Author Topic: Patina Hyena - 550/650 674cc Hybrid Cafe Build  (Read 407995 times)
Offline SF
  • I burn gas very well
Re: Patina Hyena - Dave's '78 CB550K Cafe Build Thread
« Reply #1550 on: May 19, 2017, 05:01:50 PM »
That's petty trick
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
Offline DaveBarbier
« Reply #1551 on: May 19, 2017, 05:02:11 PM »
and now you will still know how fast you are going while wheelying!
Haha, true but I hope I never wheelie this thing!
Online seanbarney41
« Reply #1552 on: May 19, 2017, 05:22:59 PM »
might want to keep that brake pedal covered with your foot during certain throttle positions then lol
Online seanbarney41
« Reply #1553 on: May 19, 2017, 05:24:45 PM »
nahhh, you be alright.  These bikes have all the weight right on the front.
Offline DaveBarbier
« Reply #1554 on: May 19, 2017, 05:38:14 PM »
Haha, thanks for the tips and assurance. Now, I'd like the bike to be able to do one, but I never intend to ;)
Online seanbarney41
« Reply #1555 on: May 19, 2017, 06:01:15 PM »
nothin' wrong with a stretch of open road and a little one wheel celebration of the beauty of life
« Reply #1556 on: May 19, 2017, 08:45:01 PM »
Offline DaveBarbier
« Reply #1557 on: May 20, 2017, 04:17:55 AM »
On the Motogadget Chronoclassic, there is a white/red wire that's not talked about in the manual. Any one know what that is?
Also, the manual says the Tach wire is supposed to connect to the coil switched ground. Is that the yellow and blue wire or is that the black wire to the coils?
Are you sure its not WHITE/BROWN? The W/B is TURN R input. I have not seen a RED/WHITE wire...  ???
Yes, the YELLOW wire for your coils is the tach signal connection.
Yup, white/red.
It wasn't in one of the two connectors that's pre-installed at the end of the gauge cable. It was loose.
About the tach wire, to clarify, the yellow wire from the gauge (as it says in the manual) goes to the coil's switched ground. Are you saying I can connect it to either the yellow wire or blue wire from the coils as that is the switched ground side? Or is the black wire to the coils the switched ground?
Offline DaveBarbier
« Reply #1558 on: May 20, 2017, 11:03:39 AM »
Chronoclassic and m-lock are all wired up but there's a weird issue with the m-lock. I programmed the keys which worked perfectly fine, but when I go back to turn the bike on with a programmed key the m-unit and chronoclassic start flashing randomly. Like power is very quickly intermittently cutting out. I took a video.
I know it's with the m-lock because I removed it temporarily and hooked up my original key ignition and things worked normally. Any ideas? I can't find anything like this issue online. Faulty unit? I have the black wire connected to ground, red wire fused and connected to constant power and brown wire connected to the 'lock' on the m-unit.
This is vey strange.
Offline DaveBarbier
« Reply #1559 on: May 20, 2017, 06:36:37 PM »
Figured out the issue! Actually, Brian at A and J Cycles out of New York did, haha. I had the reg/rec sensing wire on the lock terminal as well as the m-lock and it didn't like it. I removed the sensing wire and all is good.
A and J Cycles has a lot of stuff like Cognito products and Motogadget products. I bought the Chronoclassic and the m-lock from them on eBay. Their eBay page accepts offers on products so I got that stuff a little cheaper than other places were selling.
https://www.ajcyclesny.com/
Search for aandjcycles on eBay if you're interested.
He'll never see this but thanks Brian!
Offline DaveBarbier
« Reply #1560 on: May 29, 2017, 04:22:56 AM »
Wanted to post this here too so I can keep things organized and make a link in the table of contents.
Original thread: http://forums.sohc4.net/index.php?topic=165975.msg1918152#msg1918152
Well the quik-latch came yesterday, holy crap that was quik! :)
Just finished the install. Pretty dang easy and I think it looks awesome. It also works perfectly. For the last time, thanks Alabama for the suggestion! I highly recommend this if you don't want to carry keys. Here are the pictures.
