Author Topic: master sticking after rebuild  (Read 562 times)
Offline 78whiteorbs
« on: July 21, 2014, 04:49:16 PM »
Rebuilt a master and the action was fine. I have not filled it with fluid yet because the other day I went and mashed the lever in it was very slow to retract like its sticking.  Is this because it is "dry" or something else? Most old masters devoid of fluid still spring back just fine but then again they still do have some residual fluid in the bore lubing things up I would imagine....thoughts welcomed fellas~
Offline dhall57
Re: master sticking after rebuild
« Reply #1 on: July 21, 2014, 05:29:23 PM »
Ive never pulled in lever after rebuilding m/c's until Im ready to bleed brakes and reservoir is full of fluid. Did you clean the inner cylinder and lube it with fluid before installing new internal parts, and I also throw some b/fluid on the parts when installing also just to make sure everything is good and slick.
« Last Edit: July 21, 2014, 05:31:56 PM by dhall57 »
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline bjbuchanan
« Reply #2 on: July 21, 2014, 05:54:31 PM »
I have had it stick a little before I started using brake lube. Couldn't resist playing with it
Offline 78whiteorbs
« Reply #3 on: July 22, 2014, 09:30:35 AM »
Thought about this and though I did polish the bore out with steel wool and a drill and lightly lubed ,I am thinking no lubrication with fresh rubber is the culprit. Gonna lube her up and give it a go with the fill and bleed. Guess I just got ahead of myself.
« Reply #4 on: July 22, 2014, 10:00:23 AM »
If you assemble with brake parts assembly lube like you are supposed to, you won't have a dry sticking problem, or risk damaging brand new rubber components while trying to operate it dry.
