Author Topic: CR 750 Style Triple Clamp  (Read 4478 times)
Re: CR 750 Style Triple Clamp
« Reply #25 on: August 06, 2014, 01:40:45 AM »
Looks good... ;)
Offline kmb69
« Reply #26 on: August 06, 2014, 06:54:04 AM »
+1 Looking real nice!
« Reply #27 on: August 06, 2014, 07:35:26 AM »
You did that on a manual machine?  ?cant see it.
« Reply #28 on: August 06, 2014, 09:46:54 AM »
Nice machining work!
Offline Dreamer
« Reply #29 on: August 06, 2014, 12:18:56 PM »
Thanks guys!
I machined it on a Haas VF2 CNC.
Right now just the bottom side is a 5hr cut but I should be able to speed things up once I start to fine tune the tool path. I want the part to look cast so I need the step over on the tool path to be as fine as possible.
This is why it takes so long to machine. I'm hoping that a good sand blasting or shot peen will take care or the really fine tool marks.
1957 Manx, 1958 Dominator,1963 Atlas and 1975 CB 750
If the passion is there, the knowledge will fallow.
Me
No matter where you are, there you are.
Buckaroo Bonsai
Offline greenjeans
  • 1972 CB750K2
« Reply #30 on: August 06, 2014, 06:39:18 PM »
Well, you've captured my interest.   What specs did you end up going with and have you figured out what you'd charge for it?
Offline Dreamer
« Reply #31 on: August 06, 2014, 06:53:29 PM »
I went with the stock offset of 60mm for this first one.
I plan in doing a version for the GL conversion. I just got set of clamps from eBay to get the offset from.
I'm still trying to figure out a price. I want people to be able to afford them. Once I've complete one, I should have a better idea of what it cost me to make.
Me
Buckaroo Bonsai
« Reply #32 on: August 06, 2014, 08:55:14 PM »
Looks like if you get it down to 1.5-2 hrs, they should be affordable..and sell well.
 My buddy used to get single sided arms built out of several blocks of billet. First they had to add computer capacity to the mill. Run time was over 40 hours, they got it down to 32 ish, i think..for one swingarm.. Lot of runtime.
 Good luck with them,maybe you can have a Christmas TREE sale..heh..heh..
