Author Topic: mounting modern frame sliders on a 750K?  (Read 1344 times)
Offline grumpy
  • ..... '73 750K3 .....
« on: August 25, 2014, 07:50:36 AM »
Has anyone ever tried it?
I was thinking they'd be pretty easy to bolt on at the motor mounts.
Seems like a good spot to have them - could save the stator or points in a fall...
« Last Edit: August 25, 2014, 07:55:39 AM by grumpy »
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
Re: mounting modern frame sliders on a 750K?
« Reply #1 on: August 25, 2014, 11:34:20 AM »
I could have used this... I think they would stick out like a sore thumb, though.
--Evan
1975 CB750K "Rhonda"
« Reply #2 on: August 25, 2014, 11:53:40 AM »
I think for the CB750 you need at least 2 points of mounting to keep them from bending. Your one pointers would be so long from the frame they would bend.
Relatively cheap and proven case guards do a great job of guarding the cases. Mount with 2 or 3 points.
Offline grumpy
« Reply #3 on: August 25, 2014, 06:18:52 PM »
I actually have a set of the 3 point case guards but I can't get them to fit well on my bike (750K3).
maybe I have a 77/78 set...
anyway, I thought maybe the modern types would work. they're certainly easier to mount.
they'd likely look out of place, though.
« Last Edit: August 25, 2014, 06:27:40 PM by grumpy »
Offline bjbuchanan
« Reply #4 on: August 25, 2014, 07:14:42 PM »
Get some 2 point guards, they will look less funky.
« Reply #5 on: August 26, 2014, 12:53:24 AM »
I'm thinking about frame sliders as well, there has to be a way of making them look good, maybe welding mounts for them under the cases on the frame rails so the only protrude a small amount, just enough to stop the covers hitting the ground, black one would disappear nicely if done properly... ;)
« Reply #6 on: August 26, 2014, 02:45:13 PM »
Should be easy just flame cut a piece that goes between. The two motormounts,  then weld a boss on that, drilled and tapped for slider..
« Reply #7 on: August 26, 2014, 02:54:54 PM »
Yes, it wouldn't be hard, the trick is to make it look like it either belongs or doesn't stick out like dogs balls on a canary.... ;D
Offline hondaman750
  • The value of life can be measured by how many times your soul has been deeply stirred.
« Reply #8 on: August 26, 2014, 04:35:27 PM »
Are you willing to part with those guards grumpy?
Don't let the little red bar on the tach stop you from reaching 12k they love it! Mine does
