Author Topic: Oil Light then -clackclackclack- then Dead! (help please)  (Read 9803 times)
Offline Nik-bot
  • '78 CB550K; '06 Bonnie
« on: July 22, 2014, 06:37:02 PM »
Hello All.  This is my first post to the tech forums.  So far, I’ve gotten by reading old threads but now, after pushing my bike 1.5 miles home, I have to ask for help.
The bike is a ’78 CB550K, recently acquired (325miles /3 months ago)
Was riding home in a traffic jam (crawling) and the oil light came on and stayed on. I’d come to not trust the oil pressure light (see below) so I continued. After a few minutes, a ‘clackclackclack’ sound started and I pulled over.  The engine died on its own before I was off the road.  Oil level is fine, but smoke of burning oil poured out when I removed the cap to check. It seemed that the kickstart would not rotate the engine.
While pushing it home, I let some good Samaritans talk me into push start.  It started, but the clackclackclack noise convinced me to shut it down after 10 seconds and continue pushing towards home.
Some of the problems I’ve faced over the few months of ownership may or may not be relevant:
•   Oil light always comes on at idle, only after the engine is nice and hot – usually about 8 miles into a ride. It flickers or stays on and I blip the throttle to ensure it turns off at higher RPM. I came to understand here that this is not serious and I’d gotten used to it.
•   Recently during a ride in the foothills my oil light came on and stayed on. I pulled over and had the bike towed home. Changed the Oil Pressure Switch and all was back to normal. This was about 50 miles ago.
•   I have the wrong oil weight. I’d filled it with 10W-40 (per marking on filler cap) when I got the bike but found later should take 20W-50. I was supposed to make the switch this weekend…
SO… What have I done to my bike and what can I do to fix it?  I’m really worried here.
Dominique
PS: Perhaps this is obvious, but I have little experience with mechanics, etc. – all I know about motorcycle repair is what I’ve learned from Clymer’s and the internet in the last few months. You might need to “talk dumb” to me.
Offline billingstitan
Re: Oil Light then -clackclackclack- then Dead! (help please)
« Reply #1 on: July 22, 2014, 08:16:10 PM »
Based on hard-won experience - NEVER ignore an oil light. It's never nothing to worry about unless you know EXACTLY why it's illuminating. Even then, get it fixed and operating correctly as soon as possible. Oil is the lifeblood of an engine - one mistake and it's curtains  :-\.
Calj737's advice is spot on - drain your oil and drop your oil pan. My guess is you're going to see some glitter in your oil pan - I hope not - but from the initial description is sounds like your bike got starved of oil and the motor seized. That is, the internals were not sufficiently lubricated and locked up.
The 10w-40 isn't going to cause a catastrophic failure like that - it's not the optimum choice, but it's not THAT far off ... issues from a difference in oil viscosity between 10w-40 and 20w-50 wouldn't show up for thousands of miles, rather than 300.
From the description, it sounds like you've suffered some serious damage to the motor. I'm sorry about that  :-X
You can often find these newer 550k engines for under $500 on ebay - just make sure it's a solid seller with a good track record. They are not difficult to swap with some basic tools - a day or two tops. Just be gentle and avoid overtightening bolts. Unfortunately, depending on the damage, it may be your least expensive alternative.
But pull your oil pan and take a look - snap some pictures and post them up here. There are a lot of fellas on here that know a hella lot more than I do about these 'ol heartbreakers.
Calling upon my years of experience, I froze at the controls.  ~Stirling Moss
2014 Ducati Monster 796
1977 CB550K http://forums.sohc4.net/index.php?topic=138289.0
1977 CB550K
1972 CL175
2000 Kaw Nomad 1500
1992 KDX 200
2001 Honda 80R
Past Bikes:
1973 Kaw 900Z1
1970 Yamaha 350RD
2003 Yamaha VStar 1100
2001 Suzuki GS850
Offline Parkwood60
    • Pilez & Driverz
« Reply #2 on: July 22, 2014, 09:05:29 PM »
Sounds like you either spun a rod bearing, or seriously starved the top end for oil and seized the cam. I mostly have experience with the 750s, but its all the same, in theory. If your light was coming on at idle that typically means either the pump is too weak, or the clearances are too worn to maintain the proper pressure at low RPM. At higher RPM the pump delivers more volume no matter what, so it makes up for the less efficient pumping of a worn pump, or the leaking pressure of worn bearings.
