Author Topic: 1972 CB750K2 (start from scratch) project. Cases back together  (Read 121054 times)
Re: 1972 CB750K2 (start from scratch) project.
« Reply #475 on: April 26, 2016, 08:55:05 PM »
Not the most exciting update, but I added oil pressure gauge for peace of mind. I meant to do this a while ago but spaced it out. It was sooo easy to install. I may leave it on, or just use to check pressure periodically.  Looks OK too, just have to get used to it if I leave on.
I just bought one too.  Did you use Teflon tape or "pipe dope" on the threads?
Offline edwardmorris
  • Youngish
« Reply #476 on: April 26, 2016, 08:55:38 PM »
Was it for sure that seal that was leaking and not just chain lube? My center stand gets greasy and I clean it every few trips, but its easy to tell its the chain lube based on how stringy it is (Lucas brand I think). The black paint could be hiding it, but that area looks too clean for an oil leak to me,  unless you already cleaned it before the pix?
Offline Davez134
« Reply #477 on: April 26, 2016, 09:03:08 PM »
Yeah, I'm sure it's not chain lube. Drips down kickstand, all over wheel. Not horrible, but oil for sure. And it's not coming from oiler hole either, I left the tray out and plugged the hole as well. The pic doesn't show it well, but it's oily as #$%* in there.
« Last Edit: April 26, 2016, 09:04:50 PM by Davez134 »
Offline Davez134
« Reply #478 on: April 26, 2016, 09:06:47 PM »
Just used some tape. Really like the gauge.
  • Youngish
« Reply #479 on: April 26, 2016, 09:07:08 PM »
Yeah, I'm sure it's not chain lube. And it's not coming from oiler hole either, I left the tray out and plugged the hole as well. The pic doesn't show it well, but it's oily as #$%* in there.
Cool. Just for added sealing, apply a thin coat of Hondabond/Permatex #2 on the outer surface. I'm pretty sure I did that, will have to go back and check before I get to the K3.
Offline Davez134
« Reply #480 on: April 26, 2016, 09:17:32 PM »
I did apply hondabond to outer surface. It was actually leaking from around shaft part of seal. Maybe got tiny damage somehow when installing?? I'm going to use permatex this time outside, as it seems like it may lube better installing, then seal too.
Offline Davez134
« Reply #481 on: April 27, 2016, 09:42:31 AM »
To get proper clearance, I removed shifter cover and foot peg.
Made tool to hit it in with, got to play with my new cut off saw.
Covered splines with tape, assembly lube on inside, non hardening dealer on outside of seal.
« Last Edit: April 27, 2016, 05:02:48 PM by Davez134 »
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #482 on: April 27, 2016, 10:06:50 AM »
That's a tiny chop saw!
--Evan
1975 CB750K "Rhonda"
Offline Davez134
« Reply #483 on: April 27, 2016, 10:21:28 AM »
Ha ha. I can't tell if you're joking or not because it does look small in that picture but it is 14 inch and heavy!!
Offline evanphi
  • Apparently I'm an
« Reply #484 on: April 27, 2016, 10:57:52 AM »
I'm used to larger bases for woodworking. Yours must be for cutting steel?
--Evan
Offline Davez134
« Reply #485 on: April 27, 2016, 12:35:52 PM »
It actually uses same blade for steel/aluminum, plastics. You can touch the steel right after cutting and it doesn't burn your hand. It's an evolution/rage blade and saw. Haven't used my DeWalt saw since I got this one.
« Last Edit: April 27, 2016, 03:39:07 PM by Davez134 »
Offline Davez134
« Reply #486 on: April 27, 2016, 03:42:43 PM »
So, I think the reason this seal was leaking was the inner lip location. Compared to the OEM self I just put in, the lip was further out toward the end of splined shaft. It was just about where the splines start. The genuine seal inner lip is a few mm back toward smooth part of shaft. The original one I put in came in a kit from cycleX.
« Reply #487 on: April 28, 2016, 03:23:49 PM »
The only thing I'd add is cut the corner off a plastic sandwich bag and cover the splined shaft. It will help prevent tearing the seal lip as you slide it over the shaft. Just pull it out right before you set the seal. It just noticed...sliding it over the shaft, pulling it out...never knew working on replacing a seal was so much like sex. ;D ;D
Offline Davez134
« Reply #488 on: April 28, 2016, 06:34:44 PM »
sandwich bag would have been a much better idea than the tape I used. Yeah, my mind is dirty too...the only difference between all that you just said about the bike and sex is that with the latter, I dont swear, get angry and want to punch or throw anything during or after. Yet. ;)
Offline Davez134
« Reply #489 on: May 23, 2016, 06:54:40 PM »
Got a chain guard finally. Had it powder coated in a fine texture black because it had some rust pitting that would have showed if done in smooth gloss.
Matches the texture on my motor pretty close too
Offline evanphi
  • Apparently I'm an
« Reply #490 on: May 24, 2016, 05:03:01 AM »
WOW!
--Evan
« Reply #491 on: May 24, 2016, 08:37:37 AM »
Looks good Dave.
« Reply #492 on: May 25, 2016, 04:32:59 AM »
Offline el pachuco
« Reply #493 on: June 07, 2016, 11:33:51 PM »
Another beautiful bike!!
I recently sprayed my chain guard with rattle can bed liner. It looks very much like yours.  I like it much better than gloss black.
Also, I read where crimping the gauge halves back together kicked your butt.
I just did mine today. I used a piece of 4" PVC pipe (2" long ), sitting on a ' round plywood base  for the upper half to rest in and a 12" speed clamp to press the two halves tight, while I crimped them back together. Made for a good tight seal and a secure fixture while I hammered away on the ring.
Offline budman
  • 1914X
    • LeCompte Electric Bass
« Reply #494 on: June 27, 2016, 06:53:39 AM »
You do nice work, Dave.
Bud
1973 CB750K3 Chopper (in pieces)
Offline eM3rge
« Reply #495 on: October 21, 2016, 05:03:07 PM »
Hey Dave! I was just browsing around here and I think I have your old bike!
Offline Davez134
« Reply #496 on: October 22, 2016, 07:52:32 AM »
Nice, haven't seen it in a while. Good to know someone is still enjoying it!
Offline eM3rge
« Reply #497 on: October 22, 2016, 09:38:06 AM »
You're more than welcome to check it out, I'm at the southwest part of the valley.
Offline Davez134
« Reply #498 on: October 22, 2016, 10:01:27 AM »
I'm in the southwest as well. We'll have to go ride soon.
Offline moraarcher
« Reply #499 on: October 25, 2016, 08:37:17 PM »
Very impressed, what a beautiful bike. Just showed the pictures to my wife and said I'd like to something like that someday. She said it looked great and if that's what I wanted to do go ahead. That's my opening and now I'm on the hunt. I still have some things to finish on my '72 750.
Once again nice job on the bike and the write up.
1972 CB 750 k2   14,000mi
1998 GL 1500a    98,000mi
1985 GL 1200a
1982 Silverwing
1974 CL360
1965 Cub 50cc
