Author Topic: CB650SC CUSTOM, my first motorcycle/build  (Read 5786 times)
Offline methebmxer
« on: July 23, 2014, 01:18:33 PM »
Some time around a year ago it dawned on me that I'd always admired motorcycles and yet never owned one. My riding experience consists of crashing my friends pit bike when I was five, trashing mopeds around in the woods as a teen and getting a couple of rides on the back of friends bikes as an adult. I realised things had to change and getting a motorcycle would also be a great opportunity to learn more about them and have another project, win win!. So shortly after letting a friend know of my interest he told me of a bike going for free and I snapped it up.
Here it is as in all its purple and yellow glory
It's a 1982 CB650SC CUSTOM
It must have been rebuilt to some extent in the last ten years roughly as its been fully resprayed. it's a bit tatty but not much rust and mostly intact other than a missing tank. The loom is chopped but I can work with it and the engine looks brush painted really badly so needs a lot of cleaning although I'm hoping doesn't require a full rebuild.
As I'm new here I'll include this one of me rolling her home
Re: CB650SC CUSTOM, my first motorcycle/build
« Reply #1 on: July 23, 2014, 01:37:29 PM »
The good news is that it's close to being "all there" but has some of the ugly stripped from custom model.  There are some huge "pros" to the 650.  The primary one being the motor (more power and better porting) and another being the upgraded brakes from the 550 (mounted behind the fork).  Another good thing is that 650s are less collectible than 550s so used parts are fairly plentiful and not overpriced (except for the engine cam).  A huge plus with the motor is installing a big bore kit, which will ending up yielding you power comparable to a 750 in a much lighter (80 lbs plus) package.  This translates to a more nimble and faster bike.
If you goal is to get the bike rideable ASAP, you may wish to delay any big bore kit for now and just get the bike running and stopping.  Ah yes, you will need brake calipers for that!  I would consult a salvage yard or ebay.  While your at it, buy yourself a petrol tank and get rid of that hideous yellow!!
Offline methebmxer
« Reply #2 on: July 23, 2014, 01:41:44 PM »
big bore kit has got me listening I must admit! although I didn't plan on an engine rebuild if it's not necessary to keep cost down. I have the brake and callipers are just about visible draped over the light in the second shot (due to being a bit seized).
The yellow is going for sure! haha
Offline methebmxer
« Reply #3 on: July 23, 2014, 01:48:43 PM »
The colour isn't to my taste so a full rebuild is in order. I also know the best way to learn is to do it myself and I'm confident with mechanics due to being a full time bicycle mechanic and having worked on cars.
Once I got it home I stripped it down to a rolling chassis and started to get to know the bike
Offline cb650
« Reply #4 on: July 23, 2014, 02:45:08 PM »
Hello.  cant beat free.  What you have is a luxury custom.  Here in the states its known as a nitehawk.  One year only and  is very hard to find body parts for.  The engine is supposed to be a factory black wrinkle finish.  I would get it running and see if its worth doing anything with.
« Reply #5 on: July 23, 2014, 03:06:42 PM »
The great outdoors workspace!  I wouldn't waste your time trying to restore this bike to its stock glory.  I'd focus on making a reliable runner cafe, brat, scrambler or tracker.  Keep the weight and the ugly off of it.
Is the motor seized or free?  That may dictate whether you are just trying to get it running or doing a full engine rebuild.
650: Did the 82 come with dual front discs?  What is the diameter of the 650 fork tubes (35mm or 37mm)?
Offline methebmxer
« Reply #6 on: July 23, 2014, 03:28:35 PM »
I only have a shed to work in so stripped it outside before moving in to the shed as I had no lighting in the shed then. Now I have a fairly good space to work with good light but a little cramped, it'll do.
I don't think I'd go restore as it would be too expensive and I like the idea of having some creative freedom with it. I have a rough idea of what look I like and what fits with the bike but I think it's going to evolve as I work on it rather than set out with a final plan. Weight and ugly are definitely not welcome here though.
As far as I know the engine is not seized but I could do with confirming that as I've not seen it run and it was sat for up to a year before I got it. I have pulled the engine out though so not sure how I can check it's not seized.
It does have dual discs and the fork tubes are 37mm. I've looked in to changing the top yoke as it uses a two piece handlebar system but I'd prefer to fit a scrambler style I think. It seems I may be able to use some gold wing yokes? but Im unsure of compatibility of the steerer/stem length etc. Any pointers welcome.
« Reply #7 on: July 23, 2014, 03:54:08 PM »
I suspected that the fork tubes were 37mm.  That is the correct diameter for a GL front end, but I'm not certain whether the distance between the fork tubes is the same between the two models.  The GL fork tubes are longer than a CB750, and therefore much longer than a CB550, but I am not sure about the stock length for a CB650.  Perhaps member 650 can chime in.
Offline cb650
« Reply #8 on: July 23, 2014, 05:35:46 PM »
81 custom and 82 nitehawk/lux cust  did have dual disks.  Although not the same.  in 82 they went with dual piston calipers and the bigger tubes..   Not sure how long the tubes are.  Both mine are together.
Offline methebmxer
« Reply #9 on: July 24, 2014, 12:12:41 AM »
Once I pull the fork apart I'll do some measuring and go from there.
I have the dual piston callipers but the master cylinder has been replaced for one that comes on a Yamaha XS1100.
Offline cb650
« Reply #10 on: July 24, 2014, 03:01:20 AM »
Did they seem to work?   The 1100 had dual disks so it should.  Did it have a break switch on it?   can u post a pic?  Ok no more ?s     I'm looking to replace mine and dont like the stock plastic one.
