Author Topic: CM400T Newbie - Valve Adjustment & Carb Leak  (Read 2386 times)
Offline a1980cm400t
« on: August 11, 2014, 08:15:53 PM »
Hello Forum.  I am new here and need some advice please.
The story begins after I changed the oil and filter on my 1980 CM400T, I thought I noticed a strange ticking, tapping, knocking sound that I never noticed before.  I posted my question over on the Honda Twins Forum along with a YouTube video demonstrating the noise I thought I was hearing.  Some said to check the valves and so I did this afternoon and made a bigger mess and should have left it alone instead (hindsight is 20/20).
Here is the YouTube video:
https://www.youtube.com/watch?v=S8kxEu3Rnvw
In an attempt to check the valves, I ended up breaking the right side top cover bolt inside the top, managed to get leaking left carburetor, and rpms went from a steady 1200 to now upwards of over 3000 at idle before I turned the engine off.
Using the information on page 3-3 of the Honda Shop Manual:
** I took the bike seat off
** I turned the fuel petcock to off and disconnected the fuel line from the gas tank
** I removed the gas tank from the bike
** I removed the fat tube on the right side of the bike that connects to the top part of the head cover (I don't know what that tube is called)
** I removed the clips that are attached to the frame that guide the spark plug wires to give me enough room to pass the top end cover through the frame
** I removed both top end cover bolts - gasket was in amazing condition so I saved it/re-used it
** I removed the top cover exposing the valves
** I removed the left crankcase cover and shifter
** I rotated the flywheel counterclockwise until the arrow on the flywheel matched up with the T in order to get TDC
** I then worked on the left side exhaust valve adjusting the gap to .006 inches using a feeler gauge
** Next I worked on both the left side intake valves adjusting the gap to .004 inches using a feeler gauge
** I tightened everything down and rotated the flywheel another counterclockwise revolution making sure the arrow lined up with the T and repeated the steps on the right side
** I put everything back together and that's when I over-tightened the right side bolt on the top cover and broke it
** I put the tank back on and reconnected the fuel line to the petcock and turned it on
** I put the broken right side bolt back into its hole and firmly held it in place by hand so I could try running the engine
** Engine started and ticking sound is still there but also now the rpms are not constant at 1200 but jumped up to 3000 before the I cut the engine
** That's when I noticed the right carb is leaking gas under the float bowl by the brass screw above the tiny black hose - I never touched the carbs so not sure why it's leaking???
Everything was working before I decided to play motorcycle mechanic and now I've created a mess for myself all because I wanted to see if I could get rid of that ticking sound. I also read that it's good practice to check the valves every season and since I bought the bike used I thought to myself, well, it's worth shot to check it out.
Should I just have my bike towed to the Honda dealership? Or is this a fix a simpleton like myself can do? Totally bummed out!
PS - I also posted on Honda Twins Forums - I need all the help I can get please - Thanks.!
Offline a1980cm400t
Re: CM400T Newbie - Valve Adjustment & Carb Leak
« Reply #1 on: August 12, 2014, 08:41:10 AM »
Thanks calj737
Can setting the valves incorrectly cause the RPMs to idle too high?
Can setting the valves incorrectly cause the Carb to leak?
Can setting the valves incorrectly cause oil to get into the carb?
So much to learn!
Offline a1980cm400t
« Reply #2 on: August 12, 2014, 08:27:16 PM »
Thanks for the input calj737!!!
Offline faux fiddy
  • bike in a box
« Reply #3 on: August 14, 2014, 03:05:55 AM »
Welcome to the forum.
There is another place you might go to if you haven't yet:
hondatwins.net
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