Either way, the motor is likely toast. It can be fixed, but seeing as you are in California, you can most likely find a perfectly good motor for the same price.
Offline trueblue
« Reply #3 on: July 23, 2014, 02:47:32 AM »
By the sounds of things she be #$%*ed.  You have obviously lost oil pressure and have had an issue for some time.  As has been said before NEVER ignore an oil light.  It is your first warning, your second warning is the clack clack noise of the fuctus engine.  If you have heard the clack clack, something is damaged and the engine needs to be pulled down to repair.  The oil viscosity isn't the problem, more the lack of oil in the correct place.
1979 CB650Z
    • http://forums.sohc4.net/index.php?PHPSESSID=qbkek00iip1tff5p960uf28qu4&/topic,60973.0.html
« Reply #4 on: July 23, 2014, 05:34:26 AM »
you have a dead engine...is the bike worth the rebuild??????or is it scrap or can some parts be used vith a doner bike as new start..or drop the honda sohc dream..you have some to think abaut..now you have learned not to inorrore the oil light...the hard vay
Offline thirsty 1
« Reply #5 on: July 23, 2014, 05:54:28 AM »
Sorry to hear of your troubles Nik-bot. Remove you oil filter and take a look at it. All of the oil flows through it and catches all the bad stuff. It is a filter after all lol. It doesn't sound good from your description and you'll find everything you need to see in your filter.
Offline thirsty 1
« Reply #6 on: July 23, 2014, 09:51:29 AM »
Not necessarily. Large particles will be too heavy/large to be sucked into the filter past the oil screen pick-up in the pan. Yes, you might find metallic flakes there, but that's not conclusive. Better to drain the pan, fully expecting to drop the pan.
Pulling the filter is fine, but thinking that it is a determining factor is a "short cut". The pan is coming off, and probably the rocker cover too ultimately. Clack-clack-clack is 90% a dead engine. Brace for it. If by some miracle, you remove the pan, and don't see large bits of bearings or piston chunks, then you might get away with a rocker cover removal and some cam/top end repairs.
To each his own but its a lot easier to remove the filter then the pan. If theres metal in the filter the engine needs to come apart and be repaired.  I'd start at the filter and then the pan. He's been riding around with the oil light on so the damage has been done.
Offline Nik-bot
« Reply #7 on: July 23, 2014, 10:30:15 PM »
THANK YOU, everyone, for the helpful replies.  Perhaps even more, thanks for not ripping me apart for being so reckless and stupid.
I drained the oil and removed the pan and filter.  After running a magnet through the oil and along the pan bottom, I do see a small amount of metal filings. I actually allowed myself some hope when I saw how clean it looked, but I don't really know what to expect, so please take a look at the two pics and tell me if this is what you expected to see.
You all are awesome.
« Reply #8 on: July 23, 2014, 11:01:23 PM »
When's the funeral?
Offline trueblue
« Reply #9 on: July 24, 2014, 01:38:58 AM »
Remember there is a large percentage of non-ferrous metal in your engine, i.e. it won't stick to a magnet.  Going from those pictures it doesn't look good.  I'm not 100% certain, but I think you can see a couple of rods by looking up from the pan (been a while since I looked), you may be able to poke a screwdriver up in there and see if there is any movement.  If there is any noticable movement, you have an issue.  The other thing to do is lift the cam cover off and see if anything is chewed up in there.
1979 CB650Z
Offline lrutt
« Reply #10 on: July 24, 2014, 06:29:57 AM »
you get a ferrous cam running in non-ferrous head material. its the AL that will end up in the pan mostly, not the cam material. Somewhat the same on the crank end. Stop and go is tough on these motors anyhow, and with thinner oil like that so so.
