Author Topic: NEW Cal Fab swingarms for the 750  (Read 36286 times)
Re: NEW Cal Fab swingarms for the 750
« Reply #75 on: March 05, 2015, 09:19:49 AM »
No doubt about it, Mick.  This is a quality piece.
« Reply #76 on: March 05, 2015, 02:54:42 PM »
That it is Don.... ;)
« Reply #77 on: March 05, 2015, 04:07:28 PM »
Cant believe you dont have that arm bolted up yet, Mick!
« Reply #78 on: March 05, 2015, 05:27:56 PM »
Frames out for mods Steve.... ;)
Offline creepxstreet
« Reply #79 on: March 07, 2015, 05:54:06 AM »
What changes are you making? gussets and such? Wheel is going to machine shop Monday. Gap at the pivot bolt closed when I tightened the pivot bolt. I didn't even think about how structural that was and the frame flexed out I guess. Not used to working on old stuff.
« Reply #80 on: March 07, 2015, 08:10:04 AM »
If the engine is already bolted in the frame and there is any excessive clearance between the arm and frame, it's far better to add shims. The swingarm should be a snug fit between pivot bosses.
« Reply #81 on: March 07, 2015, 03:14:37 PM »
Adding gussets and a top frame rail kit, then off to the powdercoaters... ;)
« Reply #82 on: March 12, 2015, 09:53:01 AM »
Great to hear.  I think it might be time for you to start a build thread on this!
« Reply #83 on: March 12, 2015, 03:04:43 PM »
I don't have a camera and I don't use Iphones,  I get my daughter to take pics when she's around so expect pics in bundles at random intervals... ;D :o
« Reply #84 on: March 12, 2015, 04:23:03 PM »
I don't have a camera and I don't use Iphones...
WAT?  You are living in the 90's Mick!
Is this the walter mitty project I've been hearing about?!!
« Reply #85 on: March 12, 2015, 04:39:08 PM »
This place is my social media Steve, if I had a choice, i'd be living in the 70's.... 8)
Offline calj737
  • I refuse...
« Reply #86 on: March 12, 2015, 05:48:21 PM »
You'd probably sleep thru it again, Mick! (Sleep being a code word for drug and alcohol use)
« Reply #87 on: March 12, 2015, 05:52:32 PM »
For the music and lifestyle Cal, we've seemed to be going backwards for the last 40 years, I was 17 in 1979, i missed the hazy bit... ;D ;)
« Reply #88 on: March 12, 2015, 07:47:59 PM »
Can I join you Mick? As long as I can carry just a little hard earned wisdom back, all will be groovy.  ;) Ohhhhhyeahhhh!
« Reply #89 on: March 12, 2015, 08:08:30 PM »
Oh yeah, i'd be taking some foresight/hindsight..?  too mate.... ;)
« Reply #90 on: March 12, 2015, 08:51:32 PM »
Random and/or in bundles, we'll take it!!
« Reply #92 on: March 24, 2015, 06:48:02 AM »
Mine is almost ready to ride. Waiting for a brake hose to be made locally then bleed rear brake and ride it. Wheel is centered, chain line is straight with an offset sprocket
« Reply #93 on: March 24, 2015, 10:07:06 AM »
Sure would look nice on my F  :'(
« Reply #94 on: March 04, 2016, 03:50:23 PM »
How much were they?  Could maybe actually. Get one these days..  Stars might be aligned..
For the first 5, $650 USD,  they were originally going to be sold as just the swingarm at $650, these 5 have axle, brake adjusters and brake arm as well as heat treatment and cryo treatment, not to sure what is happening with the second batch...
Hey Mick.....I would like to order one of these but $650, holy #$%*e!  My latest project, The Park Racer, has a modded swing arm but with all the extra steel, must weigh over 26 kilos!
I'm not building a race bike but would like a custom swinger.  Any other options?
« Reply #95 on: March 04, 2016, 04:02:18 PM »
I,m not too sure Steve, Does Chris have any left..?  I can ask if you'd like...? As far as custom arms go, unless second hand, I've never seen a cheap one, the Japanese ones are well over a grand... I do have a couple of GS1100 alloy arms I'm going to have shortened at the pivot end, only paid $100 each for them and they are mint,  they are wider though so they aren't a bolt in option, bigger pivot bolt too, so some  frame mods ...  Seems I always do things the hard way... :o  Sorry I couldn't be of more help... ;)
« Reply #96 on: March 04, 2016, 04:23:05 PM »
I checked his eBay store, nothing listed.  I'm just doing research now, checking options.  My bike fund took a big hit yesterday, bought a GPz550! It's in transit...
« Reply #97 on: March 04, 2016, 04:35:02 PM »
Good little bikes the GPZ, bullet proof engines... ;)
What bike were you chasing the swingarm for mate..?  750..?
« Last Edit: March 04, 2016, 04:37:23 PM by Retro Rocket »
« Reply #98 on: March 04, 2016, 09:19:16 PM »
Yes, a K3 I bought a couple years ago that I just pulled out of storage.
Offline calj737
  • I refuse...
« Reply #99 on: March 05, 2016, 03:36:33 AM »
Stev-o, I appreciate not wanting to spend the money, but I will say this: the amount of work that goes into making a swing arm of this nature is enormous. The time spent welding alone you would pay nearly that much for someone to TIG it together. Then of course you have all the other fabrication and machine time (lathe to turn the pivot tube, milling for the axle keepers, Cryo treatment afterwards, etc). If you use $50/hr as a base rate, I bet there's nearly 35 hours of work in these. I'm making a couple of swing arms from scratch, also from aluminum, and I can attest to the work and time and "touches" just to get one thing dead right.
At $650, they are a bargain for their quality. Maybe not what you'd want to spend, but outside of CMR and TTR400, I don't know of another modern arm being made for the CBs. Spend it, you can't take it with you!  ;)
