Author Topic: suspension set up  (Read 3693 times)
Rocking-M
suspension set up
« on: September 25, 2006, 05:26:20 PM »
Since I was curious on the brakes, the suspension set up also comes to mind.
I know sport bike handling isn't doable on a 30 year old bike,
but I'd like to get close.
Suggestions and sources for springs and shocks and set ups will
be appreciated ;)
Offline aptech77
Re: suspension set up
« Reply #1 on: September 25, 2006, 07:47:17 PM »
Progressive spring/shocks or Race Tech
78CB750F1
« Reply #2 on: September 26, 2006, 12:52:28 AM »
I am using Hagon rear shocks (stock length) and Hagon progressive front fork springs on my CB750 F1.  Good improvement over the stock setup although I do find the Hagon front springs to be a bit soft.
Honda CBer
« Reply #3 on: September 26, 2006, 05:26:38 AM »
if you dont have the bread for the progressive or works, etc, there are other options... with your fork, you can play with adding bushings to the springs to increase rate and heavier oil to increase damping and action... i have even seen modifications to put an air preload into the forks, complete with a pressure guage...
for the rear, CB1100F or 900F shocks are an upgrade, with added spring rate and (mildly) adjustable damping... you could also go with something like this:
http://cgi.ebay.com/ebaymotors/Honda-GL1000-Goldwing-CB750-Shock-Absorbers-Shocks-New_W0QQcmdZViewItemQQcategoryZ35592QQihZ005QQitemZ150037075747QQrdZ1QQsspagenameZWDVW
i have read that these are pretty good, especially for the money, AND they are new and fresh...
you can also try to find used aftermarket stuff like these:
http://cgi.ebay.com/ebaymotors/78-Honda-CB-750-SS-cb750-Supersport-KONI-rear-shocks_W0QQcmdZViewItemQQcategoryZ35592QQihZ007QQitemZ170033099283QQrdZ1QQsspagenameZWDVW
the stuff is out there if you look hard enough...
Rocking-M
« Reply #4 on: September 26, 2006, 02:44:07 PM »
I put the air system on a bike years ago. I didn't know squat then (nor now) about setting up a suspension on
a bike. I wonder now if it was a good compromise.
The problem around here is our roads tend to have rough sections.
If I get to much spring rate the tendency would be to skip out of the road.
However, I really like for the spring rates to give a good feel on anything
I ride or drive.
I watched the thread on the steering damper and that is one direction I'm going.
Thanks,
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #5 on: September 26, 2006, 03:12:32 PM »
When I first read this, I thought you might be from Michigan.  ;D Ours are the same, rough pavement sections, the occasional stone, and walnuts this time of year the size of lemons. I actually feel I accommodate this variety of challenges better with the suspension set on the soft side with the tires at 30 lbs front and 32-34 lbs rear. Stiffer suspension setting or greater inflation causes the bike to skip/hop rather than accommodating them.
Rocking-M
« Reply #6 on: September 26, 2006, 05:57:15 PM »
So Bob, what we need is a rally bike set up right :)
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #7 on: September 26, 2006, 06:41:44 PM »
No, just a GHOF set up. ;D
AR-Guy
« Reply #8 on: September 26, 2006, 06:51:00 PM »
Rocking-M
« Reply #9 on: September 26, 2006, 06:57:11 PM »
AR, he's got me too :)
Offline hymodyne
« Reply #10 on: September 26, 2006, 07:28:06 PM »
will the 1000gl shocks work on a '72 cb 500?
is there any sort of chart that shows the interchangeability of bike parts between the bikes this forum serves?
something that said what shocks will and won't fit what bikes, which forks are interchangeable, which wheels, etc; something like this on the FAQ page would be a big help
(and yes, I realize that I am not volunteering to do it... 8) )
hym
Offline SohcCBs
  • 76 CB836F 77 GL1000
« Reply #11 on: September 26, 2006, 07:49:10 PM »
The shocks on the GL1000 and CB750 thru K6 are identical.  Don't know about the 500.  They share a number of parts.
I own both a '77GL1000 and '76 SuperSport.
« Last Edit: September 26, 2006, 07:54:00 PM by SohcCBs »
Offline cafehonda
« Reply #12 on: September 27, 2006, 03:38:35 PM »
These are J.C. Whitney junk I think. I have a pair of 76 gl100 dual rate shocks if you are interested in trying them out. I used 'em untill I got new Boge orca's. I'll let 'em go real cheap, since I hardly paid anything for 'em,  if you're interested. P.M. me if you want 'em.
Anger is an energy. May the road rise with you.
73 cb750 cafe
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
« Reply #13 on: September 27, 2006, 04:19:08 PM »
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline aptech77
« Reply #14 on: September 27, 2006, 07:10:15 PM »
HDDDF!!!   :D
Offline nickjtc
« Reply #15 on: September 27, 2006, 07:37:06 PM »
1977 Suzuki GS750
Offline jtb
  • An unlikely
« Reply #16 on: September 27, 2006, 08:38:35 PM »
C'mon, Bob ::) ::) ::)
1977 CB750F
1985 V65 Sabre
Offline aptech77
« Reply #17 on: September 29, 2006, 06:17:54 PM »
 ;D   :D :D :D :D :D :D :D :D    ;)
Offline nickjtc
« Reply #18 on: September 29, 2006, 09:07:01 PM »
HDDDF!!!   :D
Harley Davidson Dude, Dumb F@&k?
Heavy Duty Doting Fan?
Hey Diddle Diddle De cat and de Fiddle?
1977 Suzuki GS750
Offline aptech77
« Reply #19 on: September 30, 2006, 07:32:54 AM »
Harley Davidson Driving Dumb #$%*s  ;)
Offline nickjtc
« Reply #20 on: September 30, 2006, 08:25:45 AM »
I was close, but no cigar. I knew there had to be a Hardly Ableson in there, though..
1977 Suzuki GS750
Offline aptech77
« Reply #21 on: September 30, 2006, 08:32:27 AM »
 ;D
Offline putnaja1
  • '77 CB 550k -Was gonna cafe, but looks cool stock!
    • Jason's Wacky Website
« Reply #22 on: September 30, 2006, 03:58:35 PM »
I wish the high performance shocks for our CB's looked like this bike's shocks:
I guess the closest thing would be the reservoir shocks that came on CB900 DOHC, early '80s..
Play Pinball!
My Gallery!
"The world is divided into people who do things, people who get the credit and people who continually criticize.  Try, if you can, to belong to the first class of people.  There's far less competition"
Offline nickjtc
« Reply #23 on: September 30, 2006, 08:30:06 PM »
Forget the shocks, let's enjoy the young lady.
1977 Suzuki GS750
Offline aptech77
« Reply #24 on: September 30, 2006, 08:39:47 PM »
 :o
