Author Topic: Patina Hyena - 550/650 674cc Hybrid Cafe Build  (Read 340718 times)
Offline calj737
  • I refuse...
Re: Patina Hyena - Dave's '78 CB550K Cafe Build Thread
« Reply #1175 on: December 23, 2015, 06:18:33 am »
vapor blasting is a "peened" finish so despite the lustre, it should be equally resistant to staining. And both finishes should clean equally well.
Offline DaveBarbier
« Reply #1176 on: December 23, 2015, 06:23:26 am »
Haha, ok then, looks like I'm good to go!
Offline DaveBarbier
« Reply #1177 on: December 28, 2015, 07:46:24 am »
My valve/cam cover was blasted with the rockers and shafts in place. I'm thinking I want to remove them to clean debris and such, but they're a real pain to remove. It's mainly the pins holding the rocker shafts which is the hardest part. I've read about people cracking the cover while trying to remove them using heat and hammers.
How safe is using a hydraulic press? Do you think I should remove them even though they all slide well and there doesn't seem to be any grit in there from blasting?
« Reply #1178 on: December 29, 2015, 09:32:51 am »
I use a press Dave. Just support the piece properly. They come out with a "bang"......be prepared. ;D
Offline DaveBarbier
« Reply #1179 on: December 29, 2015, 02:38:36 pm »
Haha, sounds fun. I'll give it a shot.
Offline DaveBarbier
« Reply #1180 on: February 08, 2016, 07:22:58 am »
Just got the carbs from Godffery's Garage. CR26 Specials. I love new carbs. Also got K&N pods and the remote idle adjuster. Intake and exhaust is now taken care of, yay!
Offline calj737
  • I refuse...
« Reply #1181 on: February 08, 2016, 07:39:25 am »
Check for fitment with your stock petcock, Dave.
Offline DaveBarbier
« Reply #1182 on: February 08, 2016, 08:44:34 am »
Yeah, that's something I need to do. I'll have to do some measurements but it seems like I won't really know the exact placement until I can get the 650 in the frame and see how/where the carbs sit. I don't yet know the length of the rubbers to the head or exactly how the top end sits in the 550 frame.
But because the 550 has a longer intake tract than the 650 and the petcock sits between the head and carbs, I suspect there will be interference issues.
Offline Blackfin5
« Reply #1183 on: February 08, 2016, 02:37:37 pm »
Dave.  I have the same CR26 set up from Godfrey.  I can assure you that the stock petcock, as Cal infers, is too small for the fuel line needed for the CR26s.  I stuck with stock, but had to rig a sleeve in order for it to fit the larger ID hose.  My first attempts leaked.
« Reply #1184 on: February 08, 2016, 03:06:08 pm »
On my hybrid 550 frame/650 engine build, I am anticipating interference issues -- note I am also using a 750F tank.  I am using a Pingle petcock and relocating it.
Dave, I think regardless of the tank difference, you will likely have interference issues.  I think Kevin's or Jim's re-route is the solution.
Offline DaveBarbier
« Reply #1185 on: February 08, 2016, 03:43:34 pm »
I was looking into Pingle petcocks a few months ago when I had a issue which felt like fuel delivery (it ended up being a bad condenser). Of the one's I saw they were pretty expensive, but I could see what Blackfin says being an issue.
I'll just play it by ear and see what needs to be done.
Don, I don't think I'm familiar with Kevin or Jim and their re-route solution. Can you link something? For yours do you mean that you'll end up welding a new bung?
« Reply #1186 on: February 08, 2016, 04:30:18 pm »
Don, do you know if the pingles fit the F0/F1 tanks...?
« Reply #1187 on: February 08, 2016, 04:40:34 pm »
The Pingle I have does not fit the F0/F1 bung.  I am having it relocated to clear the valve cover and carburetors.
« Reply #1188 on: February 08, 2016, 04:51:07 pm »
Jim's aka FunJimmy's solution is shown above.  http://forums.sohc4.net/index.php/topic,27159.0.html
Kevin aka Blackfin F1 Blaster Build http://forums.sohc4.net/index.php/topic,131956.0.html
« Reply #1189 on: February 08, 2016, 04:51:23 pm »
I thought so.... ;)
Offline calj737
  • I refuse...
« Reply #1190 on: February 08, 2016, 07:52:48 pm »
I was also referencing that he's using a 650 motor, which the intakes are different too, right?
Offline DaveBarbier
« Reply #1191 on: February 08, 2016, 07:53:13 pm »
Thanks Don. After seeing those I'm not too concerned. Yeah, I'll probably have to alter something somehow but there's a couple of routes I could take.
Offline Blackfin5
« Reply #1192 on: February 08, 2016, 08:32:03 pm »
I ended up using a smaller bodied petcock and slightly shimmed the front tank mounts to move the tank off the carbs about 1/8th in.
Offline DaveBarbier
« Reply #1193 on: February 16, 2016, 05:25:14 am »
Just picked up an old (probably late 50's or early 60's) little Craftsman 618 lathe. It's pretty sweet and in great shape. Those of you with lathes, is a 6x18 too small for motorcycle work? What's the average size of work you have chucked in there?
Next up is either a milling attachment or a standalone mill/drill press. Fun times.
« Reply #1194 on: February 16, 2016, 05:34:30 am »
That is sweet.
You will be able to do a lot for your bike when you have the tooling  ;D
I have Logan 210, pretty much the same size.  Can't imagine life without it anymore.  Of course I would take bigger lathe but I miss metric threading more than size.
Offline DaveBarbier
« Reply #1195 on: February 16, 2016, 06:00:55 am »
That Logan looks like a really nice machine, but I have no idea what I'm talking about, haha. This 618 is meant to cut standard threads but apparently with changing the gears out you can cut metric threads. It's not really a metric thread but it's close enough. For a short piece they say there's no issue but the longer you go the more off it is. Like nothing longer than 1 foot of threads which isn't a problem for me.
Offline calj737
  • I refuse...
« Reply #1196 on: February 16, 2016, 07:23:06 am »
...but the longer you go the more off it is.
True of any machine. Rigidity is key. And the closer to the headstock you work, the more rigid your part is, the better the part machines. If you were to cut a long piece of rod with threads, expose only enough of the rod to cut threads, leaving the extra in the headstock (I'm assuming you can load from the backside with that dude?).
And you can still cut metric threads with that. But not all the way. Simply use an SAE pitch as close as possible to "rough" your threads (maybe 2-3 passes only), then switch to a metric die with the correct pitch. That way, your threads are square to the rod, and the die is perfectly aligned/centered on the rod.
Offline DaveBarbier
« Reply #1197 on: February 16, 2016, 09:11:53 am »
Ah, I didn't think of going partial threading and then finish with a die. I like that. I'm not sure if I can load from the rear, I think so, but I have to verify that. It came with the original manual and exploded view with part numbers, so that's awesome.
And I've been reading and watching about how important rigidity is. Not only for the finish and accuracy of the piece you're turning, but for the reliability of the lathe.
It's a whole new world I've entered into, it's insane.
« Reply #1198 on: February 16, 2016, 09:25:49 am »
Prepare for custom parts orders. ;)
Offline DaveBarbier
« Reply #1199 on: February 16, 2016, 12:04:47 pm »
Now taking orders for small chips and swirls of metal, various sizes.