Offline methebmxer
« Reply #11 on: July 24, 2014, 03:18:07 AM »
Yeah they worked well from what I could tell but the pistons had stuck a bit due to not being used. Otherwise the Yamaha master cylinder is good and looks ok
Offline methebmxer
« Reply #12 on: July 24, 2014, 03:18:49 AM »
Not sure about the brake switch?
Offline CBJoe
« Reply #13 on: July 24, 2014, 04:49:10 AM »
Can you clarify what you mean by Big Bore Kit?  Are you referring to the Dynoman DP674 Piston Kit?  Or are you referring to Paulages Thread, where he uses CB750 sleeves and pistons and has the 650 case bored and the sleeves machined?
Cheers, Joe
« Last Edit: July 24, 2014, 04:51:16 AM by CBJoe »
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
« Reply #14 on: July 24, 2014, 02:31:46 PM »
Cheers, Joe
Joe,
I was referring to the Paulages thread with the 750 sleaves.
Offline CBJoe
« Reply #15 on: July 24, 2014, 03:32:04 PM »
Thanks...just making sure I hadn't missed another thread on the topic.
For the OP...here's the thread to that if you want to read into it.
http://forums.sohc4.net/index.php?topic=40414.0
Cheers, Joe
'65 CB77
'66 CM91 (C90'ish)
Offline methebmxer
« Reply #16 on: July 25, 2014, 06:42:51 AM »
Thanks CBJoe will take a look.
with the bike completely stripped I could check out the frame which I had concerns about early on, here's why...
Someone previously decided to go at the seam on the top of the spine with an angle grinder. Apparently in an attempt to fit a different fuel tank.
They have removed the weld the entire length of the spine!
Also they hammered some other bits randomly
This is how it looks cleaned up. There are some 1mm gaps. I don't own a welder just yet but have some experience welding and brazing although mainly torch use I am looking to buy a TIG unit. I need to work out the best way to repair this. I thought one way might be to weld a narrow strip the entire length of the seam to reinforce the area?
Offline methebmxer
« Reply #17 on: July 25, 2014, 06:56:05 AM »
That confirms my thoughts, thanks.
Looks like I need to get that welder ordered!
Offline methebmxer
« Reply #18 on: July 25, 2014, 07:38:01 AM »
I tried MIG and it was a lot easier to get the hang of but I need to Get to grips with TIG as I plan on using it to make bicycle frames in the future (I'm a bicycle mechanic by trade). I guess I will get the whole lot sooner or later as I'd like to have the choice in the future. I'm not very concerned with making it easy as I think I have a steady hand and just enough skill to match. My only concern is with spending cash as it has a habit of escaping me rapidly also. ???
« Reply #19 on: July 25, 2014, 07:48:23 AM »
With the stamped frames, I've seen builders grind the original welds and re-weld the top seams to make the seams cleaner and stronger. I've also seen builders grind off some material on the backbone to fit a tank, but still re-weld it. This is different, since the PO left the structural integrity of the frame compromised by not re-welding the seams. What a moron!  I agree with the others - MIG or TIG it.
Offline methebmxer
« Reply #20 on: July 25, 2014, 08:08:12 AM »
I think the PO must have either had no idea what they were doing or just gave in half way through trying to get a non standard tank to fit. Either way I have to deal with this first or the bikes useless to me. As it was free and I'm looking to improve my welding it actually may be a blessing in disguise or at least I prefer to see things positively.
Offline methebmxer
« Reply #21 on: July 25, 2014, 08:12:38 AM »
The carbs seem in good condition other than one has some horrible deposits. The other three are clean as a whistle in comparison. What would the deposits be a result of?
Offline CBJoe
« Reply #22 on: July 25, 2014, 11:50:27 AM »
If you are lucky those carb models on your '82 should have removable slow jets (hopefully).  I think you can tell by the carb model number.  The previous CV carbs on the '81 models had pressed in slow jets and were a real PITA to clean.
EDIT:  I believe that the VB44A's had pressed in slow jets and VB44B's had the removable ones.
Cheers, Joe
« Last Edit: July 25, 2014, 12:12:26 PM by CBJoe »
'65 CB77
'66 CM91 (C90'ish)
Offline methebmxer
« Reply #23 on: August 27, 2014, 12:49:18 PM »
Been a couple of weeks but I've made an engine stand so I can get serious about pulling the engine apart and have bought a TIG/MIG welder which I've begun to get used to before I touch the frame.
I'm currently more distracted than ever by the top triple tree nightmare that came on my bike. I'm sure most of you will be aware of the unusual double handlebar design and I've read plenty on the subject of changing it for a regular handlebar but can't seem to find a conclusion and its bugging the hell out of me.
I would like to if possible only replace the upper triple tree/yoke section and tick this off my to do list but I fear that I'm way to hopeful.
The stanchion/fork uppers are 37mm diameter. http://organ-donor.org/motorcycle-data/fork-tube-diameter-list/#tube37
It seems I have three options but each with their own set of problems.
1. I found a CB900C (80-82) upper but the spacing of the fork uppers is around 10mm wider than the CB650SC so I would need to buy the matching lower. I think I may just need to fit a wider axle, hub spacers and space the callipers to make this work but the steering bearings also vary and I don't know if this is possible to adapt? also the stem length may be way out?
2. I fit a different triple tree set with the same fork leg spacing, bearings and stem size. Please enlighten me if this exists.
3. Somebody tells me what I'm looking for doesn't exist and I swap out the entire fork, deal with the related issues and go back to sleeping at night.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #24 on: August 27, 2014, 01:13:32 PM »
I would look for a 78-79 GL1000 upper. It uses 37mm tubes and also the twin disk reverse Comstar that is on your bike. It would not surprise me if the spread were the same.
