reply #22 on: July 19, 2014, 09:21:35 AM »
I run them on my SOHC 750 and my DOHC 750. Completely satisfied with their performance and cost.
CB750 K1 restored
1979 CB750Fz - original except for exhaust, 14000km
1984 VF45F Interceptor - all original, 12000 km
1968 S90 - all original, 2100 miles
1973 H2a, Restored
1973 H1D, next project
CB750K1 (sold)
1976 KZ900 (sold)
1981 CB900F (under restoration)
2015 Yamaha FJ09, my appliance rider
  • I'm back
« Reply #23 on: July 19, 2014, 10:29:26 AM »
You hit the nail spot on, Dave. I remember this bloke that had this sticker on the rear fender of his Bonnie saying: All parts falling of this bike are of the finest British chraftmanship.  ;D And in all honesty I find them bloody expensive too. That's why I built my own transistor module years ago and... my points will celebrate their 60.000 km anniversary soon!
Offline bjbuchanan
« Reply #24 on: July 19, 2014, 10:47:26 AM »
The advance curve is supposed to hit all in on these bikes at 2500-2800 rpm, dictated by the weights and springs. Slap a 10$ timing light on it and determine where it hits. If it hits after that window, clip the spring just a little and tighten the curve down. You can do one spring at a time to really fine tune it.
Like Dave said, the programmable curves offer little to no advantage other than you being able to say you programmed your ignition curve.
I'm big in to retrofitting and modifying stuff like DIY electronic ignition on cars, EFI using megasquirt, fabbing stuff up but I really can't see the justification on these bikes. The bang for the buck is just not there. The biggest gains are by getting these bikes running properly, so many bikes have all this stuff added on top because they couldn't get it running right to begin with.
