Author Topic: Weird place to see oil bubbling.. '77 CB550 K  (Read 740 times)
Offline bretherin
« on: July 30, 2014, 08:40:34 AM »
So my head gasket has been weeping oil for a bit now and the plan is to get to this once I finish up a cb450 resto as I don't want to be without a bike. However, yesterday I looked down while at a stop light and noticed that the nut in the below picture was wet with oil. The opposite side is completely dry. Upon further investigation I can see oil bubbling through the threads. This link shows my little video this morning before getting into the office. Oil bubbling on CB550
I tried to search on here and some people eluded to the head cover's side covers that are attached by the L bracket however this seems to be bubbling through the threads. The nut is not lose although I was hoping to get the time to loosen the top and re torque it down but I was hoping for a little bit of an explanation is anyone has one or seen this before? Plus, any suggestions are more then welcome.
Re: Weird place to see oil bubbling.. '77 CB550 K
« Reply #1 on: July 30, 2014, 09:19:35 AM »
It's a bit of a compression leak past the fire ring of your head gasket closest to that cylinder stud. It'll bubble out a little oil with it. It may eventually work it's way out to show between the head & cylinder, but for now just give it a wipe now & then.
« Reply #2 on: July 30, 2014, 09:45:49 AM »
Oil does bubble when too hot.
You certain the rubber pucks/oil seals under the cylinder cover aren't leaking?  These harden and loose seal with heat and age.
Offline bretherin
« Reply #3 on: July 30, 2014, 10:00:36 AM »
Head gasket is definitely leaking..
It does bubble in direct relation to throttle response, it was weak in the video as the bike was idling but at a stop if I look down and rev slightly it bubbles accordingly.
I am not certain as I have never looked in there but I doubt any PO ever has, so given its age and sparse use I'm sure they are due for a replacement.
« Reply #4 on: July 30, 2014, 12:22:56 PM »
My race engine leaked at one stud. It was barely noticeable and when I pulled the head in the off season you could see the path of the compression leak. In my case re-annealing the copper head gasket sealed it.
When/if you remove the top end for gaskets make sure you straighten both surfaces.
