Author Topic: 550 K0 press in jets, which way is up?  (Read 868 times)
DH
« on: July 28, 2014, 11:43:02 AM »
I used to know this but forgot. I look at the main jet thru one end, then the other, and it looks different both ways. A "shallow" end and a "deep" end? Which end of the jet is pressed into the carb body? Someone please kick me in the head... :P
Offline goldarrow
  • one day, i'll be an
Re: 550 K0 press in jets, which way is up?
« Reply #1 on: July 28, 2014, 11:45:27 AM »
the small groove for oring and it goes up, large groove for leave spring
CB550 K0
DH
« Reply #2 on: July 28, 2014, 11:50:28 AM »
Thank you sir. And thanks for not kicking hard :)
I never thought to check the grooves, i always looked inside.
But, whatever works :D
Offline MoMo
  • Ride like you're invisible
« Reply #3 on: July 28, 2014, 02:13:01 PM »
looking inside can tell you the direction too-the tapered opening would go towards the bowl
« Reply #4 on: July 28, 2014, 02:22:05 PM »
When installed, you should still be able to see the jet size number.
DH
« Reply #5 on: July 28, 2014, 07:10:17 PM »
Thanks again folks. I'd bet many a P.O. have put them in wrong as well.
Always helps to ask questions :)
Offline Deltarider
« Reply #6 on: July 28, 2014, 11:23:36 PM »
Mine don't. Tapered opening is where the tapered needle finds it's place. Easy to remember.
CB500K2-ED Excel black
