Author Topic: A few weeks later, Oil leaking from pump again. Any Ideas?  (Read 642 times)
Offline Lostboy Steve
« on: August 08, 2014, 05:22:15 AM »
I previously replaced all of the o rings associated with the pump, even the hard to find big one, and everything seemed good. Today, I have a slight drip, which to me looks like oil accumulation under the sprocket cover again. I will pull it apart latar to inspect. I have a big ride on Sunday and now I'm worried.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline fmctm1sw
Re: A few weeks later, Oil leaking from pump again. Any Ideas?
« Reply #1 on: August 08, 2014, 05:32:58 AM »
Make sure it isn't coming from the gearshifter seal before you do anything drastic.
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #2 on: August 08, 2014, 05:34:34 AM »
Yes, I replaced that and the main shaft seal as well. It seems as though its the lower oil pump oring.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #3 on: August 08, 2014, 05:39:00 AM »
Ill tell ya, if it wasnt dripping directly on the pipe, I would tighten the bolt a little more and ride it until the winter. Its not a significant leak, just smells like hell...
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline fmctm1sw
« Reply #4 on: August 08, 2014, 05:39:25 AM »
It's been a while since I was in any of my SOHCs.  Is there anything above that that can leak (oil pressure switch?).  Something tells me I had a leak like that in my 350F that was actually coming down from somewhere else.
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #5 on: August 08, 2014, 06:45:11 AM »
It seems as though my stud is a bit wet with oil as well, a seperate leak.... that must be the rocker cover?
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #6 on: August 08, 2014, 06:51:28 AM »
Probably one of my rubber pucks... couldnt imagine its anything else. Well doesnt that just suck. Lol
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline fmctm1sw
« Reply #7 on: August 08, 2014, 07:44:06 AM »
Those leaks can be a real pain to track down.
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #8 on: August 09, 2014, 04:56:54 AM »
I think I found the culprit.  Something I overlooked before.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
