Author Topic: 1972 CB750K2 (start from scratch) project. Cases back together  (Read 102684 times)
Offline edwardmorris
  • Youngish
Re: 1972 CB750K2 (start from scratch) project. Small leak!!! Damn!
« Reply #150 on: January 15, 2015, 12:07:37 PM »
Lester wheels?? I see lester wheels! Sorry I get excited  :P
I just have a front
Save it for the next one ;)
As for your bearing thing, I do recall that's exactly how it moved with the stock bearings, free with hand but in place when I was moving the frame, so it's probably fine if you have everything torqued down on the stem...
Offline Davez134
« Reply #151 on: January 15, 2015, 04:26:48 PM »
Ok one more progress pic from today. Done till tomorrow. Would do the front but I accidentally bought 2 rear spoke kits!! Oops. Anybody need rear spokes :)
Offline Riceman
« Reply #152 on: January 15, 2015, 06:28:27 PM »
So the fat washer worked with the stock stem?
I'm getting ready to do this tomorrow.
Offline Davez134
« Reply #153 on: January 15, 2015, 06:33:43 PM »
Yeah fat washer worked for me. Frame is a 71, triple is from '74. My kit instructions said how to measure before installing.
Offline Davez134
« Reply #154 on: January 17, 2015, 05:30:37 PM »
Well, I was going to install oil pump with new stopper and spring, but after looking it over from just the outside, I don't even want to put this pump back in the motor. Housing has obviously been taken apart, most screws are stripped out. One is missing between body and base, and appears not even a gasket in there. How do people think this is OK!?
« Reply #155 on: January 17, 2015, 05:49:23 PM »
Installed all balls steering bearings, not too hard. Quick question about adjustment/tightness. I know it's hard to quantify, but (without forks installed) should the triple stay in place or easily move back and forth? Right now I can move easily with my hands but it stays in place if I move frame around. (Hope this makes sense)
With no forks the trees should not move freely
Offline Davez134
« Reply #156 on: January 18, 2015, 09:09:48 AM »
Dave - just a reminder to clean the powder cost off the frame where the battery NEG cable attaches. There, and near the head stock where the HORN and LIGHT will ground. The powder coat can prevent a good, solid GROUND from occurring and you can have difficulties with the proper operation.
Frame looks very pretty in that gloss finish.
Thanks! I knew about the spot where the Battery negative goes but would have overlooked horn/light.
Offline Davez134
« Reply #157 on: January 18, 2015, 09:12:47 AM »
Brought some stuff to work today to get done. Got bronze bushings installed in freshly powder coated swingarm. Froze bushings, heated swingarm with 500w work light, installed with some all thread. Went waaaay too easy. Now I don't know what to do with myself
Offline Vinhead1957
« Reply #158 on: January 20, 2015, 04:33:53 PM »
That's sexy
Offline Davez134
« Reply #159 on: January 20, 2015, 06:59:51 PM »
Made some adjustments to all balls steering bearings/triple to close gap on fork ears after reading a recent thread in another section.
Thin washer on bottom, ground down top cap. Kept upper dust seal.
Also front spoke kit arrived...
Offline Davez134
« Reply #160 on: January 26, 2015, 02:44:13 PM »
Uh oh! S#!t just got real!
  • Youngish
« Reply #161 on: January 26, 2015, 05:34:01 PM »
300s or 341s?
  • Youngish
« Reply #163 on: January 26, 2015, 05:48:10 PM »
Do the nonos have chambers or straight through? I've been considering that option too after reading around here. Many seem to love the 300s for an agressive street 836...
Offline Davez134
« Reply #164 on: January 26, 2015, 06:02:32 PM »
I'll take the ends off and check for ya in a bit when I get back home. Heading to play some hockey right now. Quality of these seems great!
Offline goldarrow
  • one day, i'll be an
« Reply #165 on: January 26, 2015, 06:09:04 PM »
Those are nice! Can you also post pics of the other sides of pipes? Would like to see The chamber welding spots
CB550 K0
Offline Davez134
« Reply #166 on: January 26, 2015, 07:23:55 PM »
They are straight through. Tried to get it in this pic, but hard to capture.
Offline Davez134
« Reply #167 on: January 26, 2015, 07:28:17 PM »
Not sure if these are what you wanted. If not let me know
Have drain holes in bottom as well
  • Youngish
« Reply #168 on: January 26, 2015, 07:57:42 PM »
Thanks! So these ARE the 300 styled with removable baffles, very nice!
Offline Bill/BentON Racing
    • BentON Racing
« Reply #169 on: January 28, 2015, 06:24:44 AM »
Only if they come with that gorgeous wheel attached?  ;)
Dave, real nice! Cal I got one like that for sale ......for the rt price! D.I.D. 250x18 Buchanan's spokes SS H/D Gold anodized, Bill
BentON Racing Website
BentON Racing Facebook
Offline Davez134
« Reply #170 on: January 29, 2015, 01:42:42 PM »
Got my replacement oil pump rebuilt. New oil stopper seal/spring, new shaft seal, new case o-rings, new gasket. Clearances checked .16mm between rotors and nearly same between rotor/body. So I can rest easy now. This is what rotors looked like in my pump that i replaced. No wonder it didn't feel smooth
Now all good to go...
« Last Edit: January 29, 2015, 01:44:44 PM by Davez134 »
Offline Davez134
« Reply #171 on: February 04, 2015, 05:03:45 PM »
No real big updates, just waiting for a couple brackets, front brake caliper to show up so I can get powder coated then start assembly.
I needed some exhaust spigots, and found these made out of stainless steel. Cheaper than original replacements and no rust worries
Offline timbo750
« Reply #172 on: February 05, 2015, 12:19:36 AM »
Dave where did you get them. They look great, are there any more available?
Offline bert96
  • past ride
« Reply #173 on: February 05, 2015, 02:02:11 AM »
Would like to know too.
Bert
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline Davez134
« Reply #174 on: February 05, 2015, 07:30:12 AM »
I got them from a seller on ebay. Contacted him before buying, said he was going to try and gauge interest and make more if there was a need. They look great, but unfortunately the dimensions are just a bit off. The length from the bottom of flange to end of spigot that presses against gasket is about 2.5-3mm too short, so it will for sure have an exhaust leak. Also the diameter where pipe slides on is just a bit off as well. I contacted him about this and waiting for a reply back. We'll see what happens.
