Author Topic: Two 550's and a 500. Home stretch now  (Read 47644 times)
Offline 2strokeTrush
  • Can you get that back together sonny?
Re: Two 550's and a 500. Home stretch now
« Reply #125 on: October 06, 2014, 08:06:26 PM »
Still around guys!!  Just been busy!  Dissembled the new engine donor bike, Not in as great of condition as I thought it would be but I think it would work!  So if I'm going to have The other engine top end machined, I figure I want that for myself!  Will the top end of that 74 fit the 77 engine with only 10k on the motor?  Also I feel like the carbs on the 77 were much lighter then the ones on the 74, are they interchangeable??  I figure its a good idea to keep the 77 carbs with the 77 motor,  but the 74 carbs are free, while the 77 seem to be froze! Ill take a look tomorrow and post some pictures.  I know this is confusing, but I just want to make sure I have the best parts between the two bikes!
If You Aint First Your Last!!
 350F project-http://forums.sohc4.net/index.php?topic=133079.0
500F Project-http://forums.sohc4.net/index.php?topic=135660.0
« Reply #126 on: October 09, 2014, 08:41:30 PM »
Took a look at the 77 550 carbs, defiantly weigh less then the 74's and are a completely different design.  Two carbs seem ok, two are very gummed up!  I believe they are stuck though :(
Little worried about this rust on the rails...
« Reply #127 on: October 09, 2014, 08:49:39 PM »
Hi Tyler,
Those carbs will clean up if you take'em off the rack;it might be best to fully disassemble those and really soak'em good and then you could even possibly paint that rusty areas w/ some good silver paint & small brush later.
Offline rtbmrgl
  • Got Points! Roseville, Ca
« Reply #128 on: October 10, 2014, 10:34:27 AM »
The slides on my 500 were gummed up and  stuck, a little heat from a propane torch should free them. The bowls (almost spelt bowels  :-[) on mine were much worse and the cleaned up fine.
thanks, Mark
Roseville, Ca
Got Points!
1973 CB500 back yard find 1243 orig mi,  http://forums.sohc4.net/index.php?topic=124285.0
1976 CB750 Restoring,        http://forums.sohc4.net/index.php?topic=132997
Offline onetruepunk87
« Reply #129 on: October 10, 2014, 10:45:04 AM »
I cleaned mine with a dip in some pine-sol and water, did a great job cleaning all of the crap out of the bowls and the rust off the steel parts. I polished the aluminum afterwards and replaced the screws.
Offline rtbmrgl
« Reply #130 on: October 10, 2014, 11:50:37 AM »
Pine sol, wow haven't heard of that yet, ill have to try.  Also it will freshen up my garage.
thanks, Mark
Roseville, Ca
Got Points!
« Reply #131 on: October 10, 2014, 01:09:19 PM »
When you soaked'em in Pine Sol did you fully disassemble them and then let'em soak w/ all the parts? heated,full strength, how long ??
Offline ggrant
« Reply #132 on: October 10, 2014, 01:15:45 PM »
Pinesol is what i've used in the past too. Its less tough on the rubber parts. You can pop the whole rack in there for a couple hours.
« Reply #133 on: October 10, 2014, 02:22:46 PM »
Damn.  Never would have thought it would work THAT well.  I'm dunking mine this weekend!
« Reply #134 on: October 10, 2014, 02:25:40 PM »
Did you have a ratio, water to pine sol??
« Reply #135 on: October 10, 2014, 03:26:25 PM »
Probably something like %60 hot tap water and %40 pine-sol. Took all the guts out of each cab and had them in individual Tupperware containers and let the bowls, carb bodies, and lids soak in a big wash basin. Had them in and out of the water a few times over a weekend scrubbing them with different brushes, nylon and brass. FYI it can dis-color any brass pieces (jets, emulsion tubes, etc) if left in too long.
« Reply #136 on: October 10, 2014, 08:33:48 PM »
Well I got bored and had some time....
« Reply #137 on: October 10, 2014, 08:34:57 PM »
Can you get that back together Sonny?
« Reply #138 on: October 10, 2014, 09:35:37 PM »
Clever my friend :)
« Reply #139 on: October 12, 2014, 08:09:39 AM »
Hope you took a lot of pictures during disassembly. It makes putting them back together much easier. Put up some before and after pictures when they're done.
« Reply #140 on: October 19, 2014, 09:12:26 PM »
Hey guys, sorry I haven't updating sooner, to make a long story short I was offered my first " Real Adult" job last week and have been pretty busy since.  The Marina I work at gave me the full time position with benefits and all!  Being just 20 its a big deal to me!....Anyway, back to business, I had the carbs soaking in the Pine Sol and they actually cleaned up better then I expected!  The rust is still a issue on the tube, but they did free up, throttle is 100% free now.  Still had to dig out some sludge from the bowls.
« Reply #141 on: October 20, 2014, 01:11:57 AM »
Don't wanna burst your bubble but the 77 carbs are a nightmare as the pressed in pilot jets gum up for a passtime, as do the jetways in the carb bodies and if you don't run it for a week you frequently end up stripping them. To fit into a 500 or early 550 you need to fit the inlet manifolds, intake rubbers, air box and carb to air box rubbers from the 77 as they are all different
« Reply #142 on: October 20, 2014, 10:03:28 AM »
Oh really? Well that's pretty unfortunate. Hmm I'm gonna need to figure some things out then if that's the case. Any ideas what I could do?  I could always rebuild the 74 carbs and engine for myself. But then that still leaves the 77 untouched. My plan was to also use the leftover parts and make a complete fixable bike on the side to sell in the spring
« Reply #143 on: October 20, 2014, 10:13:07 PM »
You can fit the 77 engine complete and use the early manifolds/rubbers/carbs/airbox, just jet for a 550(which if they are 74 carbs they should be already)
« Reply #144 on: October 21, 2014, 05:04:15 AM »
So use the 77 block, but the 74 manifold and carbs? That engine only has 10k on it that's why i prefer to use it instead of the 74
« Reply #145 on: October 21, 2014, 11:27:46 PM »
Yup, the main lump is the same all the way through the 550 and will fit a 500 as long as you use the RH rear mounting plate from the 550 as the clutch cable mounts on it
« Reply #146 on: November 18, 2014, 08:20:54 PM »
Sorry its been awhile guys. Been crazy around here lately. To summarize, In the past month I have survived a car accident, moved my family from Tennessee to Maryland, Started my Career and became a Uncle!  But I'm back on track now and anxious to get going!  Sanded and painted the frame gloss black and letting that sit for a while to really cure.
« Reply #147 on: November 18, 2014, 08:44:38 PM »
Frame looks good Tyler  8)
Wow,you been doing a LOT of multi tasking stressful life changes lately  :o  ::)
How's your career ?
« Reply #148 on: November 19, 2014, 04:18:54 AM »
How's your career ?
Thanks man!  My career is great. The Marina where I work hired me full time with benefits and a very nice salary for a 20 year old, they also plan to help me financially towards Marine Trade School where I hope to become a Marine Mechanic and then come back and work for the Marina in the Mechanic shop, like you said lots of changes!! ;D ;D
« Reply #149 on: November 19, 2014, 05:18:45 AM »
Marine mechanic sounds Good  8)  ;)
 The boaters want to be sure they can get back to shore under their own steam;pretty tough to 'get out and push' when they're 'dead in the water'  ;D I guess w/ road vehicles that's an option but not w/ boats  :o  :)
