Well it was mentioned to me that while I have the engine torn down, I should remove the cylinder and re-ring it. I also wanted to have a machine shop clean the surfaces an valves. But why would I do all this work to a engine Im only going to put in the other bike I don't need and had planned to sell, This motor claims to have 21k on it, with a full rebuild you think I should just go ahead and keep this one for the 500 swap? The motor I had planned to swap is a 77 with about the same miles, but its still not 100% that I will get it. Guess ill go ahead and build this one no matter what happens, I think its a good idea to get he motor squared away first, then move on from there.
After I pulled everything I notice there is lots of grime, and what appears to be dirt with pebbles in it, or something worse
Anything look out of place? Some pistons have a brown/reddish tint to them, normal?
I got nervous about finding all that loose pebbly grime around the base gasket, so I pulled the oil pan, I figure this is normal sludge for a 40year old bike, but I don't think its as bad as I thought. I visioned at first a lost gear!
Definitely going to take this to a Machine Shop, would new valves and springs be a good idea?
Bad news is the cam chain tensioner, Its gotta crack in one, and the other looks pretty worn. Will the one from the 500 work? I believe those were fine.
The cam chain sits in here, I can eel a very small scratch, and its hard to see, but you might be able to make it out. Should I be worried about this?
Where do you all get Valves and Spring from? Guess I should add those to the list, Valve Guides as well??
