Author Topic: Oil chamber full - no oil in sump  (Read 1853 times)
Steelo
« on: September 24, 2006, 03:33:46 AM »
I have just replaced the head on my bike - I have filled the oil tank and then turned ignition over without fuel. No oil came out the opening where my oil pressure guage sits. I removed sump plug and the sump is dry. What have I done wrong? Or haven't done?
Re: Oil chamber full - no oil in sump
« Reply #1 on: September 24, 2006, 03:36:25 AM »
WHAT BIKE? If its a 750 the sump is dry till the engine runs
Steelo
« Reply #2 on: September 24, 2006, 03:39:29 AM »
so no oil will pump using just the starter?
Its a K7.
Do I need to fuel it up and give it a burst?
« Reply #3 on: September 24, 2006, 04:12:08 AM »
It will eventually pump round using kick or electric, but you have to fill all the galleries, oil filter, lines etc. Do you honestly think Honda licked it over till the oil light went out on the end of the line?
Offline 750goes
  • it will live
« Reply #4 on: September 24, 2006, 04:21:32 AM »
half fill the oil tank
hit the electric starter or use your leg - your call.
the oil light should go out after a few seconds
step 1...  check the oil level in the tank - top it up to dipstick level mark... then run it ...then check the level again
repeat step 1 as often as you like
keep doing the same thing for a while until you reach maximus fullus - if you put too much in - drain some out..
the sump only holds about a litre :)
Offline RRRToolSolutions
  • I love old Japanese bikes!
« Reply #5 on: September 24, 2006, 04:42:37 AM »
I just had the same issue. No way I was going to start-up a fresh motor without priming it. I tried to turn it over with the electric starter and no plugs, but still no oil pressure.
Mike Rieck hit the nail on the head -
He suggested I remove one of the tappet covers and pour 1 quart into the head cover so it would go directly to the sump. It worked! I hit the starter and oil pressure climbed to 30 lbs immediately (plugs removed). I knew all parts had been given a clean supply of life blood.
Regards,
Gordon
« Last Edit: September 24, 2006, 04:45:18 AM by Ilbikes »
Kaws, Hondas, Yamahas, and Suzukis - especially Kaws
Offline kghost
« Reply #6 on: September 24, 2006, 01:58:10 PM »
For a complete rebuild I usually pack the oil pump with either vasoline or lubriplate. Helps prime the pressure/scavage pump. (remember there are two rotors)
Stranger in a strange land
Steelo
« Reply #7 on: October 01, 2006, 03:04:29 AM »
Problem solved. Removed oil pump and primed by hand in a bowl of oil - replaced carefully into position and replaced sump cover. Gave starter motor a turn over and pressure went up to 60psi. Happy Chappy here!!! ;D
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
« Reply #8 on: October 01, 2006, 07:46:21 AM »
Is he any relation to blackus oilus?
« Last Edit: October 01, 2006, 04:06:23 PM by nickjtc »
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline 750goes
  • it will live
« Reply #9 on: October 01, 2006, 02:51:47 PM »
Nick
No he is only a relation to smartus arsus  :D :D,
Offline nickjtc
« Reply #10 on: October 01, 2006, 04:07:13 PM »
Nick
No he is only a relation to smartus arsusĀ  :D :D,
1977 Suzuki GS750
