Author Topic: Patina Hyena - 550/650 674cc Hybrid Cafe Build  (Read 368290 times)
Offline DaveBarbier
Re: Patina Hyena - Dave's '78 CB550K Cafe Build Thread
« Reply #400 on: May 08, 2015, 09:26:03 PM »
Dumb Question: Any unshielded wiring coming/going to the taillight (near grommets, etc.)?
Nope, all wiring is very well shielded with good crimped and soldered connectors and all holes in sheet metal (custom electronics tray) are rubber grommeted. I'll just play it by ear and see if it blows again. Not a dumb question at all. I get caught doing stupid things all the time, haha.
1978 Honda CB550K
Offline DaveBarbier
« Reply #401 on: May 08, 2015, 10:09:46 PM »
Seat update. I originally made a two up seat, but since I'm so alone and scared and sad and cold...sssoo ccoold, I decided to make a single "rump bucket" seat. 1/4" round bar skeleton, 16 gauge sheet steel for the seat pan and 18 gauge for the hump and front part, closed cell and open cell foam for padding with leather upholstery, patina'd to match other tins.
Making frame:
Welding pan:
Coming together:
Wheeling up the hump:
Welding hump (nervous! Don't want to eff it up!)
Welding the seam and grinding it back down:
Finished grinding. Not perfect, but patina will hide a lot:
Painted all but the hump:
Foam:
Leather parts traced out with chalk then cut out:
Sewn together:
Finished. Stretched on with some spray adhesive and pop riveted the underside:
Happy with the result!
1978 Honda CB550K
« Reply #402 on: May 08, 2015, 10:59:43 PM »
I like the metal fab work. The upholstery is very impressive - you may try to tighten some of the corners so it takes in some of the small slack areas. Better than anything I could do!!
Offline DaveBarbier
« Reply #403 on: May 09, 2015, 04:16:08 AM »
Thanks! Yeah I know it's a little baggy in some areas. I've upholstered things before but with less "shape" than this. My old seat was pretty plain. A learning experience for sure.
1978 Honda CB550K
Offline Maurice
« Reply #404 on: May 09, 2015, 04:22:40 AM »
Dave - what are you using for a rear muffler hangar? Picture is too far for my old and worn out eyes...
Was going to ask the same. What's the header?
Impresive work, man, looks great.
I'm asking that but sadly time to sell the 550...
Offline DaveBarbier
« Reply #405 on: May 09, 2015, 05:28:25 AM »
Thanks guys. The hangar is hard to see...almost impossible to see in this picture...but it's a piece of steel going from the clamp bolt up to where the brake actuator is. Held in place by another nut and bolt.
I know having the hangar more towards the end would provide more support but it's fine as is. Very sturdy.
The header...I don't know, haha. Came with the bike. I think it's a MAC? That's just something others have said when I asked. It was full of holes and pretty rusty, but I had it welded up and then wrapped it because it looked like a pile of garbage. But it's good now!
1978 Honda CB550K
« Reply #406 on: May 09, 2015, 07:37:37 AM »
1978 Honda CB550K
I hope that didn't come off the wrong way.  The form of the seat is excellent.
Offline DaveBarbier
« Reply #407 on: May 09, 2015, 08:39:52 AM »
1978 Honda CB550K
No, not at all! Thanks for the compliment!
1978 Honda CB550K
« Reply #408 on: May 09, 2015, 11:05:55 AM »
1978 Honda CB550K
1978 Honda CB550K
Excellent.  I really appreciate the work that you put into that seat.
Offline arogers88
« Reply #409 on: May 09, 2015, 06:04:14 PM »
Seat looks killer... Have you been enjoying this great CT riding weather?
Offline DaveBarbier
« Reply #410 on: May 09, 2015, 09:34:07 PM »
Definitely, today was pretty perfect. Open jacket with t-shirt, very comfortable.
Thanks man!
1978 Honda CB550K
Offline DaveBarbier
« Reply #411 on: May 23, 2015, 09:19:20 AM »
From riding around lately I've noticed that my bike will often stall when coming to a quick stop or a normal stop that's down hill. All other stops don't make the bike stall. I'm guessing my float height is a little low (momentum sloshing the fuel in the bowls forwards too much enriching the pilot circuit). With the clear tube method my bowls are all the same. About 4mm below gasket surface.
