Author Topic: NEW Cal Fab swingarms for the 750  (Read 40403 times)
Re: NEW Cal Fab swingarms for the 750
« Reply #50 on: March 02, 2015, 02:22:53 PM »
It would be awesome if they made a version for eye-to-eye shocks.
I think clevis mounts make the most sense as the closest "bolt on" option. Is there some advantage to eye to eyes over clevis mount? Every shock choice out there nowadays comes in either option.
Maybe. It always seemed to me that there's more options in eye to eye, especially browsing used oem take offs.
With high quality shocks like Ohlins you can get both clevis and eye to eye on any twin shock....
Wobbly
« Reply #51 on: March 02, 2015, 03:42:46 PM »
As a side note/alternative: the German company K&J makes really nice swing arms for all CB750 Fours. They are bolt-on parts, and street-legal in Germany--pass the German TUEV inspection, which is extremely difficult to pass. Thus, they have been thoroughly tested. Not cheap--but if you are thinking Ohlins, that better not be a concern anyhow. Your choice of chrome, paint, or powder coated. I thought you might find them interesting.
http://www.krueger-junginger.de/Stahlschwingen-2011.pdf
http://www.krueger-junginger.de/html/kastenschwingen.html
« Reply #52 on: March 02, 2015, 04:34:15 PM »
Wobbly, no offense mate but, this thread is about the cal fab arms , there are other companies making aluminium arms for the Honda's as well, mainly in Japan and the US, I started this thread to show the Motogpwerks arm no one elses, These arms are extremely well built and would pass any Government inspection, they are better than the original calfab arms which were built for racing. I know about the German arms I have that link, I prefer aluminium,  those arms are steel, just like the Dresda ones Carpy makes.... Feel free to start your own thread if you wish to show other arms..... ;)
« Reply #53 on: March 02, 2015, 04:39:53 PM »
Is there a swingarm for the 750 F0 through F3 Model's?
How much longer is the FO arm Cougar..? I think the FO-F1 have a different length arm to the F2-F3's.  These arms are 20mm longer than a stock K so they should be fine for the early F's..
« Reply #54 on: March 02, 2015, 04:55:00 PM »
For what Shocks Elan...? All the good model shocks on the market for these bikes are eye to clevis..?
« Reply #55 on: March 02, 2015, 04:56:00 PM »
Got mine and it's on the bike already. Going with a cbr f3 rear wheel, brake, and 160 tire. The cbr assembly fit perfect with no spacers and I'm going to need 2 small spacers to center the arm in the frame. With the arm centered, the wheel is offset 3/8s to the right and I will need a 3/8s offset sprocket. Bike already has a complete gsxr 1000 front end on it.
I called Chris on Saturday to confirm fitment after getting it in and seeing that it will require spacers and he said his mockup bike was a 72. My bike is a 75 K. I'm not sure if or when the swing arm dimensions changed or if my bike is just a little goofy. It won't take a large spacer probably 3/16 an inch on each side. I'll be back at the shop later this week to finish those and mount foot controls (thinking high mids like a pro flat track bike) and I'll be able to get solid measurements.
Here's my bike.
Gday mate, I just measured 2 stock arms, one on a K2 frame and one on a K6 frame and they both measured around 226mm {they are both in frames so the measurement is within half to a quarter of a mm}, My calfab arm measured the same at just a fraction over 226mm, measuring the pivot tube from end to end.... ;)
« Reply #56 on: March 02, 2015, 05:48:59 PM »
How did you do the measurement? I can check my F/F1 arm also (unmounted). The Cal Fab would need a brake stay mount welded on.
Offline Cougars750F0
« Reply #57 on: March 02, 2015, 06:17:22 PM »
I can't measure it rite now  my F0 is in a protected  storage  facility until I  an get my  new shop  up and running.
1970 Honda / Yoshimura 810 with ported head, 1968  Honda CB450 5 speed European model, 1973  Triumph Bonneville 750 twin carburetor model, 1975 Honda 750F0 Super Sport, 1977 Honda 750A
« Reply #58 on: March 02, 2015, 07:17:13 PM »
On the pivot tube..?  I used a tape measure in MM one of the swingarms {in the K@ frame} doesn't have the collars on it so it was easy, the other i just measured in frame and it was so close to the K2 that i assumed it to be identical, the calfab was easy, took it out the box.... ;D  Jerry, for length, measure from the centre of the pivot tube or bolt {same measurement}  to the front of the axle slot, for width, just measure the swingarm itself, not the bushes or with the collars or caps or whatever you want to call them, just the width of the actual swingarm pivot tube... Thats what i measured.... ;)
« Reply #59 on: March 02, 2015, 07:52:27 PM »
I have to say this swingarm is for an F. I have the last JMC swingarm on earth made for an F so I don't give a $hit. I have to be honest and say they should use a tube like modern bikes for the axle........just saying.
