Author Topic: wont startup  (Read 1031 times)
Offline danarchy77550f
wont startup
« on: July 23, 2014, 07:38:46 AM »
Hi Guys,
 Recently finished a rebuild on my 77 CB550F after having my primary chain fail.  I had to replace the upper case because of damage so i had to rebuild it from the pretty much every bolt.
Its buttoned up now but im having trouble firing it up.  It will back fire every once in awhile
I have spark
new gas
cleaned out floats and jets
electronic ignition ( existing )
I adjusted the valves after i noticed gas shooting out of carbs
.002 intake .003 exhaust
im going to check compression after work
i static timed it and it checks out
starter is working
battery is at full charge each attempt
carbs are sucking in and exhaust is pushing air out
im at a loss as to what else could be wrong, please help!
Re: wont startup
« Reply #1 on: July 23, 2014, 08:57:57 AM »
i never touched the coils so they should be fine, and i know the ignition leads to a blue and a yellow wire, i will try switching them up because they were backwards on my friends 750
Offline goldarrow
  • one day, i'll be an
Re: wont startup
« Reply #2 on: July 23, 2014, 10:03:00 AM »
you indicated it back fired, by anychance you have the advancer cam flipped 180 degrees out?
CB550 K0
Re: wont startup
« Reply #3 on: July 23, 2014, 10:18:44 AM »
is that the center black part?
Re: wont startup
« Reply #4 on: July 23, 2014, 10:21:19 AM »
Good plan to check compression.
Did you heed the warning in the shop manual about fitting the cylinder cover back on without bending valve stems?
If there are still no bent valves...
The mechanical spark advance mechanism can be assembled backwards, which would make spark timing 180 out of phase.
I'll ask how you connected the spark leads.  One coil connects to 1&4 the other to 2&3.  It's not a left side/right connection scheme.
Offline goldarrow
Re: wont startup
« Reply #5 on: July 23, 2014, 10:24:54 AM »
yes.
also you mentioned electronics ignition, is this Dyna S, they are famously know to have switched blue and yellow wires around.  few things to check but all are easy to do
CB550 K0
Re: wont startup
« Reply #6 on: July 23, 2014, 10:27:46 AM »
The valves shouldnt be bent, they are on dead center.
the bike was running for two years on the ignition so it shouldnt be backwards but i will double check
the coils are running to the correct cylinders
