Author Topic: Patina Hyena - 550/650 674cc Hybrid Cafe Build  (Read 349049 times)
Offline DaveBarbier
Re: Patina Hyena - Dave's '78 CB550K Cafe Build Thread
« Reply #175 on: October 12, 2014, 03:06:12 PM »
So the head gasket is actually in my lap. If it has been torqued down can it go back on or should I get a new one?
1978 Honda CB550K
« Reply #176 on: October 13, 2014, 01:28:59 AM »
itll be ok,ive reused plenty.
Offline Franky
« Reply #177 on: October 14, 2014, 06:59:52 AM »
Hi DaveBarbier!
Keep asking those questions and being so thorough - I'll be reassembling my CB550 engine soon, so your thread will be of great help :-)
1974 Honda CB360T Stock
1974 Honda CB550 K0 Stock
1977 Honda CB550 K3 Cafe - never ending build :)
1988 Honda Dax ST50 Cafe
1997 Honda Benly 50S Stock
Check out my "Yamaha R6 fork on a CB550 made easy" thread:
http://forums.sohc4.net/index.php?topic=118983.0;all
Offline DaveBarbier
« Reply #178 on: October 14, 2014, 08:35:03 AM »
Hi DaveBarbier!
No problem Franky, let me know if you have any photo requests. If I haven't assembled that part already or if I have a picture that I haven't posted I'd be happy to oblige.
1978 Honda CB550K
Offline DaveBarbier
« Reply #179 on: October 16, 2014, 04:51:23 PM »
Work's been pretty busy lately so haven't been able to button things up yet. But tonight I got the clutch on and clutch cover sealed up. Went pretty smooth.
1978 Honda CB550K
Offline DaveBarbier
« Reply #180 on: October 19, 2014, 05:16:12 PM »
More progress today. Put the cylinders and head back on with the cam and sprocket. Next seems to be the final buttoning up.
The chain went on the sprocket with ease (it's described well in the FAQ) but then it was a bear trying to get it on the cam. I used a little prying action with a screw driver and then it popped on just fine. Maybe because it was a new chain and didn't stretch yet.
Just from another post I shoved rags down the cam chain area. If a little bolt jumped down there it would suck. I urge you to do the same.
1978 Honda CB550K
Offline Tews19
  • I am no
« Reply #181 on: October 19, 2014, 06:01:50 PM »
Will you be putting anything on the pucks to help seal/keep them from moving?
1970 Honda CB750 survivor.
Offline DaveBarbier
« Reply #182 on: October 19, 2014, 07:42:18 PM »
I'm not sure. From factory there isn't anything helping them. I got OEM replacements so I wouldn't think I'd need anything. I'll do some more research. Any suggestions?
1978 Honda CB550K
Offline goldarrow
  • one day, i'll be an
« Reply #183 on: October 19, 2014, 08:02:36 PM »
Around that area where the pucks seat, I usually clean with acetone, then smear a bit of hondabond on it.  Seat the pucks and wrap everything up.
CB550 K0
Offline DaveBarbier
« Reply #184 on: October 19, 2014, 08:25:31 PM »
I don't have Hondabond, but I do have a Permatex hardening gasket sealer. Will that work? I also have a non hardening one.
1978 Honda CB550K
Offline Bootsey
« Reply #185 on: October 19, 2014, 08:28:59 PM »
Just use a light coat of the same stuff you sealed the crankcase with.
Offline DaveBarbier
« Reply #186 on: October 20, 2014, 04:38:08 AM »
I used Loctite 518 and that's an anaerobic sealer designed for zero tolerance aluminum flanges. It won't cure if used on the rubber nut sealing pucks. It'll just stay a gel and could get washed off by the oil.
1978 Honda CB550K
Offline DaveBarbier
« Reply #187 on: October 20, 2014, 05:12:28 AM »
Found Hondaman talking about using Permatex non-hardening stuff around the rubber sealing pucks. I'll do the same.
I also see he used more of that sealant around the cam chain tunnel on the head gasket surface. I definitely didn't do that, haha. He seems to use sealant in many strategic areas so I'm curious how leaky mine will be...
4. Add sealant around the whole cam chain tunnel. Honda did: I'm sure it was important!
Are you using Permatex no.2? The same stuff as what you use with the pucks under the cam tower?
I was considering spraying the whole head gasket down with Copper Spray a Gasket, but am open to a different approach if you have found a better solution.
Oh, and I'll PM you for a set of those o-rings for my K4.
Thanks
Dan
Yeah, their non-hardening stuff. I really wish I could find some FelCoBond, but they don't sell it around here anymore. That stuff was excellent for this task, especially on the old CB/CL72/77 engines which had nothing sealing these passages but the head gasket. They often leaked, more than a little. It strongly resembled rubber cement, but was oil- and gas-proof.
