Author Topic: Two 550's and a 500. Home stretch now  (Read 49196 times)
Offline 2strokeTrush
  • Can you get that back together sonny?
Re: Two 550's and a 500. Home stretch now
« Reply #250 on: August 23, 2015, 07:56:38 AM »
If it's only firing on 2 cylinders, I'd expect it to rattle like that. Until you have all 4 running, impossible to diagnose engine noise.
Ill get her on 4 and report back. I appreciate you being Patient with my questions!
If You Aint First Your Last!!
 350F project-http://forums.sohc4.net/index.php?topic=133079.0
500F Project-http://forums.sohc4.net/index.php?topic=135660.0
« Reply #251 on: August 23, 2015, 09:43:44 AM »
Electric Starter working! Yellow wire was corroded behind the bullet connector as if it filled with water at some point and sat there. Simple trim back and replace connector. Thats one down :)
« Reply #252 on: August 23, 2015, 03:54:35 PM »
Good job.   Next....
Offline Restoration Fan
  • My wife will never call me
« Reply #253 on: August 23, 2015, 05:03:12 PM »
I think you're going to find Cal is right regarding 1 & 4 cylinders.  I don't believe in coincidences very often so the fact that the 2 cylinders that share a spark from the same coil aren't working tells me there's a problem somewhere between the coil and the spark plug.  Check to make sure the wires to the back of the coil are making solid connections.  I SWORE that mine were right but then when I pulled them off to re-attach them, I realized that one of them had been pinched and was causing the short.  Once I fixed that issue, those two cylinders started right up.
« Reply #254 on: August 24, 2015, 07:32:10 PM »
Found the front brake issue tonight, Seal is broken. Not sure how it happened but I can only assume it was during installation the lip of the piston must have grabbed it. Anyone have any tips for not repeating this process?
« Reply #255 on: August 24, 2015, 07:47:39 PM »
Have t seen that issue before, not sure how you did that?!
« Reply #256 on: August 25, 2015, 12:30:40 AM »
Super clean, lots of fluid and a slow easy push. If it don't slide in real easy take it out and start again
« Reply #257 on: September 07, 2015, 08:19:51 PM »
Been in a bit of a rut recently between the front breaks and the motor this past few weeks, I had my Carbs rebuilt by a local shop who I should have gone to the first time. Fresh rebuild kits and fuel lines and they look great! This turned out to be the cause of only running on 2 cylinders. Good new is she's firing on all 4 now.
Bad news is that while starting the bike up to test everything I am again hearing the top end tapping noise. I am thinking its a valve hitting the top of the piston. Sounds like its the number 1 cylinder. From what I read this is most likely the cause or possibly the Cam Chain is loose but I doubt it. The carbs also need to be vacuums synced. I attached a video so you can try and hear the noise I'm talking about. Have not run it anymore since.....
And since I had everything available to do so, and was feeling down about the ticking noise and not being able to ride I decided to see what she would look like with everything back on :)
« Reply #258 on: September 07, 2015, 08:28:43 PM »
Wow!! Gorgeous bike!!!!  :o :o :o :o :o :o :o
« Reply #259 on: September 07, 2015, 08:30:00 PM »
It might just be a loose cam chain.
Offline goldarrow
  • one day, i'll be an
« Reply #260 on: September 07, 2015, 08:37:57 PM »
Check valve clearance again
CB550 K0
« Reply #261 on: September 07, 2015, 11:31:00 PM »
That sounds like exhaust gasket leak to me
« Reply #262 on: September 08, 2015, 07:49:19 PM »
Tyler - use the "Mechanics Stethoscope" and locate the noise. It could easily be an exhaust leak too. If your valves are properly adjusted, they're not hitting the piston. Especially at idle. That's nearly impossible with a half decent running motor by the way...
More likely cam chain, vacuum synch or an exhaust leak. But the screwdriver in your ear will tell you best which it is.
Cam chain is tight, and I replaced all the exhaust gaskets so I don't know how there could be a leak. I will check the valve clearance again though. Bike starts right up but that noise has me worried....
« Reply #263 on: September 08, 2015, 08:05:40 PM »
Just because you replaced the gaskets, doesn't mean the flange is snug.
that makes sense, Ill check that out tomorrow as well. Just sucks because Im so close and this is holding me back, but i would rather be careful and not mess something up inside the engine.
« Reply #264 on: September 08, 2015, 10:29:54 PM »
I said it before, i sold a 550 and later fitted an aftermarket exhaust for the buyer, when he brought it back for a service i spent 2 hours repeatedly doing the tappet clearances to find that one exhaust flange just needed nipping up by about 1 turn on each nut( that had new gaskets as well)
« Reply #265 on: September 09, 2015, 09:41:37 AM »
Alright I'll check that out to!
« Reply #266 on: September 15, 2015, 08:31:35 PM »
Thank you to everyone for the tips, It was indeed valve clearance issues and a full carb vacuum sync that did the trick! no more tick!  sounds good and quick throttle response! Only issue I am having now is the petcock not flowing on the right side outlet.
 I have a 500 tank running a 500 petcock with the 2 outlets. The right one is hardly dripping starving the bike of gas and causing issues. Tomorrow Im going to clean out the new petcock and see what happens. Dos anyone have any other tips or possible causes??.
Doing the whole Tag and Title thing tomorrow so expect a few more daytime pictures!
« Reply #267 on: September 17, 2015, 09:46:30 AM »
Sometimes with low fuel in tank one side will stop first, no idea why but have had it happen.
Feels good to get it finished tho' don't it
« Reply #268 on: September 17, 2015, 10:06:16 AM »
The tank was full and when I disconnected the lines still only one side would flow and it was leaking in the off position as well. With a full tank and the lid open or closed. Never buying K and L petcocks again. I have overnighted a honda one for tomorrow so we'll see if that helps!
« Reply #269 on: September 17, 2015, 06:29:19 PM »
I've heard of duel outlet petcocks not equally flowing, has to do with physics.  Cal can explain.....
« Reply #270 on: September 17, 2015, 07:35:35 PM »
Paging Professor Cal . . .  ;)
« Reply #271 on: September 18, 2015, 05:02:30 AM »
The lay answer is: You're not holding your mouth right. Class dismissed.
Confused
« Reply #272 on: September 18, 2015, 05:12:56 AM »
« Reply #273 on: September 18, 2015, 06:42:18 AM »
I love that nice blue Tyler  8)
« Reply #274 on: September 18, 2015, 09:44:22 AM »
my point exactly.
Care to explain or ?????
