Author Topic: swing arms  (Read 1988 times)
Offline captain rats
swing arms
« on: July 27, 2014, 05:58:14 pm »
Is it the F series swing arm that's slightly longer than the early k series or the K8?
After a longer swing arm that will bolt on with no mods. Advice appreciated?
Offline bjbuchanan
Re: swing arms
« Reply #1 on: July 27, 2014, 06:44:23 pm »
F is longer
Offline 78 k550
Re: swing arms
« Reply #2 on: July 27, 2014, 10:36:14 pm »
I have a 76 swing arm and chain guard.
PM me if interested.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Re: swing arms
« Reply #3 on: July 28, 2014, 02:38:13 am »
77/78 f or k are both longer, not a lot mind you.
Offline Bailgang
  • Scott
  • Indiana
Re: swing arms
« Reply #4 on: July 28, 2014, 03:45:40 am »
The left side shock mount sticks 10mm farther out on the 77/78 F and K so shock alignment issues can be a problem when mounting the later swingarm to an earlier K or F.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline Stoli
Re: swing arms
« Reply #5 on: July 28, 2014, 03:56:43 am »
A CB650 swingarm is longer than all of them but does require a slight mod. I realize you stated no mods but thought it was worth mentioning. All you have  to do is englarge the holes in the frame to accommodate the larger pivot bolt. You will also need the axle and spacers from the 650.
My Project Threads:
Project #1 - http://forums.sohc4.net/index.php?topic=117106.0  First bike
Project #2 - http://forums.sohc4.net/index.php?topic=127364.0  Something different
Project #3 - http://forums.sohc4.net/index.php?topic=123831.0  Long and Low
Re: swing arms
« Reply #6 on: July 28, 2014, 08:07:26 am »
500-4 is also longer, but I think same pivot size. Opening pivot hole is not easy to do a nice job,  but you can make spacers, and run, original size bolt.
Offline MiGhost
  • What was that about being an
Re: swing arms
« Reply #7 on: July 28, 2014, 08:49:01 pm »
The '79 CB650 used the the smaller 14mm pivot bolt common to 76-78 550\750 and would be no mod bolt in.
~ Ghost
Grey Ghost '80 CB650C: Updated Stock Restomod. Period Custom Cruiser (OEM harbags & trunk, Wixom Ranger fairing, Jardine turnouts)
Bad Moon '83 XJ750MK Midnight Maxim: Full Dress Tour Deluxe w/ X-1 Fairing
Re: swing arms
« Reply #8 on: July 28, 2014, 11:02:59 pm »
Be careful opening the frame hole for bigger pivot. If not done accuratelly, you could end up with slop there, be simlar to worn swingarm bushings..
Re: swing arms
« Reply #9 on: July 28, 2014, 11:57:24 pm »
+1, its far easier to modify the swingarm...
Offline Stoli
Re: swing arms
« Reply #10 on: July 29, 2014, 04:38:14 am »
How do you modify a swing arm to accept a smaller pivot bolt? All I can think of is custom bushings and although that is probably a more elegant solution than opening the holes in the frame, I wouldn't consider making brass bushings easy. Hondaman makes custom SA bushings so you could send it to him I suppose. That would be easy.
My Project Threads:
Offline dusterdude
Re: swing arms
« Reply #11 on: July 29, 2014, 09:50:11 am »
Bushings
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Re: swing arms
« Reply #12 on: July 29, 2014, 09:55:41 am »
Remember the F's had disc brakes. That requires a mod.
Re: swing arms
« Reply #13 on: July 30, 2014, 04:40:54 am »
Some great advice and tips there including stuff I never thought of.
How much extra length we talking about with a k8 swing arm, if anyone knows?
Offline Stoli
Re: swing arms
« Reply #14 on: July 30, 2014, 05:57:22 am »
In a nutshell, you gain an inch with the K8 and 2" with the later ones. Here are some pics from another thread - link to that entire thread below. As you read through that thread and some others on here, you might be scratching your head as different guys point out different things that they had to do to make things work.  I think the biggest source of confusion (for me anyway) is that very few refer to the year (and/or model) of the DOHC that they were using, and there were differences just like there are differences between the different years of the SOHC.
The above pic is from this thread which has some good info -
Here's three swingarms for comparison
top to bottom, left to right... '74, '77, and DOHC.
(ignore the obvious screwup with the 10&15/32"... it's 10&7/16" but I can't be bothered to go back and modify the pic)
http://forums.sohc4.net/index.php?topic=34880
« Last Edit: July 30, 2014, 06:00:14 am by Stoli »
My Project Threads:
Offline Stoli
Re: swing arms
« Reply #15 on: July 30, 2014, 06:07:36 am »
... As you read through that thread and some others on here, you might be scratching your head as different guys point out different things that they had to do to make things work.  I think the biggest source of confusion (for me anyway) is that very few refer to the year (and/or model) of the DOHC that they were using, and there were differences just like there are differences between the different years of the SOHC.
Case in point - in the pic above, the DOHC shows a "pivot" length of 9-3/8" which you would need to grind down to fit in the CB750 SOHC frame, but an '81 CB650 has a "pivot" length about 1/16" less than a CB750 SOHC, so instead of grinding, all you need is a large washer used as a spacer.
I know you are not looking to go with anything that needs a mod, but I am just posting that here in case there is someone else that reads the thread and is thinking about a DOHC swingarm.
« Last Edit: July 30, 2014, 06:11:08 am by Stoli »
My Project Threads:
Re: swing arms
« Reply #16 on: July 30, 2014, 03:12:31 pm »
That's awesome, thanks will be a good help. Good to see some fit a wider tyres too.
Re: swing arms
« Reply #17 on: July 30, 2014, 03:22:37 pm »
Rats, I have a pic somewhere of a 4.5 inch rim in a stock 750 swingarm, you would be surprised just how big a tire you can squeeze into a stock arm mate... I'll dig it out and post it... ;)
Here you go...
And here's a pic of a modified GSXR swingarm i have , monoshock removed and shortened, I also have a GS1100 {gsx here} that i'm having the pivot area removed and shortened at that end and a new pivot tube made up, anything is possible mate... ;)
The alloy arm is on a CB750 F1 frame...
« Last Edit: July 30, 2014, 03:32:30 pm by Retro Rocket »
Offline calj737
  • I refuse...
Re: swing arms
« Reply #18 on: July 30, 2014, 03:51:03 pm »
Retro - is that a 17" wheel on that swing arm?
Offline MarshallCS
  • The Audio Ninja
  • The things I can control are in control
Re: swing arms
« Reply #19 on: July 30, 2014, 04:31:02 pm »
So between a 78F swingarm and a 79 650 arm, the 650 arm is longer with no other mods needed?
First and Only Bike
1978 Honda CB750F Supersport
Re: swing arms
« Reply #20 on: July 30, 2014, 06:31:37 pm »
Yes Cal, its a 4.5 inch x 17 off a 1988  gsxr750J, same size axle as the 750 too... ;)
