Author Topic: Check out what this PO wired up !  (Read 3420 times)
DH
Re: Check out what this PO wired up !
« Reply #25 on: August 29, 2014, 03:44:05 AM »
I just did that on my 750, except with the 3 fuse setup. Dave, do you notice better
performance of electrical components since that modification? I did on my bike.
« Reply #26 on: August 29, 2014, 04:29:51 AM »
the main thing on all of the electrical system on anything is to have all the connections what and where ever they are clean and tight,if you've noticed an improvement from just doing a fuse repair have a look at the entire loom,all the connectors must be clean and tight,dissemble the gang plugs and be sure they are clean where you cant see, I never noticed any improvement apart from the fact that most petrol stations don't even carry glass tube fuses anymore?i always have a couple on board anyway plus ive never liked a metal cased fuse holder it just seems wrong?mine was corroded so I just pissed it off,too easy!
Offline FillionJ
« Reply #27 on: August 29, 2014, 03:29:08 PM »
That's awesome, when I get my sub harness in maybe I'll wire that up, I have trouble
Finding those little glass fuses as well
Offline FillionJ
« Reply #28 on: September 10, 2014, 06:00:39 PM »
K so I got my panel in and it seems all the wiring is ok EXCEPT the fuse is cut off.. I'm sure it's not hard to wire it up to this but can someone advise me ?
Offline FillionJ
« Reply #29 on: September 10, 2014, 06:08:34 PM »
Offline FillionJ
« Reply #30 on: September 10, 2014, 06:09:00 PM »
Sry I forgot to attach the picture...
Offline FillionJ
« Reply #31 on: September 10, 2014, 06:21:02 PM »
What do u mean upside down ? As in the back?
Offline FillionJ
« Reply #32 on: September 10, 2014, 07:10:26 PM »
Ah k perfect I follow now ! Maybe I can make it to canadian tire before they close !  Now to figure out where this red one belongs.
Offline FillionJ
« Reply #33 on: September 10, 2014, 07:13:04 PM »
I don't see another red
Offline FillionJ
« Reply #34 on: September 10, 2014, 07:15:00 PM »
Actually would it go to the starter solonoid also?
Offline FillionJ
« Reply #35 on: September 12, 2014, 04:08:47 PM »
Offline FillionJ
« Reply #36 on: September 13, 2014, 07:09:05 AM »
Of course ! I just found this in the shop so figured I'd slap it together for now!