Should I raise the level another mm or so? Could something else be causing this? Doesn't matter if the motor is hot or cold, and I have a full tank of fuel.
1978 Honda CB550K
Offline Tews19
  • I am no
« Reply #412 on: May 23, 2015, 09:51:01 AM »
I had low floats. Adjusted last night but even being lower than that I never had the bike stall. I'm at about 200 miles since the build was completed.  Maybe your idle is to low?
1970 Honda CB750 survivor.
Offline DaveBarbier
« Reply #413 on: May 23, 2015, 12:59:11 PM »
RPM is about 11-1200. I had a stalling issue when I'd come to stops randomly but I raised it and it isn't a problem anymore. Maybe these problems are related and me raising the idle is just masking it but I don't know.
My opinion: you don't want the fuel ANY higher than that. In fact, I'd probably lower it.
Still could be a mixture issue or a fuel level issue I guess. Maybe I'll try lowering fuel level a millimeter or so.
1978 Honda CB550K
Offline Tews19
  • I am no
« Reply #414 on: May 23, 2015, 01:07:22 PM »
What size slow jets? Also maybe do only 1 turn out on the air mixture screw?
Offline DaveBarbier
« Reply #415 on: May 23, 2015, 01:18:40 PM »
IMS is 1 turn out. Slow jets are 45. Stock is 42. Also, they're Keyster jets because the PO drill out the originals. That could be an issue but it doesn't feel or smell rich and plugs aren't black, they seem pretty good. I'm also a novice at diagnosing lean/rich conditions, haha.
1978 Honda CB550K
« Reply #416 on: May 26, 2015, 01:13:59 PM »
+1, that is too high...from your pic, looks like fuel level is right at the gasket
Offline DaveBarbier
« Reply #417 on: May 26, 2015, 02:00:15 PM »
Really? To me the picture seems like it's below the seam. Anyway, I'm out with the bike right now and am measuring all levels again. They are all exactly 3mm below the seam. I will lower the level (raise the float height) by 1mm across the board. Giving me 4mm from the seam.
After a test I'll come back with results.
1978 Honda CB550K
« Reply #418 on: May 26, 2015, 02:19:36 PM »
I guess I dunno...could be a tricky angle or I am not familiar with those carbs.  Anyway, I would definitely try a lower level before higher.  That is the benefit of the clear tube method...gives you a visual guide to what is actually going on inside the carb...but this also makes me miss working on Holley 4 barrels...external  screwdriver float adjustment with a sight glass/plug would really kick ass on these!
« Reply #419 on: May 26, 2015, 02:29:28 PM »
say that again!
easy to do on the internet
Offline DaveBarbier
« Reply #420 on: May 26, 2015, 02:32:55 PM »
Yeah after you guys said to lower it I can see what you mean after looking around on other posts. And besides, if I suspected the pilot circuit being enriched by the forward slosh of a hard braking bike, the raising of the fuel level in the bowls would be counterintuitive. Lowering would make much more sense.
And as far as the sight glass and external float adjustment...my god, that would be so helpful. But then I wouldn't become a pro at removing and installing my carb rack...
1978 Honda CB550K
Offline DaveBarbier
« Reply #421 on: May 26, 2015, 04:22:02 PM »
Ok, now they're all like this, which is exactly 4mm from seam. Would you guys still say it's too high or is this satisfactory?
Edit: a picture would help...
1978 Honda CB550K
« Reply #422 on: May 26, 2015, 07:03:37 PM »
That's right where I would put them...real and only test is how it runs now...
As far as I know the 3-4mm below the bowl gasket spec was strictly only for early cb750 carbs, although I, and many other have used it successfully on many other carb sets...even Mikuni's
Offline DaveBarbier
« Reply #423 on: May 26, 2015, 07:08:04 PM »
True, but considering it ran fine before except the stalling when coming to a quick stop or a stop down hill. That problem might not even be fuel level related. We'll see. Thanks guys
1978 Honda CB550K
Offline DaveBarbier
« Reply #424 on: May 30, 2015, 07:17:09 AM »
Been doing some tests and it seems like that solved the issue. I've been doing some hard stops down hill and it won't stall. Thanks guys, I'm going to keep an eye on it. Now to track down a buzzing between 6500-7250 rpm. Probably cables vibrating against the headlight bucket but when I play with them it doesn't help, oh well. Minor problem.
1978 Honda CB550K