I turned up a piece of steel to fit in the hole in the receiving end of the tank. Here's the threaded plug.
You can tell that it's been welded in and painted. I have a nut on the underside locking the post. So it's essentially double nutted.
Video of it working:
Also did the patina treatment to reduce the "bling" factor.
« Reply #1561 on: May 29, 2017, 02:48:59 PM »
Looks great, Dave!
Offline DaveBarbier
« Reply #1562 on: May 29, 2017, 05:26:46 PM »
Looks great, Dave!
Thanks Don! I'm very close to a complete bike. Just finishing up the degree process again and my motor will be complete. Then deciding on what jets to use and buying a handful. Very close!
Offline Camrector
« Reply #1563 on: May 30, 2017, 04:55:46 PM »
Can I still use that modified valve cover?
I'll be ready to degree mine in this week!
Offline DaveBarbier
« Reply #1564 on: May 30, 2017, 06:15:28 PM »
Yes, totally. I am using it currently but hopefully will be finished with it tomorrow. Worst case by this weekend. I'll let you know when I'm finished.
Offline sinister902
    • Anger Street Kustoms
« Reply #1565 on: May 31, 2017, 05:33:04 AM »
I LOVE THAT QUICKLATCH. damn!
« Reply #1566 on: May 31, 2017, 08:44:00 AM »
It's kind of crazy how Honda "keyed" the tank doors. One can use any key or flathead screwdriver to open the latch. It makes it more of a PITA for the legit owner to open.  I guess it was a reaction to the late 70s gas crisis and people stealing gas.  This is a MUCH more practical and cleaner solution.
Offline DaveBarbier
« Reply #1567 on: May 31, 2017, 11:49:38 AM »
Yeah it's weird. Other CB125's and CL200's I've had don't have a locked cap. Not sure why they did a fake lock. I'd bet you're right with the gas crisis thing.
Thanks guys!
Offline DaveBarbier
« Reply #1568 on: May 31, 2017, 12:02:02 PM »
Degreeing again! This time with a big ass 18" wheel. Soooo much easier to read, my god. I can very easily read down to the .25° even .125° if I want to go nuts.
Offline Camrector
« Reply #1569 on: May 31, 2017, 08:31:11 PM »
Noice!! Go nuts!!!!!
« Reply #1570 on: May 31, 2017, 09:20:32 PM »
WOW!  That is one big-ass wheel!
Offline DaveBarbier
« Reply #1571 on: June 01, 2017, 03:34:40 AM »
Haha, totally.
Well motor is almost all buttoned up. Got the degree to within .125° of each other. Very happy with that. Put the real cover back on, sealed the pucks and torqued it up. Just want to verify nothing changed when I loctited the sprocket bolts.
Got to get on the jet situation.
Offline DaveBarbier
« Reply #1572 on: June 01, 2017, 09:55:00 AM »
Speaking of jets, anyone have any recommendations to start? Someone I should be speaking with regarding the CR's? I've been talking with the very knowledgeable Mike from Powerbarn and he recommends the following:
115 main
58 pilot
YY6 or YY7 needle
I trust Mike of course but I figure the more suggestions the better.
I'm going to get a selection with a few jets on either side of the above. It's just hard to guess because there is no basis for what I have done and these carbs. What does everyone else do who has a heavily modded engine?
« Reply #1573 on: June 01, 2017, 02:55:58 PM »
115 main
58 pilot
YY6 or YY7 needle
This one will be more modified that any other I've owned.  Frode (with a MR billet 1000cc block) has a welded bung in his header with an AF probe patched to a meter.
Offline DaveBarbier
« Reply #1574 on: June 01, 2017, 04:16:47 PM »
A while ago I was thinking of doing a welded bung for an a/f sensor, but I'll be doing dyno time up in MA (a shop MRieck recommended) so I'll let the pros handle that. Still want to give them as many jets and needles as they need to do runs with. I doubt they have any CR jets on hand. I've never been to a dyno, so not sure what protocol is.