Not as much fuz as I would have expected to see but you won't know till you pop the valve cover and fully pull the pan.
As stated above, never ignore your lights. Kind of like the boy who cried wolf. you might get faked a couple times but it only takes once. An oil pressure gauge is cheap insurance and easy to install. I've had them on both my SOHC's.
Offline thirsty 1
« Reply #11 on: July 24, 2014, 06:47:35 AM »
Hmmmm that looks no bueno  ???  Calj737 is on point. If you have vise and the old filter you can cut the pleats out of the filter and squeeze the oil out of it. Take some pics of the filter and post them. It'll be all glittery. Unfortunately something has rubbed metal to metal and you have issues. If your not comfortable taking a engine apart you might want to find a local mechanic.
Offline Nik-bot
« Reply #12 on: July 24, 2014, 10:23:39 PM »
OK, so I took some pics from the bottom. Those are attached here. Do they tell us something?
I removed the breather cover, tach cable, and every top bolt i could find but the cam cover doesn't seem to want to budge.  I gave it a few half-hearted whacks with a rubber mallet but no luck. Is there a trick to removing it?
Offline goldarrow
  • one day, i'll be an
« Reply #13 on: July 24, 2014, 10:28:22 PM »
Whack and jiggle and wiggle and pull up.
CB550 K0
« Reply #14 on: July 24, 2014, 10:39:36 PM »
I don't see that much metal stuck to the magnet, and a fair amount of that is probably from the trans from normal wear.
Offline lrutt
« Reply #15 on: July 25, 2014, 05:59:46 AM »
I'd like to see what was in the BOTTOM of the oil pan as well.
« Reply #16 on: July 25, 2014, 07:21:52 AM »
Subscribed.
« Reply #17 on: July 25, 2014, 07:27:58 AM »
Subscribed.
Everyone rubbernecks at the roadside crash victims... Just human nature
LOL!  I have nothing to contribute, never touched 550 in my life, but I am always curious.
« Reply #18 on: July 25, 2014, 07:47:38 AM »
I prefer to offer knowledge or opinion only on things I already busted my knuckles on.
Offline Nik-bot
« Reply #19 on: July 25, 2014, 09:57:46 AM »
Here's a pic of the bottom of the pan. In the upper-left, near where the drain plug is sitting, is where I poured the oil from the pan - that's the loose detritus.   The gunk in the middle of the pan seems to have been there for a while (I have to scrape it up).
« Reply #20 on: July 25, 2014, 09:59:26 AM »
That does not look bad, did you pull the valve cover?
Offline Nik-bot
« Reply #21 on: July 25, 2014, 10:08:09 AM »
Under the breather cover, there should be some more bolts, and the end caps have to come off...
...I'd like to see the rod caps? Any chance you can grab some pics in between those? And especially of your top end as you remove the cover
Ah, I'd not removed the screws under the breather cover.  I will do that tonight after work and report!
I had to ask google what the rod caps are  :) . I will get pics of those and the entire top end and come back.
Thanks to everyone for the helpful contributions!
« Reply #22 on: July 25, 2014, 11:00:56 AM »
Just for reference ... this is what an oil pan looks like when you've spun a bearing. There's no mistaking a catastrophic failure.
1977 CB550K
1972 CL175
2000 Kaw Nomad 1500
1992 KDX 200
2001 Honda 80R
Past Bikes:
1973 Kaw 900Z1
1970 Yamaha 350RD
2001 Suzuki GS850
Offline lrutt
« Reply #23 on: July 25, 2014, 12:16:47 PM »
Yea, that pan doesn't look bad at all.
I'm starting to guess a loose jam nut on a valve and that what might have been clattering. Pull those valve caps and just check for an uber loose rocker first.
« Reply #24 on: July 25, 2014, 12:27:09 PM »
I was just thinking the same thing: one time my 750 suddenly started clacking. One of the valve adjusters broke off above the rocker, allowing the remaining part that contacted the end of the valve stem to unscrew.