« Last Edit: March 02, 2015, 07:57:13 PM by MRieck »
« Reply #60 on: March 02, 2015, 08:13:30 PM »
If anybody out there is looking for a swingarm, I would strongly advise against the Carpy Dresda copy.  I bought one used from a member here and it is total garbage...flimsy, just as heavy as the stocker, axle adjusters are too small for the box section so that it crushes when you tighten the axle, absolutely no performance advantage.  It looks very similar to the KJ arm, but the KJ arm has more bracing on the pivot tube, and I am sure, the KJ must be a higher quality piece...sorry Retro about the off topic, really just all the more reason to consider the
MotoGPWerks piece.
« Reply #61 on: March 02, 2015, 09:16:26 PM »
MotoGPWerks piece.
No problem Sean... ;)
Offline creepxstreet
« Reply #62 on: March 03, 2015, 05:49:42 AM »
Back on track here, when are you 2 other guys getting your swing arms in and riding them?
« Reply #63 on: March 03, 2015, 02:33:22 PM »
I have 3 different aluminum swingarms, I have to decide which is going on which bike as I'm only keeping one. I think i may use the calfab arm first, I'm waiting on some frame work to be finished before i can get the frame powder coated and fit the arm, I'll post here as soon as its in... ;)  I just re read your original post, if your wheel is offset you need to adjust your wheel spacers, or are you referring to the sprocket carrier poking out further  ..?  If it's just the sprocket carrier, all you need to do is shave 3/8ths off it, I've done this before and it works well...
« Last Edit: March 03, 2015, 02:37:06 PM by Retro Rocket »
« Reply #64 on: March 03, 2015, 02:45:49 PM »
The wheel is only 1/8 inch more offset than what we measured the stock rear wheel to be offset at. I also need a 3/8s inch offset front sprocket to get chainline straight.
« Reply #65 on: March 03, 2015, 04:50:26 PM »
Thats what i'm saying, you need to center the wheel, the stock rear wheel shouldn't be offset at all....?  the easy way to get the chain line right is to take some material off the sprocket carrier, it has to be perfect as well....
« Reply #66 on: March 03, 2015, 04:58:18 PM »
I couldn't find any solid info on stock wheel offset. 1/8 inch more can't hurt too much and there were no tracking issues previously. If it's all #$%*ed up I'll redo it. I'm not sure how much I can take off the cush drive face or how much tire to chain clearance. It's something I'll be paying close attention to though.
« Reply #67 on: March 03, 2015, 05:02:05 PM »
You won't find any info on "stock wheel offset", there shouldn't be any offset, it should sit dead center .... ;) I've seen this problem before and its usually down to a poorly spoked rear wheel or using the wrong spacers, allowing the wheel to sit off center. Do you have a build thread..?  We should be discussing this there.... ;)
Offline johno
« Reply #68 on: March 04, 2015, 03:30:30 AM »
Sorry to butt in Retro but the poor bloke is stressing about his offset . :(
Creepstreet jump on my thread Salt lake racer oz style, halfway down the page and I'll explain how the model changes the swing arm.
cheers johno :D
« Reply #69 on: March 04, 2015, 11:56:52 AM »
OK so we're on the same page here. For the swingarm length I got 430mm from the center of the pivot bolt to the front of the axle slot and the width of the swingarm tube only without bushes is 230mm.
Can I get a second verification measurement from someone?
« Last Edit: March 04, 2015, 11:58:52 AM by Jerry Rxman Griffin aka MuthaF'er »
« Reply #70 on: March 05, 2015, 09:19:49 AM »
No doubt about it, Mick.  This is a quality piece.
« Reply #71 on: March 05, 2015, 02:54:42 PM »
That it is Don.... ;)
« Reply #72 on: March 05, 2015, 04:07:28 PM »
Cant believe you dont have that arm bolted up yet, Mick!
« Reply #73 on: March 05, 2015, 05:27:56 PM »
Frames out for mods Steve.... ;)
« Reply #74 on: March 07, 2015, 05:54:06 AM »
What changes are you making? gussets and such? Wheel is going to machine shop Monday. Gap at the pivot bolt closed when I tightened the pivot bolt. I didn't even think about how structural that was and the frame flexed out I guess. Not used to working on old stuff.