1978 Honda CB550K
« Reply #188 on: October 20, 2014, 12:39:21 PM »
I like to use the hardening stuff around the peaks of the cam chain tunnel,only nip those 6mm screws down plus a little,the pucks you can use just about anything I use the non hardening there.
Offline DaveBarbier
« Reply #189 on: October 20, 2014, 01:42:19 PM »
Ok thanks, I'll definitely do the non-hardening for the pucks. Do you think it's a problem that I didn't put any sealer by the cam chain tunnel? Is that a requirement or just for precaution? I also didn't add any sealer on the o-rings by the base gasket or head gasket.
1978 Honda CB550K
Offline Tews19
  • I am no
« Reply #190 on: October 20, 2014, 03:50:28 PM »
I had permatex for all the main gaskets. Not sure how well it worked as I had a nasty head gasket leak which I'm currently fixing. I am also in the process of removing the permatex from where the pucks were. It's a PITA to remove!
Offline DaveBarbier
« Reply #191 on: October 20, 2014, 06:53:19 PM »
That's another thing I've been thinking about. If I did/do seal this up like Fort Knox how painful it'll be when I take it all apart again. I've used the Permatex hardening stuff and acetone and even mineral spirits works alright removing it.
Thanks guys, I'll post pictures of what I end up doing.
1978 Honda CB550K
Offline DaveBarbier
« Reply #192 on: October 21, 2014, 02:13:33 PM »
Just installed the rubber nut sealing pucks. I used some of this:
Laid a small bead in the groove. Then placed the pucks and squished and twisted them down...
Then ran my finger to clean and smooth the remaining sealant.
1978 Honda CB550K
Offline eigenvector
« Reply #193 on: October 21, 2014, 02:19:13 PM »
To be totally honest, I've never sweated it.  I lost one of those things, so i manufactured a new one by cutting it out of a old KLR650 rear tire inner tube.  It didn't leak, move, shift, or even sit cleanly in the hole.
I'm not recommending that of course, but I just don't worry about them, they seem to seal just fine on their own.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Offline calj737
  • I refuse...
« Reply #194 on: October 21, 2014, 03:42:12 PM »
Dave- not to be an "alarmist", but that cam looks a wee bit worn from the pictures. Did you have that examined with an instrument for face wear or runout? Rockers good too?
Perhaps this was all covered weeks ago (pages ago in the thread) and it's moot now?
Offline DaveBarbier
« Reply #195 on: October 21, 2014, 03:52:59 PM »
No, please, alarm away. I posted a picture of the journals and cam earlier and it was said that they were ok. It feels super smooth. I know it would be best to replace the head but that's not money I have right now.
What do your Elven eyes see? I didn't check the cam with any instrument... Aside from my finger nail.
1978 Honda CB550K
« Reply #196 on: October 21, 2014, 04:27:36 PM »
they often look like that,it has no gouges or groves itll be ok.
Offline calj737
  • I refuse...
« Reply #197 on: October 21, 2014, 04:33:15 PM »
 It could just be the picture, but I see "burnishing" on the lobes. That is an indication of wear, but not always worn.
What you need to verify is the lobe across its width is flat, and that the rocker travels along the lobe without peaks and valleys.if you were diligent and kept your rockers in sequence to their original location, whatever wear occurred will still be "mated or matched" lobe-to-tappet, so it's less of an issue. But I see small disfiguring in the edge of lobes that would make me want to inspect them closely.
Recently, I bought a used cam and the seller indicated no wear, very good condition. Uh, not so much. Upon receipt, it looked like yours, and an instrument validated .03 of wear on the lobe edge/edge. Completely unusable. Maybe ok to get a motor to run, but not for a rebuild/major project.
Pictures can be deceiving, so this may all be unnecessary. I'd just have a good session at least with quality Verviers and measure top to bottom in each lobe at 3 points along the overall length. It may be sufficient to determine wear or no wear. (Since you're instaled already).
Offline DaveBarbier
« Reply #198 on: October 21, 2014, 08:48:00 PM »
Yup, I never removed the rockers so they're still mated. I'll measure them with my digital calipers tomorrow. If it's out of spec can the cam be replaced alone or do the rockers have to be replaced too? Or the head machined?
1978 Honda CB550K
Offline calj737
  • I refuse...
« Reply #199 on: October 22, 2014, 04:11:31 AM »
The cam does not require the rockers be changed, but the rockers and the cam usually wear together. So...
Head should not require any machining to change the cam. The bearings and journals were fine, right? Just make sure if you get a new/used cam it's better than yours and you I don't get crap for your troubles.
