Author Topic: 1975 cb750f oil filter stripped in crankcase  (Read 608 times)
Offline kingrabbit
  • Half-Assed Wrench
« on: July 25, 2014, 06:04:18 PM »
The aluminum crankcase hole where the oil filter screws in is stripped. Previous owner had tried to address this by tapping the hole and putting a brass fitting in there.
I tried JB weld.
It worked for a bit.
Then the oil leaked out round the gasket again. All the oil.
What I want to know is if I can get a big enough helicoil to fix this?
Any ideas?
'74 CB 550K
'75 CB 750F
'73 XLH 1000
Donny
Offline Vinhead1957
Re: 1975 cb750f oil filter stripped in crankcase
« Reply #1 on: January 15, 2015, 04:31:08 PM »
They have an adapter for spin on filter upgrade. You can try to thread it in with T-tape or epoxy it in with JB weld. The alternative is helicoil.
