Author Topic: Ebay seller kenosha_kid BRONZE swingarm bushings  (Read 2187 times)
Offline brandEn
« on: September 02, 2014, 08:35:03 AM »
Has anybody used the bronze swingarm bushings from Ebay seller kenosha_kid? He is located in Germany and sells them for $28 shipped! The pictures shows a lip on the inside of the bushing though.
kenosha_kid store
Bronze Swingarm Bushings
Offline Mr Freeze
Re: Ebay seller kenosha_kid BRONZE swingarm bushings
« Reply #1 on: September 02, 2014, 08:53:35 AM »
They're probably alright, I looked at those too, but there's others on eBay with a spiral groove cut into them on the inside that helps spread the grease around.
« Reply #2 on: September 02, 2014, 09:10:08 AM »
I used them on K3F - i.e. fitting F arm into K3 frame - they looked good and installed without issues.  The bike was not on the road yet, cannot testify more.
Kenosha Kid is a good seller, communicates really well.
« Reply #3 on: September 02, 2014, 09:27:06 AM »
Branden, by 'lip' are you referring to that light appearance on the bottom? Looks like light vs lip to me??
I bought a set for my F by Parts Plus but don't remember where I got them. Part 28-1026 (SAH-750N).  Made in Japan. They may have had that spiral. Vintagecb750.com I'm thinking. They are $60 now. Kenosha's is MUCH better pricing.
Offline brandEn
« Reply #4 on: September 02, 2014, 09:29:38 AM »
By lip I am talking about that ring in the center of the inside diameter of the bushing where the collar installs. I just ordered a set. I figure the worst that can happen is I am out $30! lol
« Reply #5 on: September 02, 2014, 09:36:38 AM »
Looks like a bronze copy of my NOS set I have in front of me. I think you'll be alright.
Offline brandEn
« Reply #6 on: September 02, 2014, 09:40:21 AM »
Good to hear!
Offline Tews19
  • I am no
« Reply #7 on: September 02, 2014, 10:43:46 AM »
I recently installed those on my 750 and 550. They work great.
1970 Honda CB750 survivor.
Offline brandEn
« Reply #8 on: September 02, 2014, 10:45:38 AM »
SWEET!
Did you install the dust caps and felt washers that are part of the OEM setup or just the bronze bushings?
Offline Tews19
  • I am no
« Reply #9 on: September 02, 2014, 10:48:57 AM »
Just the bushings. With the lip you don't need the other part. I did use the dust caps though.
Make sure you freeze them. I got a set from cb750.com before and those went in easy. To easy actually. Kenosha kids are a snug fit. I had to order a second set when I tried to install without freezing and mushroomed one. Also put in the middle sleeve before install or at least check to make sure you won't have any fitment issues.
Offline brandEn
« Reply #10 on: September 02, 2014, 10:51:25 AM »
Will do. I didn't even think of that. The swingarm collar goes in between the bushings doesn't it?
« Reply #11 on: September 02, 2014, 11:03:48 AM »
Swingarm collar goes inside these bushings.
From the outside:
- swingarm
- bushing
- collar
- long bolt
Long bolt is the very center.  The long bolt tightens the frame and holds the collar in position creating a hinge for the swingarm if you understand what I mean.  The collar and the bolt are stationary and bushings with the swingarm rotate.
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #12 on: September 02, 2014, 11:43:47 AM »
If you're replacing the earlier style bushings without the top hat, you will only need the metal dust caps like Tews said.  Losing the felt grease seal and plastic ring with this setup will only be an issue if you ride in the rain a lot.
My sandcast is sporting these very bushings, and they feel really nice.
« Last Edit: September 02, 2014, 11:53:29 AM by Greggo »
« Reply #13 on: September 02, 2014, 11:51:21 AM »
Excellent points Tews. Same here. I believe I even used the felts from the earlier K's inside the dust caps.
52145-283-000  RING, RR. SWINGARM FELT
Offline brandEn
« Reply #14 on: September 02, 2014, 01:14:45 PM »
Thanks for the help fellas, I will update this thread with a few pictures when I get to the point of installing them. Just as an FYI, about an hour after I bought these the seller contacted me and let me know they are shipping tomorrow. Good seller so far!
Offline brandEn
« Reply #15 on: September 02, 2014, 01:17:48 PM »
Just for future reference...
1974 CB750 K4 parts fiche
« Reply #16 on: September 02, 2014, 01:20:48 PM »
Yes, same experience every time I buy from him.
Here is how I installed them:
http://forums.sohc4.net/index.php?topic=115305.75
Offline brandEn
« Reply #17 on: September 02, 2014, 01:34:02 PM »
Thanks for the link. I like how you did that. Having the collar line up the bushings and pressing it all together looks like the way to do it.
Offline goldarrow
  • one day, i'll be an
« Reply #18 on: September 02, 2014, 04:16:15 PM »
I have those bushing in my 550 also, been 8000 miles and no complaints
CB550 K0
Offline brandEn
« Reply #19 on: September 11, 2014, 05:36:53 PM »
Received my bushings today and they look like great quality. I think they will work great. There is a groove machined into the center that I assume is to hold grease.
Nic
« Reply #20 on: September 11, 2014, 09:00:34 PM »
I bought a set as well for spares, not arrived yet but they look the biz.
Offline Rusted Honda 317
« Reply #21 on: September 11, 2014, 10:29:32 PM »
I did the swingarm needle bearing kit. Working out nice for me.
« Reply #22 on: September 12, 2014, 08:04:24 AM »
While using the center sleeve inside bushing may help line it up, it could end up tight.
 Better to install bushings, then fit sleeve to bushings after. Adjustable reamer should do it.
Offline Stoli
« Reply #23 on: September 12, 2014, 06:39:34 PM »
I have used his bushings on two '78K swing arms and they fit perfectly. Freeze the bushing, warm up the swingarm a bit, apply a little grease and tap them in. They need just the right amount of coaxing. Don't need a sledgehammer but snug enough that you need to give them a decent whack or two with a rubber mallet. Highly recommended.
My Project Threads:
Project #1 - http://forums.sohc4.net/index.php?topic=117106.0  First bike
Project #2 - http://forums.sohc4.net/index.php?topic=127364.0  Something different
Project #3 - http://forums.sohc4.net/index.php?topic=123831.0  Long and Low
