Author Topic: cb550 rear wheel stud bent  (Read 913 times)
Offline stereosilence
  • 1975 CB550K
« on: August 16, 2014, 03:11:56 PM »
Somehow, one of the four studs on my rear wheel got bent. Are these replaceable? Please advise.
Re: cb550 rear wheel stud bent
« Reply #1 on: August 17, 2014, 12:12:09 AM »
#4 is rubber,the studs unscrew from the housing with some effort,try a little soft flame heat around the alloy if its real tight.
  • 1975 CB550K
« Reply #2 on: August 17, 2014, 11:21:31 AM »
#43. So do you just clamp down on this with vise grips and torque?
  • 1975 CB550K
« Reply #3 on: August 17, 2014, 02:26:35 PM »
Sounds tough. I think I'm going to get a shop to install my wheel bearings, so I may see if they will replace the stud. I don't have the tools it sounds like and I don't want to mess up the powder coat.
  • 1975 CB550K
« Reply #4 on: August 18, 2014, 06:42:21 AM »
Yeah. I'm a little worried about shearing it (although it is a pretty big stud). Also, I'm not sure how I would hold it still.
Should it be perpendicular to the part in the wheel or the part that is bent?
  • 1975 CB550K
« Reply #5 on: October 02, 2014, 11:29:41 AM »
I ended up using a double nut and a regular wrench. It came out much easier than I thought it would.
