All R.C. angle drives can use a distributor or a magneto. The base is a VW design. The original setup came with a Mallory duel point VW distributor. You could also get a magneto for more money. Either way the distributor or magneto had to be setup to run counter clockwise. The distributor weights, plate and point's cam were reversed. The magneto had to be setup " phased " for reverse rotation.
Here is a Mallory super mag III that i have with a VW base drive. In order for me to use it with the R.C. drive i have it will have to be phased for reverse rotation. Also the magnets have to be changed because they are too powerful for the R.C gear drive. It will need to be converted to a super mag II.
Here is my KZ R.C. angle drive setup......
And the gear drive shaft " KZ " with the gear. " DO NOT LOOSE THE GEAR ! " as they are rare as a DODO bird !
They are not an off the shelf part !
A JOE HUNT magneto with the VW drive base.....
