Author Topic: Honda cb750 Gas Tank Options  (Read 2194 times)
Offline edosm
« on: September 25, 2006, 05:00:28 PM »
Hello,
Does anyone know if a Honda early 1980's HONDA CB1100F Gas tank will bolt up to a Honda CB750 SOHC...I don't currently have the tank inorder to check...but it looks to have the same front mounting "c" tabs..
Any thoughts
Thanks
"Fix it! and it will Run!"
Hop on a Honda
Re: Honda cb750 Gas Tank Options
« Reply #1 on: September 26, 2006, 10:58:02 PM »
Ma man, dammed good question.
When you find out let me know as I would love a bigger capacity fuel tank for the CB 750 K5.
Mine is due back from the Liquid Overhaulers  on Friday.
Yee Haa I ride again.
Dave
Offline 750goes
  • it will live
« Reply #2 on: September 26, 2006, 11:58:26 PM »
Yes,,I will post a picture of my original tank and frame
the tank on mine was a 750/900/1100F from a dohc, and it fitted fine on the 1976 750F SOHC,
BUT the rear tank mount tabs had been ground off from the frame, where the rear rubber sat..
sorry it may not be a good photo but will give you the idea of the look...
will post it next few minutes
Offline 750goes
  • it will live
« Reply #3 on: September 27, 2006, 12:12:52 AM »
found some of it  .....also the picture of the frame shows where the frame had a plate welded to it to allow the rear of the fuel tank to sit....
Offline 750goes
  • it will live
« Reply #4 on: September 27, 2006, 12:19:36 AM »
heres the one with the frame
