Author Topic: Stuck case bolts cb750  (Read 550 times)
Offline Carver
« on: August 05, 2014, 05:18:49 PM »
Alright I need some help getting these case bolts out. I got all of the top ones out eazy peasy. The bottom ones however, three are now rounded, three are out and a few arent budging AT ALL. I tried a ratchet, a hammer impact, a snap on 1/2" 14 volt impact, and now Have no idea how to progress. If all else fails one of the techs at my shop has a 1" makita impact but I'd rather not escalate it to that.
Any advice? thanks guys.
Cb 750 k3
Cb 450 dohc k4
Re: Stuck case bolts cb750
« Reply #1 on: August 05, 2014, 05:50:00 PM »
Drill the tops off....
Offline edwardmorris
  • Youngish
« Reply #2 on: August 05, 2014, 07:26:13 PM »
Try using some vice grip pliers, should get a good grip on them to twist loose.
Offline Carver
« Reply #3 on: August 06, 2014, 04:40:09 PM »
vice grips didn't work at all, Craftsman makes a special socket which I bought on recommendation from a tech at the shop. it absolutely wrecked them. Literally chewed up no edges left and this socket combined with a hammer impact still gripped them and got them out. Highly recommended.
http://www.sears.com/craftsman-bolt-out-5-pc-damaged-bolt-nut-remover/p-00952061000P
Cb 750 k3
Cb 450 dohc k4
